Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Unable to clean the surface of a GE Profile Gas Range
The surface of the range has burnt on residue that I am unable to scrub clean. I there a product that can be used to clean the surface?
  • GE Master
  • 5,568 Answers
Try on a small spot not too visible to put a drop of household ammonia and let it sit preferably cover with a cup or small bowl over night to see if the surface is dulled by it.
If not, drip some on the residue or soak a piece of scrap cloth or paper towel and cover that with a cup or bowl and let it sit for a day. It should soften the baked on residue.
If you run out to buy the ammonia, please remember that the stuff can be deadly for anyone but especially a child. Hide it well.
Posted on Jan 12, 2009
  • Steve Allison
    Steve Allison Jan 12, 2009
    Forgot to mention; an unused (they should ALL be) credit card won't damage hardly any surface if used to scrape at crud like that.
Ge profile gas oven grates rusted badly. just got new replacement grates. how can I avoid the same problem? thanks.
Be sure to clean the oven grates after using. You'll
find it effective to prolong it's useful life. But not with
water, just clean it free from residues and dirt.
Oct 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
My GE profile gas range keeps clicking all the time, this happens right after we have cleaned the gas range. And usually it goes away after a few hours. But this time around it refuses to go and it is very...
You are getting water into the range when cleaning causing the igniter switch to short out. The reason why it goes away after a few hours is because the water finally dries up. When cleaning the range refrain from using so much water. You will need to leave the range unplugged until the water dries up again.
Sep 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
How do I clean a GE gas range (self-cleaning oven?)
What do i clean the burners with ? the round surfers is harder to scrub, what do you advice .
Apr 20, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Discolored cook top
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Apr 10, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Gas Cooktop
Do you hear the spark ignitor trying got light the burner?
If not, then make sure there is not a residue or film of cleaning solution on the burner bases or burners themselves. It could be coincidental that the spark ignitor failed when she just happened to be cleaning the unit.
Jan 23, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Top of oven door is turning brown
DeBruce Polish will remove these problems on both stainless steel and enamel finishes. DeBruce Polish also works wonderfully on ceramic cook tops. DeBruce Polish is non-toxic, odor-less and non--abrasive, a true eco-friendly multi-surface cleaner. We get DeBruce Polish at debrucepolish.com.
Nov 22, 2008 | GE Profile 30" Self-Cleaning Freestanding...
GE Profile gas range
hello dreeden5
Ngafm at your service,
You have a GE Profile oven range. I and you just cleaned it and the pilot light on all four burners continues to click on and off.
It sounds like the gas line or the gas valve, have some debris in them!
They need to be evacuated by an experienced tech.
This time you need service.
Bless You ngafm
Please give me a good rating at this sight before you leave!
Thank You
Sep 10, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE PROFILE RANGE TOP
psnowden this can happen. If I remember correctly GE is using a Hi Temp paint, not porclean, on this range. And if they are using porclean, it is a thin coating. With current ranges the cooking oil gets into the finish and runs the heat up causing the finish to lift. The is espically true with white. The gentlest clean will in time not stop this from happening. You can get some hi temp touch up paint to make it look better, however it will keep doing this, espically on the burners you use the most.
Feb 03, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge profile gas range
  What do you mean by the surface burners coming on.  This is a gas range,  correct?  Do you mean that the flame comes on?  Or does the spark come on and they don't light?
  Does the oven come on?
Oct 18, 2007 | GE Profile Spectra JGBP85 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
87 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
