I have a phillips magnovox big screen (March 2000) model # 9P6444 C103 - the picture is very dark and is best watched with the room lights off... what needs to be replaced or fixed?
    Scholar:
  • 87 Answers
The coolant fluid in the blue and green picture tubes is in need of changing.Unless you have done this before I do not recommend that you attempt this repair.A shop shoud be able to make this set look like new again for about $275
Posted on Jan 12, 2009
Keep asking for best picture settings for jvc television model lt-39c740A but getting no reply no very impressed
There is no such thing as a best setting. The "best" setting depends on many things, such as the room brightness, the direction of the light (if any), and your own eyes.
No one can tell you the best settings without knowing the details. Are you watching in a dark room or a bright room? Is any light coming through the windows? In which direction? And most important of all, what looks best to YOU?
Feb 19, 2015 | JVC Televison & Video
Phillips 47PFL422D/37 I've had the tv about 6 years with no trouble. But now the picture is to dark to watch it also pulses. I've tried to unplug it and plug it back in I get a picture for
First, average life on these sets is about 3 to 4 years at best and only boards are sold so even if you can pin point the board (no individual parts are sold) it is likely if will not get fixed and doing so is a bad investment as all the boards are now old.
Dec 04, 2012 | Televison & Video
I have a phillips magnovox 9p6031 c103 rear projection tv. At first the screen would shrink and have an orange look, when I would go through the convergence re-set it would clear up, now the tv makes a...
This problems is the cause of 2 Convergence is dead also.Know how to solders?Buy a convegence kit at Tv repair World.com,Tvrepairkits.com to repair it ur self.The shop will cost u $300 for parts and labors.
Nov 29, 2009 | Philips 46PP9302 46" Rear Projection...
Reference to Phillips Magnovox Model PR1302 C121.
turn on tv,it turns back off,without lighting screen.
May 04, 2009 | Philips Magnavox 27MS343S 27" TV
Picture is dark
On projections, there isn't much you can do as they age accept replace the CRTs. In that case you might as well buy a new one. One thing you can do is open the front speaker grill to where you can see inside the set. Depending on the brand, find the "Screen" controls, one for each tube. Some sets have all 3 on the "focus/screen" block (small black box mounted in front) and some have the knob on each individual CRT board (mounted to the bottom of the CRT). What this does is increases the current to each tube, thus making that colr brighter. Do each equally as to keep the color balanced. Only do this if you feel comfortable with working on electronics.
Jan 12, 2009 | Televison & Video
White corners SONY KDL52XBR6
This is called a dark shading error. All the LCD consumer sets have some visible degree of this effect. Some will be a little less or more than others even from the same batch in the assembly run. This has to do with the optical design quality of how the back-plane lamps illuminate the screen. The design and assembly tollerance of this area is very critical.
Normally, LCD screens don't show their best picture in a darkened room. The very black regions of the picture content may look a little washed out. LCD screens are best watched in a room that is lit, but not very bright. You have to consider that there is a powerful set of lights behind the polarized panel of the LCD display, and there will always be some breakthrough of light.
If you want a TV that is more like a CRT in its characteristics a Plasma would have been a good choice. The trade-off with the Plasma is that it does not have the picture sharpness of the LCD. A Plasma set is best watched in a darkened room.
If you have an LCD computer monitor, take a look at it in a dark room with a black screen. You will most likely see the dark shading errors. Only the very expensive production studio type LCD monitors have less of this error than the consumer sets, and they are not absolutely perfect.
Jerry G.
Nov 19, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
My TV
One of the most common faults with the phillips rear projections is the coolant in the tubes. That can and will make the picture very dim and can cause the brightness and focus controls not to have much affect over it. Please respond to this same post with your model number and I will check to see if their are any other items that could cause that symptom.
Jul 01, 2008 | Televison & Video
Help..... Phillip Magnovox Model 9P5034X101
NOT EXPENSIVE POWER SUPPLY PARTS ARE NEEDED TO BE REPLACED . ONLY A TECH WHO , HAS EXPERIENCE ON THIS TV MODEL AND THE KNOWLEDGE ABOUT THIS PROBLEM ,COULD FIX THE TV RIGHT THE FIRST TIME. OTHERWISE REPLACE POWER DEFLECTION BOARD ,PARTS AVAILABLE AT PARTSTORE OR SIMILAR COMPANIES
Apr 25, 2008 | Philips 9P5034C 50" Rear Projection...
Picture issue with Philips 64" Big Screen
don't know if this is same problem or not but try this:
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.keohi.com/keohihdtv/brandspecific/philips/philips_convergence_geometry.html
Dec 05, 2007 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
95 people viewed this question
Top Televison & Video Experts
