Question about Teledyne Laars HEAT EXCHANGER ASSEMBLY, DP-350 - 10403602
Pilot light will go out a few times a day on mini therm II
I have in floor heating in lower level and forced air upstairs. I have to light the pilot light a few times a day. I've taken out what I think would be similar to a thermocouple and emery clothed it down. I cant remember for sure but I think I have had to do that before and it worked. Could it be that that part now needs to be replaced. Also yesterday it was going out more regularly so when I lit it the last time I left the cover off thinking I would need to light it again but it hasn't gone out since. 12 hours so far. Any help would be appreciated.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Teledyne Laars Master
  • 1,448 Answers
Needs a new thermo coupler
Posted on Nov 06, 2014
jgwhomeequip
  • 1902 Answers
SOURCE: Pilot light wont stay lit
If this is a new item then you will need to let the gas run alittle bit longer. If this is a used item then it sounds like you are going to need to replace the flame sensor. You may have to even do it on the new item. But usually for the first start you willl need to hold the pilot down for about 1 minute to really let things heat up in there then when you release all will work
Posted on May 21, 2009
john224
  • 1378 Answers
SOURCE: pilot light won't stay on
Replace the pilot generator.
Posted on Jul 05, 2009
bill_48632
  • 149 Answers
SOURCE: Laars Lite 2 LG - pilot light will not stay lit.
It sounds like a thermocouple has gone bad. this is a very common problem with gas powered things ie; water heaters, furnaces, hot tubs. The telltale sign is when you release the pilot light button it won't stay lit. This is a safety feature and is relatively inexpensive and easy to repair.
Posted on Aug 09, 2009
  • 33 Answers
SOURCE: my heaters pilot wont stay on and ive replaced the
Problem with the thermocoupler its not producing a minivolt of 250 plus that is needed to open the main gas valve
http://www.laarsman.co.uk
Miles
Posted on Jun 05, 2010
SOURCE: I have a Laars Mini-Therm II boiler that keeps
4.34
Posted on Oct 10, 2010
My upstairs temperature is 80 degrees and the downstairs is 69 Honeywell focus pro th6000 is set at 69. Why is the upstairs so drastically hot?unit is located upstairs& thermostat is downstairs
if there is no control of air movement between floors and you have it on cooling then any cold air will go down to the lower floor
or alternately if you have it set on heating all the hot air will rise to the upper floor
where is the system located (upstairs or down stairs ) and where is the thermostat located
to get control close any upstairs to down stairs doors or erect a heavy curtain across the stair well
Dec 17, 2016 | Honeywell Heating & Cooling
Why can't I lower my honeywell 8500 below 67 on cool?
With a two story house you have to be aware that cold air flows downwards so any cold air coming from an ac unit will flow downstairs( normally down the stairway) so unless you can close off the down stairs then the up stairs unit will be cooling downstairs as well. Ac units have a thermostat located in the air intake and it cools until the cold air has risen to that point. In effect the space above the ac unit will be hotter than the floor. Knowing how they work ,you can see that the upstairs unit will never reach the set temperature because the cold air is continually heating from the house and will never get to the top thermostat.
So your solutions are
1-- fit controls that restrict the cold air from leaving the upper floor (Doors)
2--don't run the upper ac unit unless you are living up there (waste of money
)3 place an ac in each upper room and keep the room door closed
Aug 12, 2014 | Heating & Cooling
Heater is not igniting
see this causes and fix it. God bless you
f there is no heat, check the electrical service panel for a burned fuse or tripped breaker. Relight the pilot light (see below). If there is not enough heat, adjust the burner air shutter (see below); and clean the burner ports (see below).
If the pilot light does not light or does not stay lit, clean the pilot orifice carefully with a toothpick, test the thermocouple and replace it if it is faulty (see below).
If the flame flickers, adjust the pilot (see below).
If there is an exploding sound when the burner ignites, adjust the pilot to a higher setting and clean the pilot orifice and the burner ports.
If the burner takes more than a few seconds to ignite, clean the pilot orifice and adjust the pilot light.
If the burner flame is uneven, clean the burner ports. If the burner flame is very yellow, clean the burner; open vents in the furnace room to provide more air; adjust the burner air shutter.
If the furnace makes a rumbling noise when the burners are off, clean the burner and adjust the burner air shutter.
If the air is too dry, wash or replace the evaporator pad if you have a humidifier; test the humidistat; and adjust the water-level float to raise the water level.
If some rooms are too cool and others too warm, the distribution system may require balancing. Refer to the Forced-Air Distribution Fix-It Guide .
Oct 08, 2012 | Intertherm Heating Cooling System 15kw...
Central heating does not work well upstairs
You need to restrict air flow to lower level vents to allow more air to be forced into upper level. Air will follow the least resistant path.
May 26, 2012 | Heating & Cooling
Weak air conditioner air flow and very hot upstairs.
