Question about Indesit Washing Machines
Reset indesit wib111 - Indesit Washing Machines
  • 569 Answers
SOURCE: indesit WIB111 vibrates excessively on a spin
It sounds as if one or more of the drum supports, which are springs or shock absorbers, have become detached or are in some way damaged. You would need to take the back and top off the machine to check this. Otherwise you will have to call a service engineer.
Alternatively, if this is a brand new machine, the reason is that the transportation fixings have not been removed. These are typically two or more steel rods that hold the drum in place, and have to be removed when the machine is installed, and before it is used, If they are not removed there is no damping of vibration as the drum is not free to move on its flexible supports.
Posted on Mar 19, 2010
Testimonial: "Thanks that was really helpful"
  • 159 Answers
SOURCE: washing machine drive belt keeps coming off
Try putting some locktite on the thread of the bolt. Loctite is a liquid you can buy to lock bolts into there threads.Alternativley the pulley that the belt runs on may be worn & sloppy in the centre where it goes on the metal shaft.you may need a new pulley as well as Loctite..but try the Loctite first.
Posted on Jun 01, 2010
tanda400
  • 7 Answers
SOURCE: My indesit wib111 wont go ignto o spin cycle or
Washing Machines do not spin when filled with water for obvious reasons. Have you checked the filter? this could be blocked with a build of fluff etc.
Can you hear the pump running when it is supposed to be emptying. This means there is a blockage. Can you hear a "humming" This means the pump is jamed, may be a coin or some other small item. If there is no sound then the pump is most likely at fault.
Posted on May 04, 2012
Testimonial: "well what can i say but true expert removed the filter found 20p pieces jamming the pump.removed refitted the filter now working like new .thank you so much 5 star"
  • 3 Answers
SOURCE: indesit wib111 leaking from pump
This that unscrews is a filter cover, it does have to come out and will be restricted by something thats blocking it, without being too forceful it will have to be removed so the "catch area" can be cleared of objects, like pins and maybe a sock, then the cover can be screwed back in and made secure to stop it leaking (engineer of 20 years experience)
Posted on Aug 29, 2012
  • 389 Answers
SOURCE: Indesit wib111 1100, pressed button to start but the red doorlock light comes on & the top green light & thats it ,No fill up or Start. Please Help
is the door locked just try opening the door and shutting firmly
Posted on Oct 02, 2012
Testimonial: "This is one of the most helpful sites on the web thank you, "
Door hinge won't come off
TORX is the screw type that you need a tool for. They come in different sizes.
Nov 25, 2013 | Indesit Washing Machines
Wib111 drains but not spinning, also repeating cycle
Check your fault codes. I have had to raise the discharge hose to 1" to 1 1/2" above the back of the washer, then connect to the drain tube. Height of the discharge hose can cause cycle to not operate properly, like fill and drain at the same time and won't cycle properly.
Jun 20, 2013 | Indesit W 123 Front Load Washer
Indesit wib111 leaking from pump
Aug 29, 2012 | Indesit Washing Machines
My indesit wib111 wont go ignto o spin cycle or empty.it fills and washes ok
May 04, 2012 | Washing Machines
Washing machine drive belt keeps coming off indesit wib111. the nut which holds the drum and the whell keeps also undoing, no matter how tight i do it up.
May 31, 2010 | Washing Machines
Washing Machines Logo
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
