Question about KitchenAid KGRA806PSS Gas Kitchen Range
Oven light not working
Kitchenaid gas range model YKGST307HW9. Broked a light in oven socket. I used a tool but short circuited something. is there a fuse somewhere. none of the 2 light working.
thanks
Please RTGDM
Posted on Jan 17, 2009
Kitchenaid gas range keeps beeping intermittantly, oven turns on by itself and code F2:E1 keeps comiong up on pad. What is the problem
Hi
Thanks for using FixYa. Error F2-E1 in your Kitchen Aid range indicates shorted keypad. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 29, 2010 | KitchenAid KGSA906PSS Gas Kitchen Range
Kitchenaid Gas convection range lower burner will
whirlpool oven wont turn on top burner work.
model #SF315PPQ2
Sep 04, 2009 | KitchenAid KGRT607HBS Gas Kitchen Range
KitchenAid KGRT607 - Oven won't light reliably, can smell gas.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Aug 29, 2009 | KitchenAid KGRT607 Gas Kitchen Range
Oven wont turn on.
Ours did that and I installed a new igniter. Took the old one out and went to a store that sells them. Installed it myself.
Sep 29, 2017 | KitchenAid KGST307 Gas Kitchen Range
Kitchenaid YKGRT607HS6
F2:E0 is shorted keypad, and F2:E1 is no keypad connection, you need to replace the keypad.
You can find schematics and find replacements by entering model number here.
Dec 14, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Oven Doesn't Work
See my post on this subject.
lapwte
Dec 14, 2008 | KitchenAid KDRP467KSS Dual Fuel (Electric...
Dual fuel kitchenaid; burners work, oven does not
I had a similar problem. There's a thermostat before the control panel. You need to remove the knobs and the front panel to get to it. You'll also need to remove a couple of trim pieces to keep from bending the panel. The part number is Whirlpool W10017820, sells for about $40.
Nov 29, 2008 | KitchenAid KDRP467KSS Dual Fuel (Electric...
KitchenAid superbra range KGST307
I am not a repair man or anything, just an owner with the same gas range slidein appliance. What we have found to work was 1) plug in the probe into the socket in the oven 2) Turn on oven with the probe set at the minimum 160 degrees. and oven temperature to 325 degrees. 3) click start 4) wait for oven to reach probe temperature. 5) oven will then beep show end 6) Click cancel 7) open door and remove probe. 8) wait five minutes before trying to use again. I hope this helps you it has work for us so far. 6)
Aug 27, 2007 | KitchenAid KGST307 Gas Kitchen Range
KitchenAid KGRA806PSS Gas Kitchen Range Logo
200 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
