Question about HP LaserJet 2420 Printer
How to set up an HP to a NW directly
I am trying to figure out how to set up my HP 2420 to my internal network directly. It has a NIC and I figure that if I plug in my network cable directly to the printer there is some way I can put the printer on the network but I am not sure how and don't have a manual for the printer.
    President:
  • 623 Answers
Yes, you can connect your printer to your network by plugging it into a hub, switch or router that is connected to your network.
The general HP site for your printer is here.
The Network manual is a little bit convoluted, but helpful. It is here.
You might have to re-install the printer software, which you'll find on the same page (first link). It is usually the biggest download you can find. Don't we all love HP...;-)
If you need any further assistance, please come back and I am happy to help.
Posted on Jan 12, 2009
  • HP Master
  • 4,338 Answers
Follow the steps on page 188 of the user guide.
set the IP address, Subnet Mask and Gateway via the front panel.
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00224567/c00224567.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
My computer beyond ISA server and also have note book, when cable wire not attach with router then my wire note book connect easily, when i put my cable connection in router, wireless indication light stop...
First of all, routers come with static ips... (the default is usually 192.168.1.1). So I am going to assume you mean your internet ip is a dynamic ip. Now Im not an ISA expert, so I may be wrong... but ISA should work with a dynamic external IP. And lastly if you cant get it to work, a quick call to your ISP will get you a static IP.
or
Try to configure the IP address of the external NIC in the same network as your router with the default gateway pointing to your router´s IP address.
In the internal NIC, configure the IP address of the internal network in the same subnet as your internal clients, set no default gateway and set an internal DNS.
In the internal network definition, you should put only the networks behind ISA trust interface.
Create access rules according to your needs.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 21, 2010 | D-Link DIR-300 Wireless Router
1. We make image of WS HP XW4600 with RHEL 5.1 - using clonezilla 2. Then we put this image on PC HP Compaq 6000 Pro Microtower 3. Everything is OK excluding network adapter - it doesn't work. 4. By...
You might plug in a USB wireless adapter or NIC. That might get you to the internet where you can download the needed drivers for the internal NIC. Or you can look in Device Manager, see what NIC is listed that needs drivers, download that driver set to another computer, then transfer the drivers to the Compaq. In Device Manager, add the drivers for the NIC, directing the search to the USB device where the drivers are located.
Oct 15, 2017 | Red Hat Enterprise Linux ES 3 Standard...
Can i connect my xbox to my laptop /w pc usb
Xbox Network Connection using Hub
This is the most common network configuration and is also the easiest to setup.
Step #1: Plug your network cable(RJ-45 cable) that comes from your cable/DSL modem into the uplink port of your hub. (Make sure that your uplink is switched to "on").
Step #2: Take an RJ-45 cable and run it from one of the ports of the hub, directly to the Network Interface Card (NIC) installed in your computer.
Step #3: Take another RJ-45 cable and run it from a different port of your hub directly to your xbox.
**NOTE** A switch may be used in place of a hub with the same basic setup.**
That's it! No other network changes should be needed for this configuration. Your Xbox is now on the same network as your PC.
Xbox Network Connection using Router
This is another common network configuration.
Step #1: Plug your network cable(RJ-45 cable) that comes from your modem into the WAN port of your router.
Step #2: Take an RJ-45 cable and run it from one of the ports of the router, directly to the Network Interface Card (NIC) installed in your computer.
Step #3: Take another RJ-45 cable and run it from a different port of your router directly to your xbox.
**NOTE** In steps #2 and #3, you should not use a port that is directly beside the "uplink" port on your router, if your uplink port is being used to connect to another routing device.** If your router has a built in firewall, you will need to forward ports 8602 both incoming and outgoing to the internal ip address of your pc. Consult your device manaul for port forwarding.
That's it! Your Xbox is now on the same network as your PC
Xbox Network Connection using Crossover Cable
This is the last network configuration. For this setup you need at least one NIC card.
Step #1: Plug your USB cable that comes from your modem into your PC's USB port. This should already be done, if you have a usb modem for your current internet connection.
Step #2: Take an RJ-45 cable and run it from an installed NIC card on your PC, directly to the Xbox.
**NOTE** A crossover cable is only needed if you are connecting the Xbox directly to the second NIC card. If you have a device such as a switch, hub or router in between you should use a standard RJ-45 cable. This type of network setup also requires "Winroute©", a program downloadable from the world wide web. Consult the manual for specific instructions on how to set this up. Also if you have a USB ethernet adapter, you may use any of the setups described herein. USB ethernet adapter basically converts a USB cable into an RJ-45 cable.
That's it! Your Xbox is now on the same network as your PC.
Aug 14, 2009 | Video Game Consoles & Games
EIO 1 ERROR
There's probably a problem with the card in the printer. It may need a firmware upgrade, you may need to adjust settings or even change the slot. The EIO 1 means it is now in slot 1. Here are some steps to try from the HP website:
Press (Select) to enter the MENUS.
Press (Down arrow) to highlight INFORMATION.
Press (Select) to select INFORMATION.
Press (Down arrow) to highlight PRINT CONFIGURATION.
Press (Select) to select PRINT CONFIGURATION
Check if the I/O card is on ready state.
Make sure that TCP/IP status is ready.
Check the network statistics for any bad packets or bad transmition.
Try to use another slot then the one that the JD is installed on.
If the problem persist,try performing a cold reset with the JD inside.Warning: This will reset the printer's configuration to the default settings,and also to the JD so you will need to set again the network values.
May 19, 2009 | HP LaserJet 2420 Printer
Media Disconnected (Windows Vista)
Your ISP is there to help you connect to the internet even supplying hardware to work with there network if they won't help try a different ISP when setting up a new account (DSL or cable) they will send a installer out and make sure you can connect. Good luck mysleuth
Apr 29, 2009 | Computers & Internet
We have an HP Laserjet 2420 PCL 5e - it prints perfectly on regular paper but will not print envelopes. We have to manually feed the envelopes on the tray but it only prints gibberish. I have rebooted the...
This is not a printer problem. You have a computer problem. In ALL cases, the printer is told what to do from the computer, it does not report TO the computer.
Mar 10, 2009 | HP LaserJet 2420 Printer
Double side printing issue with HP 2420
Try to default on your page setup.
May 23, 2008 | HP LaserJet 2420 Printer
Orange Livebox and NIC
Sounds like an internal problem with the Orange Livebox NIC controller.
If you have an other router Lynksys/belkin you could try it would isolate the problem definitively
Nov 26, 2007 | Powerline Ethernet Network Adapter
Not printing continously
Try a different network cable.
Feb 11, 2007 | HP LaserJet 2420 Printer
HP LaserJet 2420 Printer Logo
165 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
