Question about Blaupunkt Car Audio & Video
Reno 2 rear speakers blown on 1990 Carrera 2 need replacements
    Sergeant:
  • 256 Answers
As long as there the right size, Any after market speaker will evan work in it, End probally sound better then the factory speakers,
Posted on Dec 04, 2012
Porsche Carrera bass speakers inoperative
Either your speakers are blown, you have a loose connection somewhere, or your amp is bad. First thing to check is the amp. If all looks good then you probably need new speakers. Be sure to check all fuses, and, the super simple stuff- like verify the bass setting on the head unit isn't turned all the way down to 0
Aug 22, 2013 | Porsche Cars & Trucks
Harmon kardon avr-520 keeps turning itself off
I have a avr 520 and had put it away for about 6 months to reno the theater room when it was done I hooked it all back up and it started to shut down. Not when the radio was on but when I was playing a blue ray movie after reading all the pages of info there was on this subject I went home and disconnected the speakers and sub and then played the movie with no sound for 30 minutes. Then hooked up one rear at a time let that run for 20 minutes each then the other rear. Restarted movie moved to sub then right front center then left front and it went off. Unhooked left speaker and it ran fine. ran new speaker wire to left front and it ran fine ran 2 full movies through it. The speaker wire I use is not cheap either 12 gauge 99 percent oxygen free wire. Somewhere in the reno it was snagged or pinched and was grounding out causing the unit to overheat and turn the unit off. Thanks everyone for their input that info help a lot. hopefully these helps someone
Dec 17, 2012 | Yamaha Audio Players & Recorders
What is the comon fault
The most serious common faults are with the standard 3.4 engine in the early 996 Carrera models (not applicable to Turbo engined vehicles which is a different engine design):
1. The engine cylinder liners develop hairline cracks. (Engine replacement or rebuild required).
2. The intermediate shaft bearings fail in these engines (a well known design fault). Failure requires engine replacement.
3. The rear main seals in the engines fail as exhibited by a slowly worsening oil leak. The seal needs to be replaced when they leak. It's an expensive job.
Problems 1 and 2 are serious have resulted in many engine replacements. Problems 2 and 3 remained when Porsche upgraded to the standard 3.6 engine in the series two 996 Carrera models (problems not applicable to Turbo engines)..
There are a few other issues such as Air Conditioning condensers that clog up with road debris and eventually become porous and fail.
Jan 14, 2011 | 1999 Porsche 911 Carrera
Porsche 1990 carrea 2 hood latch not working anyway to release hood?
With a rarchet, extension and socket remove the bolts holding the latch to the core support and the hood will open. The cable usually just fell off. reattach or replace as needed.
Nov 20, 2010 | 1990 Porsche 911 Carrera
I HAVE A 1990 TOYOTA CAMRY AND I NEED A WIRING DIAGRAM FOR RADIO INSTALLATION.
does this help, or do you need more?
1990 Toyota Camry Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: Black/Red
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 3 1/2?
Front Speakers Location: Dash
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 5 1/4?
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
Oct 17, 2010 | 1990 Toyota Camry
Have a 1990 Porsche Carrera 2. Key lock Broke on drivers side while we were locking car and engaged alarm. Need to figure out how to disarm alarm so I can get car started again. I can turn alarm off on...
Um, how about having the lock repaired or replaced so that the alarm and locking functions work again? If the car is in Bozeman, MT, I recommend contacting Auto Stop who have experience with porches.
May 07, 2017 | 1990-1993 Porsche 911 Carrera (964) Relay...
I need raido wiring diagram for 1990 corolla
1990 Toyota Corolla Stereo Wiring Diagram
Radio Antenna Trigger Wire: N/A
Radio Amp Trigger Wire: N/A
Front Speakers Size: 4′
Right Front Speaker Wire (+): Purple
Right Front Speaker Wire (-): Light Green
Rear Speakers Size: 4′
May 29, 2009 | 1990 Toyota Corolla
1992 porsche carrera convertible top won't open. It starts to open then you hear a crunching noise from one of the top motors behind the seat
Replace the top motors or check cables from motors to top. There are 2 motors one for each side of the top.
Apr 25, 2009 | 1990 Porsche 911 Carrera
Cannot shift into reverse although forward gears all functional
have ur shift linkage bushings replaced....most likely thse are torn or completely broken .. this is common on these models..also on some vw's of the same years
Apr 09, 2009 | 1990 Porsche 911 Carrera
Cut harness from stereo in 1990 corolla dx sedan
did u know that they make a harness for your car that plugs into your factory harness and then adapts to your aftermarket radio? for the lights, you have blown the interior light fuse, it may be the same fuse as the cigar lighter.Below is your radio wire colors and what they do.
1990 Toyota Corolla Car Stereo Radio Wiring Diagram.
Dec 19, 2008 | 1990 Toyota Corolla
Car Audio & Video Logo
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
