Question about Sony VAIO VPCF134FX/B F Series Notebook
Button turning Wireless on/off does not work
The button is not connected to anything on the motherboard. So what should it be connected to? (I pickeded it apart to clean the fan)
I have a notebook aspire 6930, i've had it just barely over a year, and a couple days ago my internet just wouldn't connect. When i push the touch button to turn the wireless LAN on it does not light up...
1) Make sure Wireless Lan is Enabled by pressing the light button of it
2) Click with right button on the Battery Icon (on the botton bar aside clock)
3) Select Windows Mobility Center (a window will open up)
4) Click on "Turn wireless on" button.
Jun 12, 2010 | Acer Aspire 6930-6455 Notebook PC
In my laptop wi fi can't work
Once you press the button that represent the bluetooth and also the wireless it will turn from an amber colour to blue then if nothing is showing for you connect to anything then you have it but is not yet drive . you will need a WLAN driver meaning a wireless local area network driver then you can get that downloaded from the http://microsoft.com/download that is compatible with your operating system then after downloading it install it with the prompt it gives you . then repress the button and check for test.i
if that doesn't work then maybe someone has work on your system before that has forgotten to connect you wireless cable on the motherboard.
kindly rate this solution..
May 07, 2010 | Toshiba Satellite A135-S4527 Notebook
Wireless does not work my computer does not read wireless base station
turn on the wireless button ON...if still the problem exists then re-install the wifi driver from the motherboard drivers & utilities cd/dvd given by your compaq distributor. Then you will find your wireless connection working properly.
Feb 23, 2010 | HP Compaq Presario F500 F700 and G6000...
Wireless switch is broken. and i wanna knowhow to turn on wireless without using the button
Since the switch is soldered to the motherboard, I would not suggest messing with it, I would get a small usb network adapter and connect that way. The only way to fix that problem is to resolder a new switch. It cannot be bypassed, it is built into the motherboard circuit. The button has to be in the "on" position to be able to be enabled from the device manager because the "On" button turns on the Wireless radio.
Oct 07, 2009 | HP Pavilion zd8000 Notebook
Wireless button
The wireless button is on the left side of the computer. It is just to the right of the audio connectors.
Apr 05, 2009 | Dell C600 (002UH) Motherboard
Logitech wireless mouse and keyboard
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Sep 23, 2008 | Logitech Cordless Mouse
Laptop will not connect to blitz router
Make sure the laptops wireless card has not been turned off. Many laptops have a button where you can turn off the wireless card.
Jul 09, 2008 | Blitzz Technology (BWA611) Router
Computer won't turn on
check all led's. then make sure your switch is connected to the motherboard properly. if a conection to the switch is loose (which is what it seems) it wont register to start the boot process.
Feb 24, 2008 | Mach Speed (S755) Motherboard
Sony VAIO VPCF134FX/B F Series Notebook Logo
22 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
