Question about Axis 215 Ptz-E IP Camera
Help in wiring a Axis 215 PTZ-E .
Do i need a power adapter to power up this camera ? And what exactlly do i need. I have 3 wires BLUE < BROWN < and YELLOW-GREEN Thank you Janet
  • janet Diaz Dec 06, 2012
    the books says Alos that to connect the cable to a 100-240VAC, 1.2A, 50/60Hz power connector . Now what is that ?????
    Opps sorry I meant Axis manual says to connect the cable to a 100-240VAC, 1.2A, 50/60Hz power connector . Now what is that ?????
Replace camera on swann system
Yes it is not a complicated procedure, involves just disconnecting the power and video cables and remove the screws of the old cameras.
Jan 03, 2014 | SWANN Security Swa43-d1c2 - Swann Secu...
How do the wires hook up in a bosch\phillips ltc 0829
Dear Jesse Diaz,
please find below the link to installation guides that should help you with the problem:
http://resource.boschsecurity.com/documents/Installation_Guide_enUS_2263492107.pdf
http://resource.boschsecurity.com/documents/Installation_Guide_enUS_2263526411.pdf
http://resource.boschsecurity.com/documents/Installation_Guide_enUS_2250534027.pdf
Best regards
Andrea Goehler
on behalf of Bosch Security Systems
Sep 11, 2012 | Philips Bosch Ltc 0829/20 Autodome Color...
Spin out of control
Reset the power to the camera and test first.
If it worked before you may have a wiring fault... or if it is new or someone tampered with it, the baud rate settings or protocol setting might have changed.
Apr 03, 2012 | Pelco CONTROLLER MATRIX- PTZ CONTROL
Powered subwoofer keeps blowing its fuse
The amp is blown. You need to get it in for service. No telling exactlly what is wrong untill it is opened. 215-736-8055
Jan 15, 2010 | Onkyo Bass Reflex Powered Subwoofer...
I have a Pelco Spectra mini in a warehouse, we replaced the previous camera with this new one but the PTZ function does not work. The old camera worked for while and stopped. We moved the new one to...
Hi. Did you call Pelco's customer support? They should be able to talk you through troubleshooting the camera to at least determine if this is a defective camera or not.
Aug 18, 2009 | Cameras
I can't remove numbers that appears in screen when i use a Samsung PTZ camera. Can you help me?
sounds like you are seeing a display generated from the PTZ camera itself. can you access the camera's menu?
Jul 20, 2009 | Samsung SADT-100PM POLE MOUNT ADAPTER FOR...
No sound with USB and IPOD Apline IDA-X100
You connected your blue alpine wire (power antenna) to your blue wire (amplifier remote on) on the BMW harness adapter. You need to undo this, amputate your blue alpine wire (because your E36 has no power antenna) and connect the alpine blue wire with white stripe (remote power) to your blue wire on the harness adapter.
When you switch source from the radio, alpine is shutting off your amplifier through the connected power antenna wire. Since you're not listening to the radio anymore, it sees no reason why it should give it power.
Dec 27, 2008 | Alpine CDA-9851 CD Player
Installing a pelco ptz camera using my old controller
pelco cctv ptz doec not moving can you give me a solution?thanks a lot.
Aug 18, 2008 | Cameras
Axis 215 Ptz-E IP Camera Logo
27 people viewed this question
Top Axis Video Cameras Experts
Are you an Axis Video Camera Expert? Answer questions, earn points and help others
