Question about Cobra Power Inverter 2500 Watt Continuous 5000 Watt Peak, 12dc>120ac Cpi2575
My cobra unit cpi 2575 has a message olp how do I remove message?
Use this in the transport trailer
2 Suggested Answers
SOURCE: need fuse size for cobra cpi-850
80a fuse should work fine thats the size i have it installed with i used 4 ga. wire
Posted on Jan 09, 2009
I replaced the 35amp fuses with 40s in my 1550 cobra power inverter will that cause the olp code to pop up
The olp overload refers to Watts and the fuse is monitoring Amps! The rule is replace fuses with the same or lower but in this case it isn't causing the olp!
Oct 22, 2014 | Electronics - Others
Cobra inverter
should probably connect it straight to your battery or you are trying to use something that requires too much power.
Sep 04, 2014 | Cobra 12 Volt 2500 Watt Power Inverter...
Cobra inverter overload
Check out this manual:
http://search.aol.com/aol/search?&s_qt=sb&q=Cobra+cpi-2575+instruction+manual&tb_oid=07-01-2013&s_it=amonetizetest1-ie&tb_mrud=07-01-2013&tb_uuid=20130107163427450
Jan 13, 2013 | Cobra CPI-2575
How do I remove olp message
Its an inverter DC to AC---what since I do not understand the described problem is the unit doing or not doing?
Dec 04, 2012 | Cobra Cpi 2575 5000-watt, 12-volt Dc To...
I am using 2500 cobra inverter .when i go to plug in extention cord led comes up ( OPP ) and and i do know what that stsnds for ? no power
Short Circuit Protection - OPP
If the
AC output of the inverter is shortcircuited
for one second or more,
it will shut down to protect itself.
The meter will flash as shown to
indicate Short Circuit Protect and
an alarm will sound.
To restore normal operation,
disconnect the short circuit and
turn the unit
Off and On again
using the
Power Button.
Current flowing down an unintended path, try a new extension cord
Apr 15, 2012 | Cobra CPI-2575
What kind of fuse does the cobra cpi 150 take?
FROM WHAT I CAN SEE IF THERE IS A FUSE IT WILL BE INTERNAL, I'M SUPRISED TO SEE THERE IS NOT A RESET OR OVER LOAD PROTECTION ON THIS UNIT CALL COBRA AND THEY CAN ANSWER THE QUESTION
Aug 10, 2009 | Cobra CPI 150 BK MicroPORT Power Inverter...
Power invertor weill beep a few times then shut
insufficient ground...check your connections and try again...do NOT continue to use the unit if the problem persists.
Good Luck
Jun 15, 2009 | Cobra 2500w Power Inverter
2000 watt cobra inverter keeps saing olp, overload
2000w means is out off rang load 2000w plus then alarm beep have running.
Mar 24, 2009 | Cobra CPI 1000 DC to AC Power Inverter
Need fuse size for cobra cpi-850
Jan 08, 2009 | Cobra CPI-850 Car Audio Amplifier
Cobra Power Inverter 2500 Watt Continuous 5000 Watt Peak, 12dc>120ac Cpi2575 Logo
Top Cobra Car Audio & Video Experts
xxxxxx xxx
Are you a Cobra Car Audio and Video Expert? Answer questions, earn points and help others
