5 lights on my chanderlia 1 has stopped working
  • 1 more comment
  • E Hill Dec 04, 2012
    a light fixture
  • SD Tech
    SD Tech Dec 04, 2012
    You may want to post a new question, from 50 years experience fixing my things: It has 5 bulbs and one is not working? You have swapped or replaced the bulb? If not the bulb you need to get in a position where with it removed you can look down into the socket to see if it is not making contact with the bottom of the bulb--a small metal tab if pushed down will prevent this---I since no one else has attempted to help am willing to assist you.This is very basic: look in a normal lamp if this one uses regular bulbs will use the threaded side for one connection and the bent tab at the bottom will stick up and touch the connection on the bottom of the bulb . These are called incandesent bulbs. Let me kinow what you can and I will try to help
  • E Hill Dec 06, 2012
    when there is no bulb in the socket . as I look into the in the socket there is a white round piece of material which the 2 wires are attached to and the wire then goes inside the arm of the light fitting. are 2 prongs which connect to the buld when it is inserted. it uses regular bulbs .
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
I have to ask a silly question, is this a TV set (where it is listed) or a light fixture of some type?
Posted on Dec 04, 2012
    a light fixture
  • E Hill Dec 05, 2012
    Thanks for your reply. there are 2 round sort of prongs inside the where you push the bulb into. the bulbs have 2 prongs which you push in and the bulbs contacts these. and you turn to the right into the lungs. it was fine untill we took the shades off to wash them. it has never been any trouble before. things are going wrong 1 after the other at the moment and we are in our late 70s and lost with it all.Thanks again
Brake lights are not working but my back window brake light works and so do my tail lights and turn signals. 01 chevy malibu
if rear window stop light works has blown globes in other 2 tail and stop are different circuts fit 2 new globes only go in 1 way
Sep 16, 2013 | 2001 Chevrolet Malibu
Mhu75ng stopped lighting after about a year. Fan starts, but burner doesn't light. Fan stops after about a minute. LED code is 3 flashes. Gas supply should be good, heater in another room ups
3 flashes could be the pressure switch ,jump it out see if it lights or clean the flame sensor or check the snap dice's 1 for high temp and 1 for low temp ..
Apr 12, 2013 | Mr. Heater MHU75NG
Sony Cybercam DSC-w120 stopped working completely for 1 week.
Contact SONY it should still be covered under warranty period
Jun 09, 2017 | Sony Cyber-shot DSC-W120 Digital Camera
Turn signals work,then out of the blue stop working.my hazards stop working. 1994 gmc 1/2 ton 4x4
check the fuse for the hazard light and turn light. also check the bulbs for all light make sure they are good
Jul 30, 2009 | 1995 GMC Sierra C1500
RIGHT STOP LIGHT WORKS IRREGULARLY(2002 FORD WINDSTAR)
thereis three switches to check one is the muti function switch. the second is the headlight switch and third is the brake switch on the pedal.if not them check your ground and see if it is secured properly
Mar 07, 2009 | 2000 Ford Windstar
2003 silverado 1500 v-6 brake lights dont work
ljones, Did you check the "VEH stop" fuse in the left side instrument panel fuse box. There are 3 stop light fuses, 1 for all the stop lights located in the under hood fuse box. 2 in the left side IP fuse box. 1 for the upper stop light and 1 for the lower stop lights. The fuse box in the IP is where the upper and lower stop lights split. Let me know.
Feb 26, 2009 | 2003 Chevrolet Silverado 1500
1969 ford mustang mach 1 brake / stop light switch challenge
Most tail light problems are a result of a bad ground......somewhere.
Sep 16, 2008 | 1966 Ford Mustang
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
