How do i tune tv to input #1
Connecting phillips dvd player to
emerson EWFG 2705 TV--ALSO AM CONNECTED TO DISH
I FOUND THE ORIGINAL TV REMOTE
Posted on Jan 15, 2009
I'm trying to hook up my dvd player to my tv and dish network system. I had disconnected it a couple of months ago before having some renovations done in my house, and I can't get it back to how...
If you have HD TV it is best to hook up the DVD player separately.
The easiest way to connect this is to find the cable going from the receiver to the TV and disconnect it from the TV. Connect this cable to the back of the DVD player where it says "in" or "input".
Next take another cable and connect it from the DVD player output to the TV. Make sure your TV set is tuned to the correct channel and input and you're all set. If you need further assistance please reply here and I will see to it this gets resolved.
Daniel Busa
DISH Network
Customer Service
May 22, 2011 | Emerson EWD2204 DVD Player/VCR
What channel does the tv have to be on - I have dish network - do I leave the dish off or on and move it to a certain channel?
First check what channel or input your TV is currently on bypowering the TV off then back on and noting the channel or input that appearson screen when the TV is powered on. If you are using a Coax Cable toconnect the receiver to TV1, check the receiver's back panel for the outputname. If your receiver has a "TV CH 3/4 out" (non-ViPReceiver): Tune TV to channel 3 or channel 4, if it has"Home Distribution" output (ViP Receiver): Tune TV to channel 62or 75. If using non-Coax (RCA, Component, or HDMI) to connectreceiver to TV1, cycle through the inputs until picture appears. In your casesince you have the Toshiba XDE500 connected between the receiver and TV, tuneTV and component to channel 3/4 (coax) or correct input. Hope this helps, andhank you for being a valued DISH Network customer!
Phillip Chang DISH Network Customer Support Representative
Feb 08, 2011 | Toshiba XDE500 Player
Can't get my westinghouse tv to recognize dish network
Happy to help get that fixed right away!
You mentioned that your TV is not recognizing the DISH Network signal, since wedo not know how many TV's your receiver is able to support, or whether it's theTV1 or TV2 having the issue I will address them both.
The first thing we want to do is ensure that all connected components arepowered on (VCR, DVD Player, etc.). Check what channel or input your TV iscurrently on by powering the TV off then back on and noting the channel orinput that appears on screen when the TV is powered on.
If TV1:
Check what type of cable is used to connect the TV to the receiver. If you areusing a Coax Cable to connect the receiver to TV1, check the receiver'sback panel for the output name. If your receiver has a "TV CH 3/4Out" (non-ViP Receiver): Tune TV to channel 3 or channel 4,if it has "Home Distribution" output (ViP Receiver): Tune TVto channel 62 or 75. If using non-Coax (RCA, Component, orHDMI) to connect receiver to TV1, cycle through the inputs until pictureappears; most TVs have a "TV/Video", "Input", or"Source" button. If the issue persists, check that theconnections between your DISH receiver and your TV are secure then reset thereceiver by unplugging it from the outlet for 10 seconds then plugging it backin. If not fixed then connect another component (VCR, DVD Player, etc.) to thesame TV, using same cable, same input, and same channel to see if it works. Ifit works with the other component then call us at 1-800-333-DISH (3474) foradditional troubleshooting, if it still doesn't work with the other componentthen the cable should be replaced.
If TV2:
Access "Modulator Setup" from TV1 by pressing the menu button(on the top left of DISH remote) then pressing the numbers 6-1-5. Tune TV2 tothe channel that appears under "TV2 Out" on screen. If stillno picture, verify the mode (air or cable) that TV2 is on. Then change themodulator setup to match this mode (air or cable). After changing modulatorsetup, tune TV2 to the channel that appears under "TV2 Out" onscreen. Check that the connections between your DISH receiver and your TV aresecure then reset the receiver by unplugging it from the outlet for 10 secondsthen plugging it back in. If not fixed then connect another component (VCR, DVDPlayer, etc.) to the same TV, using same cable, same input, and same channel tosee if it works. If it works with the other component then call us at1-800-333-DISH (3474) for additional troubleshooting, if it still doesn't workwith the other component then the cable should be replaced.
Phillip Chang
DISH Network Customer Service Representative
Feb 06, 2011 | Westinghouse SK-32H240S Television
How do u hook up the dvd player and dish network to your tv
The easiest way to connect your DVD player with your TV, is to find the cable going from the receiver to the TV and disconnect it from the TV.
Next take another cable and connect it from the DVD player output to the TV. Once you've done this make sure your TV set is tuned to the proper input or source. Your DVD's should play when the receiver is off, however, you'll probably need your DVD player on to get the DISH signal.
Daniel Busa
Dec 10, 2010 | Sanyo DWM400 DVD Player
Sylvania tv lc220sl1 trying to hook up with dish network and tv setup says (autoscab) receiving no channels or no signal.
