Question about HP 2133-1 Mini-Note PC
My hp mini is typing rapidly same letters and the some key are not working
    Problem Solver:
  • 14 Answers
You need to clean out the keyboard, it sounds as if something was spileed and causing keys to stick.
Posted on Dec 05, 2012
5 Suggested Answers
  • 63 Answers
SOURCE: top letter keys on keyboard not typing
I think its likely to be a hardware problem but check that your keyboard settings are correct for your country. Look in the control panel and then Keyboard settings.
Does the tab key work?
Posted on Jan 21, 2009
byteguy
  • 2229 Answers
SOURCE: When I type numbers are being displayed instead of letters. I was told that my FN key may be stuck, but I can't seem to find the FN key.
The FN key is the key just to the left of the HP key. It says Fn
Posted on May 27, 2009
  • 1043 Answers
SOURCE: i cant undo the fn key on the mini note
You should be able to turn off the built in numeric keypad by pressing the fn key and the num lk simultaneously. The num lk is directly above the +/= key. If after doing this you still find you only momentarily turn off the numeric keyboard then there is another underlying issue. At that point you should take your unit to your area HP repair center.
Posted on Jul 15, 2009
  • 39 Answers
SOURCE: hp mini keyboard shift key 2 does not type @
it has to do with your keyboard setting, currently you are set to the united kingdom keyboard layout, you will need to change this to Unite States settings assuming that you got vista, you will need to do the following
goto control panel
click on regional and language option (there will be a pop up)
click on the keyboard and languages tab
click on the change keyboard button (another pop up will appear)
click on add
and add the United States Keyboard
change the keyboard setting on the upper drop down menu to United States, and then click ok.....this should solve your problem.
Posted on Sep 27, 2009
How i can enble function key
HP laptops have the ability to lock the blue special function keys on, making numerical data entry easier on laptop models that do not have the room for dedicated numerical keypads. Because the key combination to lock the function keys is so simple, however, it is easy for those who wouldn't normally use this ability to do so accidentally. When the function keys are locked, pressing certain keys will result in numbers being typed rather than letters. Unlock the function keys to alleviate this issue.
Press the "Fn" and "Num Lk" keys on the keyboard simultaneously. The "Number Lock" indicator light should turn off, indicating that the letter keys will once again type letters when pressed. This combination should work on the majority of recent HP laptops. If it does not, try one of the alternate key combinations in this article's remaining steps. Press the "Fn" and "F11" keys simultaneously, then attempt to type a letter. If the combination does not work, continue to the next step. Press the "Fn" and "Scroll Lock" keys simultaneously, then attempt to type a letter. Continue to the next step if this does not work. Press the "Fn," "Scroll Lock" and "F11" keys simultaneously.
Jan 16, 2013 | HP 4440s Probook
Hp netbook 110-97TU 1: Text box such as search prompts, google search text box, etc automatically types by itself letter "qqqqqqqqqqqqq......" 2: Keyboard keys/letters not working at all,...
having this issue may cause by hardware problem or key board malfunction, if the computer is still under warranty call your manufacturer and have it replaced.
Jul 03, 2011 | HP Mini 1000 Netbook
I have an HP mini laptop,but I don't know how to get the @ sign to work, it is shown on the Q key.Is it because it was from Germany ? The languague format is English US. Thanks, Judy jngulu@yahoo.com
Isn't the @ symbol with the number 2, just above the letter Q?
If I'm right, you can type "@" by holding the shift key and then pressing 2/@ key.
Mar 22, 2011 | HP Mini 1000 Netbook
My compaq mini 110 - some of the keys are not working and i get these long streaks of letters like wwwwwwwwwwwwwwwwww when i just type it once
It sounds like you W key gets stuck. A possible solution is to press it down hard and wiggle it side to side to force the mechanism and rubber contactors to shake off any dust and dew buildup. If this doesn't work you may try to remove the key, but you'll have to work carefully so you don't break the key.
Jan 15, 2011 | HP D8597A Keyboard
Hp 2133 keyboard is locked on typing umbers instead of letters
Hit Function and F11 (F11 on my mini is num lock)
You need to turn off numlock to go back to letters. If F11 doesn't work look at the function keys for numlock and then hi FN + F##
Jan 11, 2011 | HP 2133 Notebook PC
HP MINI keyboard letters doesn't want to work
the letters of n, b and six, seven of my HP Mini 110 keyboard would not work, what should i do?
Oct 28, 2010 | HP D8597A Keyboard
I can't type the @ key
when typing e-mail addresses, press the shift key holding this key down and then press 2 directly above in-between letters Q and W
Sep 20, 2010 | HP Mini 1000 Netbook
I have an hp mini laptop..whenever i press letters u,i,p,o,j,k,l,m it shows numbers 4,5,6,1,2,0. maybe i had typed something which made this like this..how do i do it.
The problem is that you have to turn off the number lock hold FN key and press the scroll button wherever its on your keyboard usually its after the f12 key,, that should fix your problem...
Jun 08, 2010 | HP 2133-1 Mini-Note PC
I cant undo the fn key on the mini note
Jul 15, 2009 | HP 2133 Notebook PC
HP 2133-1 Mini-Note PC Logo
57 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