Check the fans are all working ok and make sure there isn't a louvre closed in the duct
May 04, 2012 | Heating & Cooling
I have a Danby DR401 that I got from a friend, but it won't remove any moisture from my home. The RH% is 79%, the unit is set to 35% and it's been running for 2 days with no moisture being...
There are 5 basic, but solvable reasons for what you described.Numbers 1 & 2, you have already addressed.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
in basement applications. Raising the unit up off the floor, level
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helps you to further troubleshoot and solve the problem. Thanks for choosing FixYa.
Aug 25, 2011 | Danby Dehumidifiers
Had three 50-gal American Standard water heaters installed Dec. 2009 Two upstairs in attic, one downstairs at ground level. Attic location used because heaters being replaced were up there. Upstairs...
Plumber is right.
Problem is not amount of air in attic. Problem is how hot the air is.
Oxygen molecules separate apart in very hot air and pilot light goes out since there is not enough oxygen density to support combustion.
http://waterheatertimer.org/images/Water-heater-in-attic-800.jpg
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
More ventilation is needed.
Plumber is not ventilating expert, and not responsible for attic ventilation that builder failed to install. Plumber should do a survey of location before installation to make sure gasoline vapors are not stored nearby, but summer attic ventilation is gray area until more general-public folks become aware of problem. Hotter summers temperatures will spread that information.
Hire local home center to install roof vents AND soffit vents.
Note: You also need soffit vents.
Remember a vent on the roof is like sucking air out of a coke bottle. The roof vent is no good unless air can also enter the attic from another vent located in the soffit.
Another solution is electric water heater for very hot locations.
Or install solar-assisted water heater.
http://www.hotwater.com/products/residential/cirrex_solar.html
Jul 28, 2011 | American Standard 40 G Natural Gas Water...
I have a Fedders dehumidifer model # A70145D2A-A-R. It is a few years old and it's worked pretty great but now it just runs continuously and no moisture is gathered. What can I do to fix it? I was...
You'd be hard pressed to find a Fedders like yours. They've been out of business for several years.
There are several basic things that can cause what you described.
1. The humidity extraction level is improperly set. Lower the level to 32-35%
2. A dirty of clogged air intake filter. Turn the unit OFF unplug it and remove the filter for cleaning.
3. Obstructed air space. A dehumidifier requires a minimum of 12" clear air space around the entire
unit.
4. The ambient air temperature at floor level is between 40 & 60 Degrees F. Dehumidifiers do not work well in that temperature (Except low temp models). This especially true in a basement application, because the air temperature at floor level is colder than say, chest level. Raising the unit up off the floor onto a sturdy table, cabinet top, etc, that can handle the weight of the unit, plus a full tank of water, will normally resolve that problem.
5. The cooling coils are dirty and need to be cleaned.
Critical problems:
1 The humidity sensor has failed an needs to be replaced.
2.The compressor is low on refrigerant gas and needs to be recharged.
Sometimes the repairs (Time spent finding, the Parts & labor), if necessary, can cost almost as much or as much as a new unit, which would have a full warranty.
Hope this helped you troubleshoot the basic and solvable problems and you won't need to make any critical repairs. Please let me know. Thanks.
Jun 16, 2011 | Fedders R6DH45X Dehumidifier
My dehumidifier suddenly does not remove any water from the air. It worked perfectly last summer and just sat in the basement unplugged over the winter. I plugged it in a few days ago and it has been...
It may simply be a case that the air intake filter needs cleaning, as do the condenser coils. This is recommended maintenance, prior to using the dehumidifier for the first time each season. Also, the air temperature at floor level, may be to cool for it operate properly. Particularly, if it's below 60 degrees. the unit up off the floor and placing it on something sturdy, will help solve that issue.
After cleaning the unit, as stated above, try placing it upstairs where the temperature will be warmer and allow it to run at it's lowest humidity extraction level. That's usually 35%. If it functions properly upstairs, then you will know that it's an air temperature issue in the basement.
Hope this helped you troubleshoot and solve the problem.
May 26, 2011 | Whirlpool AD70USS Dehumidifier
Heat on bottom floor no heat on top floor
pretty vague, but i'll give it a shot. i assume that your upper and lower floors are heated by the same unit. of course if your not sure you better check to see if there is a second t stat for up stairs in case there is a second unit that heats it. there may also be a zoning system that seals off upstairs ducts unless the zone stat for that area is calling for heat. so look for a second stat upstairs if you think it may be zoned. now to you original question. lets assume the unit is not zoned and only one unit heats both. then you may have a mechanical damper in the ductwork ,usually located close to the indoor blower that shifts to force more air upstairs in summer and more air downstairs in winter, these can usually be shifted as needed to control air to upper lower and are usually marked upstairs dornstairs etc. if you have no dampers etc, then you have reason to suspect the ductwork has come apart or been crushed before it gets upstairs. you'll have to go up or under the house etc and try to find duct problems.good luck
Oct 28, 2008 | Honeywell Heating & Cooling
Teledyne Laars HEAT EXCHANGER ASSEMBLY, DP-350 - 10403602 Logo
114 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
