Agitator on whirlpool washer makes lots of noise. No noise when it spins.
  • 45 Answers
In the agitator itself and there are ratchets that are called dogs. If you reach into the drum it will present itself because you be able to turn the agitator both directions, normally the agitator only turns freely in one direction. You can replace the dogs/ratchet by disassembling. If you take rinse dispenser off of the agitator you will see an insulator that you pull off and then you can see the dogs and a bolt that will allow you to take the agitator out.
Posted on Jan 12, 2009
I have a Whirlpool Gold washer (MOD# GSQ9669LW0). The washer makes a grinding noise below when in operation. Spins when agitating, but not in rinse mode. Water still pumps out in final spin.
This machine can get items stuck in the drum, the bearings can go bad etc. https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/38-5-620929-/Whirlpool-Washer-won-t-spin-GSQ9669LW0.
Oct 16, 2017 | Whirlpool Washing Machines
Know when clutch going bad
Needs agitator dogs in agitator.
Mar 13, 2014 | Whirlpool Washing Machines
Whirlpool washer WTW5510VQO will fill, spin and drian but won't agitate, just makes a clicking noise.
If this is just clicking then the agitator bearings stuck or something is jamming it.
Jun 05, 2012 | Whirlpool Washing Machines
I have a whirlpool ultimate care 2 washing machine commercial use. it its making a lot of noise I believe when spinning cycle changes as if the brakes are coming on noise gettting worse other than that...
here is one trick to do. put the timer on spin and pull out the timer knob. open the lid and use a screw driver to actuate the lid switch. then with your other hand hold the agitator until the tub gets to a high spin. once the unit is at a high spin then let go of the agitator. let the unit spin for another minute then lift up you screw driver. it should come to a gradual stop and not a sudden stop. let me konw if that works.
Oct 14, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Basket won't move-noise
do you notice if it agitates?
if it doesnt agitate it is just a simple coupling
if it is making a humm noise its the motor
if a LOUD rumble ONLY on spin cycle, its the basket drive assembly and the clutch.
May 29, 2009 | Whirlpool LSQ9610L Top Load Washer
Whirlpool washer agitates but makes a very loud noise
It sounds like the agitator teeth, that are plastic, are worn out. To check this, take the agitator cap off with a strong knife or flat-head screw driver, and check the circular teeth inside, to see if they are worn out. These plastic teeth are the agitator part of the washer, where as the spinning part is a metal set of teeth, at the bottom of the agitator. You see the metal teeth, when you take the agitator completely out. You will have to replace the agitator if the teeth are worn out.
Jan 11, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Noise when stopping after spin cycle or open lid (after moving)
check hub nut, it is likely loose, its under the agitator. top pops off agitator and bolt hold agitator down.
Jan 04, 2009 | Whirlpool Inglis IP4400 Washer
Washing machine noise
check the dogs in the agitater
Mar 25, 2008 | Whirlpool GSC9455 Top Load Washer
Open Questions:
Samsung Washer WT1101cw will not drain. Originally had a OE error. Running "Spin" or "Rinse Spin" cycles but pump cycles on for less than 1 second and goes into spin with water in it. _Laundry loaded with a OE error and water not draining. _I manually drained the system, took apart the drain and did not find a clog or anything to prevent the motor from turning. _Pump motor reads continuity. _Ran multiple SPIN cycles and then a RINSE and SPIN cycle and actually had the pump run for a few seconds and even for a minute or so one time but could not repeat and hasn't since. _checked the Pressure Switch and see continuity between common and outside contact. Tried to increase pressure by blowing into the tube using a straw on the end of tube but saw no change. Not sure how the pressure is created inside the bowl. _There was no overfill condition originally and I have not tried to run a normal cycle because the washer is in an upstairs location and draining is difficult and messy. ___I believe that something is preventing the voltage from being sent to the pump motor but I have am not sure what logic conditions need to be satisfied for this to happen.I keep looking at the pressure switch because the drum will perform a load sense and then go into a spin cycle with water in it which sloshes around. Questions: --Shouldn't the drain pump normally be running prior to the spin? --what causes the change in the pressure switch? Does the switch only change at a "full" level? Please only answer if you have a clear understanding of the system. I am trying to avoid excessive expense in this repair and swapping parts unnecessarily. I am beginning to think that it is the control board and do not want to spend hundreds of dollars if it is not. Thanks.
Apr 23, 2018 | Samsung Washing Machines
Washing Machines Logo
102 people viewed this question
Top Washing Machines Experts