We would be happy to help get your picture back. The first thing we want to ensure is that all connected equipment is on.Check what type of cable is used to connect the TV to the receiver. If you areusing a Coax Cable to connect the receiver to TV1, check the receiver'sback panel for the output name. If your receiver has a "TV CH 3/4Out" (non-ViP Receiver): Tune TV to channel 3 or channel 4, backif it is labeled "Home Distribution" (ViP Receiver): Tune TVto channel 62 or 75. If using non-Coax (RCA, Component, orHDMI) to connect receiver to TV1, cycle through the inputs until pictureappears; Most TVs have a "TV/Video", "Input", or"Source" button. We want to ensure that the TV and the receiverare connected properly, please visit this link to for more information:http://www.dishnetwork.com/SupportSection/setup-receiver-totv. Once we havemade sure everything is connected properly, unplug receiver for 10 seconds thenplug it back in, this will reset the receiver. If we are still not getting apicture connect another component (VCR, DVD Player, etc.) to the same TV, usingsame cable, same input, and same channel to see if it works. If you get apicture with the other component give us a call at 1-800-333-DISH (3474) forsome additional troubleshooting. If it doesn't work with the other componentthen replace the cable that was used.
We hope these steps resolve the issue. We want to thank you for being a valuedDISH Network customer!
Phillip Chang
Oct 02, 2010 | Sylvania LC320SS8 32 in. LCD Television
Just set up new tv on dish network and eveything
It would be our pleasure to help get that fixed right away.The first thing we want to ensure is that all connected equipment is on;although it may seem like an obvious step we don't want to overlook it. Checkwhat type of cable is used to connect your TV to the receiver. If you are usinga coax cable to connect the receiver to TV1, check the receiver's back panelfor the output name. If your receiver has a "TV CH 3/4 out": Tune TVto channel 3 or channel 4, if it is labeled "Home Distribution":Tune TV to channel 62 or 75. More than likely you are using a non-coax (RCA,Component, or HDMI) cable to connect receiver to TV1, in this case we want tocycle through the inputs of your until picture appears; most TV's have a"TV/Video", "Input", or "Source" button either onthe front of the TV or on the remote. We also want to ensure that the TV andthe receiver are connected properly, visit this link to for more information:http://www.dishnetwork.com/SupportSection/setup-receiver-totv. Once we havemade sure everything is connected properly, unplug receiver for 10 seconds thenplug it back in, this will reset the receiver. If we are still not getting apicture connect another component (VCR, DVD Player, etc.) to the same TV, usingthe same cable, on the same input/channel to see if it works. If you get apicture with the other component give us a call at 1-800-333-DISH (3474) forsome additional troubleshooting. If it doesn't work with the other componentthen replace the cable that was used.
Phillip Chang
Feb 21, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
TV Stuck on 1 channel
We would be happy to help get that fixed right away. The first thing we want to ensure is that all connected equipment is on. We want to then check what type of cable was used to connect the TV to the receiver. If you are using a Coax Cable to connect the receiver to TV1, check the receiver's back panel for the output name. If your receiver has a "TV CH 3/4 out": Tune TV to channel 3 or channel 4, back if it is labeled "Home Distribution": Tune TV to channel 62 or 75. If using non-Coax (RCA, Component, or HDMI) to connect receiver to TV1, cycle through the inputs until picture appears; Most TVs have a "TV/Video", "Input", or "Source" button. If we are still not getting a picture then unplug receiver for 10 seconds then plug it back in, this will reset the receiver, then try cycling the inputs again.
We hope these steps resolve the issue. We want to thank you for being a valued DISH Network customer!
Phillip Chang
Jan 22, 2010 | Emerson EWF2004 20" TV
I have recently switched to a Dual receiver from Dish network...I have a coax connection to my Sony but cannot find the way to change the input to find the signal from the coax cable. The TV will not take...
We would be happy to help get that fixed right away. Thefirst thing we want to ensure is that all connected equipment is on. Since we know you are using a coax cable to connect the receiver toTV1, check the receiver's back panel for the output name. If your receiver hasa "TV CH 3/4 out":Tune TV to channel 3 or channel 4, if it is labeled "Home Distribution": TuneTV to channel 62 or 75. We also want to ensure that the TV and thereceiver are connected properly, please visit this link to for moreinformation: http://www.dishnetwork.com/SupportSection/setup-receiver-totv.Once we have made sure everything is connected properly, unplug receiver for 10seconds then plug it back in, this will reset the receiver. If we are still notgetting a picture connect another component (VCR, DVD Player, etc.) to the sameTV, using same cable, same input, and same channel to see if it works. If youget a picture with the other component give us a call at 1-800-333-DISH (3474)for some additional troubleshooting. If it doesn't work with the othercomponent then replace the cable that was used.
Phillip Chang
Jan 18, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Dish Network connection and surround sound
HI, connect audio output from tv to system,you may have to turn this on or turn up in tv menu for some sharp tvs,this should get sound for tv and dvd and anything else you hook up to tv.
Hope this helps.
CABLE GUY.
Mar 29, 2009 | Audio Players & Recorders
Connecting VCR to TV
Oh man dont shoot your stuff instead use your remote and go to your menu and select your input. You tv is looking at your coaxial input but you can select which input you want. 1, 2 front back whatever you need. channell 3 or 4 has nothing to do with connecting up your dvd if you connect and choose the front connection in your menu.
Oct 21, 2008 | Televison & Video
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
