Question about Canon PowerShot S2 IS Digital Camera
Picture White Out
I was wondering if anyone has experience the same problem I get with my Canon Powershot S2 IS. When I take a picture on Automatic and out doors the picture is very bright or white washed. You can see the image but it just seems to bright. In doors not to bad and on TV settings and video all fine. It is only one half years old or there abouts and has only been used about a dozen times. Very light use. I have looked through all the settings and can find anything obviously wrong. Anybody got any suggestions?
  • Anonymous Mar 28, 2008
    Hello my S2 IS is good in video mode but its pictures resolution is bad and white line will appear when zoom in saved pictures and the outdoor pictures are too bright . Is it possible to solve my s2 is problem?
Your problem may be an easy fix. Assuming you don't know much about cameras, have you checked the ISO setting? For an outdoor photo the ISO needs to be at a lower level or the result is a white out.
Posted on Jun 04, 2008
My Canon S2 IS (3+ years old) has gradually
Take Canon offer or sell your as parts on Ebay. your camera can not be fixed with out great cost and you still have an a camera who's value is not that high.
Jul 01, 2009 | Canon PowerShot S2 IS Digital Camera
My Canon S2 IS works fine except the display will not provide picture viewing capability when I turn the camera on for picture taking. It will display photos from the memory card. The viewer is black for...
Your camera has the know issue of Stuck shutter, whichhappens after some time (weeks or months) thata camera is notused.
Unfortunately the repair of it requires a complete disassembly of the camera, including the lens, fix it, and then put back together everything.
Definitely requires th skills, tools and experience to do it, so it's recommended that a professional camera repair center is performing this type of repair.
If you look for a reliable and low cost repair service for it, you can look in ebay for such repair services.
Example, look for seller ID Great_items_2004 or with the keywords "Shutter black S2".
Best regards,
Jun 24, 2009 | Canon PowerShot S2 IS Digital Camera
"Canon powershot s2 is" not showing live picture
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 22, 2009 | Canon PowerShot S2 IS Digital Camera
White screen for all outdoor pictures
Sorry to say this sounds like a stuck open shutter mechanism. Put the camera in any mode other than auto and make certain that you turn the flash OFF (you don't want to blind yourself in the following step). Next look down the center of the lens barrel and take a picture. You should see a tiny flicker (wonder where that website got that name?) in the center of the lens as the shutter opens and closes. If no movement is seen then it's likely stuck.
Some people have had success in unsticking Canon S2 IS shutters with the following procedures. It may or may not work for you:
http://www.fixya.com/support/t295396-canon_s2_black_screen
May 09, 2009 | Canon PowerShot SD30 Digital Camera
Canon powershot camera won't shoot picture
Your problem is probably the same as mine, though my camera is a PowerShot S1 IS. That is very much the same symptom mine had, and doing some research online, I found out that some Canon cameras (there is a listing) came out with a defect in their CCD (main digital sensor), which presents this failure after some months of use. Canon will fix the problem free of charge, if you take it to a Canon Service Center.
Hope this helps.
Apr 14, 2009 | Canon PowerShot S2 IS Digital Camera
Canon S2 IS - LCD screen is white after taking an outside picture
the image is all white or has lines through it.Definitely sounds like a repair issue, and has been a previous problem with the camera in the past. There is a defect in the sensor of the camera, and happens quite frequently in this model. I would try and contact Canon about it, and see if they'll repair it for free. If not, its probably going to cost more than the camera is worth to repair it.
Mar 24, 2009 | Canon PowerShot S2 IS Digital Camera
Canon S2 IS problem blank viewfinder and LCD
some cameras have the choice to take the picture by looking through the veiwfinder or on the LCD screen. check in the menu and set it to LCD if you want to use the LCD
Mar 21, 2009 | Canon PowerShot S2 IS Digital Camera
Canon UXUS i pc 1060 pictures bleached white
I've got the same problem.
Happened just two months ago. I was outside taking pictures by a campfire, so I wonder if the smoke had something to do with it.
Movie mode is fine, but regular photos are either all white or with strange horizontal lines, not clear at all.
I'm going to open it up and reseat all the connections.
Anything else to try?
Anyone else have this problem or know what to do?
Aug 20, 2008 | Canon PowerShot SD10 / IXUS I Digital...
Canon Powershot Problem
Throw it at your driveway and see if that fixes it.
Jul 11, 2008 | Canon PowerShot S2 IS Digital Camera
Powershot S1 IS trouble shooting in images of lcd monitor
Try playing back pictures you know were captured properly ( either with another properly working camera or with your camera before the problem with quality has appeared ). If the image is ok in playback but 'noisy' in capture mode then the CCD sensor is faulty /on its way out. Ask Canon if they repair CCD faults on this model free of charge.
Aug 18, 2007 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
283 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
P.J. Ryan
P.J. Ryan
Level 1 Expert
Are you a Canon Camera Expert? Answer questions, earn points and help others
