Question about Dell E172FP 17" LCD Flat Panel Monitor
Where do i set the brightness of the monitor - Dell E172FP 17" LCD Flat Panel Monitor
    Problem Solver:
  • 9 Answers
Dear sale out this monitor and buy new monitor
Posted on Dec 04, 2012
How can I decrease brightness and contrast?
To help you change the brightness and contrast settings from the LCD monitor, please follow the instructions mentioned below,
The control buttons are located at front panel of the monitor. The Brightness Button is used to select the Brightness/Contrast adjust functions. Press to switch functions or adjust settings.
To decrease the brightness or contrast press (-) button & to increase (+) as per your adjustment.
GuruAid.com
Mar 29, 2016 | Dell E173FP 17" LCD Monitor
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
Brightness and contrast symbols
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
LCD back light is off or very dim
I changed monitors and it works??? What worked. Did the brightness appear? Is the monitor now functioning properly?
If not, monitors can have increase brightness by using the menu settings. The settings can be accessed by the buttons that are usually below the monitor screen on the front under panel. Adjust the brightness from there.
If that fails then change the monitor. That you are suggesting that the backlight is out, I am assuming that you have a flatpanel monitor and not a CRT. Either can be configured the same way using the menu buttons; however, the back light issues are different in the two types of monitor.
Good Luck
Sep 28, 2009 | Dell Dimension 2400 PC Desktop
How do I adjust brightness on Dell E152FP monitor
there's a buttong located on your monitor. just look for it then set up brightness to watever display u want.
Jul 03, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Brightness pop-up window on screen
The setting is programmed into the memory of the monitor. It has been set that way, sort of like a memory button for your car's driver seat. The car remembers your favorite seat position, and the monitor is remembering your favorite brightness settings.
It's been a while since I played with any settings on a CRT monitor, but I'm sure if you give it a few minutes, you will find in the menu how to set up the memory recall feature on your monitor.
good luck.
tony
May 20, 2009 | ViewSonic E70fb 17" CRT Monitor
Acer AL11511
To even things out you need to use the controls on the monitor to lower the brightrnes. to acceptable levels. When playing a DVD there are seperate controls in the software and your graphics driver to adjust the Video Overly settings. Look for settings called gamma and brightness in the video overlay settings in the windows display properties panel. This should help even things out some. Deal is to crank down the brightness on the monitor and crank it up in the video settings in windows. It will make the DVD's brighter and rest of the time the regular screen darker.
Jun 26, 2007 | Acer AL1511 15" LCD Monitor
CRT monitor too bright
I have/had same problem. I have ATI Radeon display adapter and in driver settings there was adjustment for brightness. I adjusted that to minimum and now the brightness is pretty good (still little bit too bright, monitor setting 0%). Other succestions welcome...
Sep 28, 2006 | Keytec Sony Multiscan E500 21 in. CRT...
Dell E172FP 17" LCD Flat Panel Monitor Logo
13 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
