Question about Jenn-Air JES9800A Electric Kitchen Range
Jen-air JES9750 Stove beeps - digital touch controls don't work
Digital read out has said (F1 -7), (F-8) at different times; cutting off power did not reset or help Top burners and dials work Clock works (can't set) Oven light works (only when door opened)
    Top Expert:
  • Jenn-Air Master
  • 9,472 Answers
SOURCE: Jenn Air slide in range JES9750AAB - Touch Pad
put on tree belt . having the same problems replaced ERC $200.00 now they are telling me touch pad touch pad is $240.00 .the stove cost $1300.00. $1740.00 how much more will i have to put in this stove
Posted on Jan 06, 2009
Krazytech
  • 725 Answers
SOURCE: beeping, flashing, oven door locked, display shows F-1
F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) BUT you also need to check the Oven Temperature Sensors The Oven Temperature Sensors should read room temperature, 70°F, the resistance is 1000-1200 ohms. make sure you pull off the wires to measure the sensor's resistance and it reads open it is bad. and you will have to replace it too. hope this helps.
Posted on Sep 05, 2007
  • 126 Answers
SOURCE: GE gas stove the burners on top work, the oven won't get hot
The most common reason a gas oven won't heat is a bad igniter. It is located near the valve and burner under the oven bottom. You can usually see it glow orange just before the fire lights. Most GE ranges take a cylindrical igniter part #WB2X9154 or #WB13K21 rectangular igniter.
Posted on Jan 02, 2009
yecalam13
  • 41 Answers
SOURCE: I have a jenn air oven and stove top. the
Just a suggestion, turn the breaker off to the range and leave off for 30 secs. This may reset the board. That's the easy way. If that doesn't help I'll try to find more on it.
Posted on Jul 24, 2009
SOURCE: I have a Jenn Air 'slide-in' electric
The unit has a bad touch pad
Posted on Mar 05, 2010
Baking
I sounds like an issue with the pilot light. Our stove does the same. Sorry that's not much help
Jul 23, 2012 | Jenn-Air JES9750 Electric Kitchen Range
I have a hotpoint older stove don't have the model # at this time. the digital display on my oven stopped working { stovetop works fine). After about 2 months of nothing all of a sudden it lights up...
The beeping indicates to me that the clock has power to it and it's the problem and needs to be replaced. ya need model number to order part it usually can be found on rim around door or inside of the bottom storage drawer, when ordering parts its call by 4 names, all are the same part its either clock, eoc,oven control,or relay board
Gene
Aug 03, 2011 | Hotpoint RB790SHSA Electric Kitchen Range
HOW TO UNLOCK JEN-AIR STOVE TOP MODEL# JED4536WR01
The All Off cooktop touch control turns off the downdraft exhaust
system and all surface cooking areas that are in use at the same
time.
The Lock cooktop control avoids unintended use of the surface
cooking areas. When the cooktop is locked out, the surface
cooking areas cannot be turned on by the cooktop touch
controls.
To Lock Cooktop: Touch and hold the ALL OFF/LOCK keypad
for 4 seconds. After 4 seconds, ALL OFF/LOCK will glow red,
indicating that the cooktop controls are in the lockout position.
To Unlock Cooktop: Touch and hold the ALL OFF/LOCK keypad
for 4 seconds.
Apr 24, 2011 | Microwave Ovens
We have a GE Spectra,What is F1?how do you stop it from beeping when it does it?
Remove the back panel to the range and check the wires coming from the oven temperature sensor to the control board. Check and make sure the connector is secure, you can also bypass the connector plug by cutting off the connectors and joining the wires directly. If directly joining the wires doesn't solve the f1 code error, then you may have to replace the control board.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part.
Feb 07, 2011 | GE Spectra JBP78 Electric Kitchen Range
I have Model #JER8750AAB Serial#16776012WK When uising the self cleaning feature, oven stopped and F1 displayed on stove ??
Dec 19, 2010 | Jenn-Air Microwave Ovens
I have a jen air propane oven and four stove burner and it is flashing a the code f7-1 and saying call a a tech. Please help the beeping is very annoying
Hi, the error code implies that the Function key shorted or stuck..
You need to replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Oct 20, 2010 | Jenn-Air JJW8530C Expressions Collection...
Left rear stove top electric burner does not work. burner element good. no power from stove to plug in module that has front and rear burner. front burner works.
ok you have a fun one becuase the sockets could be bad you need to check for 220volts at the plug in for the serface burners if no power there then bad switch
Jun 02, 2010 | Jenn-Air JES9750 Electric Kitchen Range
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Front control panel shows "Remove Probe From Oven" & Beeps.
I have the issue as well, seems like when I use the convect. feature. I have not called to have it serviced yet, but I have found that opening the oven door and truning the fan on for a few minutes, corrects it. At least until you turn it off again.
Sep 23, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Aug 02, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Jenn-Air JES9800A Electric Kitchen Range Logo
117 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
