Question about Jl Audio 12W7 Car Subwoofer
I NEED TO TAKE OFF THE DUST COVER ON A JL W 7
2 Suggested Answers
hoohah
  • 21 Answers
SOURCE: dust cover came off of cone on a older JL W3.now
The dust cover does not need the flexibility needed at the outer edges of the cone. Clear nail polish often works well for dust covers.
Posted on Oct 30, 2009
How to replace front wheel bearing on 2003 kia sedona
Disassembly 1. Remove oil seal from front wheel hub. 2. Remove front wheel hub assembly with suitable tool.
bi6c021a.gif 3. Remove retaining ring. note_icon_eng.gif If the bearing inner race remains on wheel hub, grind a section of inner race until approximately 0.020 in (0.5 mm) remains. Remove race with a chisel.
bi6c021b.gif 4. Remove wheel bearing with suitable tool.
bi6c021c.gif note_icon_eng.gif Do not remove dust cover unless necessary. Do not reuse dust cover if removed. 5. Mark relative positions of dust cover and knuckle for proper reassembly. 6. Remove dust cover with a chisel.
ai2a023c.gif note_icon_eng.gif Do not remove wheel hub bolt unless necessary. Do not reuse wheel hub bolt if removed. 7. Remove wheel hub bolt with a press.
bi6c021d.gif Assembly 1. Press in new wheel studs. note_icon_eng.gif Front wheel hub press in either bolt turning or loosening by the torque of 108.5 lb•ft (147 N•m, 15 kg•m) shall not be premissible.
bi6c022a.gif 2. Mark new dust cover to match the removed dust cover. 3. Align mark on new dust cover with knuckle. 4. Install new dust cover with suitable tool.
bi6c022b.gif 5. Install new wheel bearing with suitable tool. 6. Install front wheel hub assembly with suitable tool.
bi6c022c.gif note_icon_eng.gif Use a new oil seal, and apply grease to seal. Install oil seal so that it is flush with knuckle. 7. Install new oil seal with SST(0K993 331 016).
Jan 12, 2013 | 2003 Kia Sedona
I need to wire two w 7 svc ten inch subs to a 1 ohm load
jl didnt make w7 svc but i will include a wiring schematic from jl for the w7......http://mobile.jlaudio.com/support_pages.php?page_id=145
Aug 26, 2010 | Jl Audio 12W3 Car Subwoofer
My cone on my JL W7 cone is cracked, How can I replace?
JL has good customer service, and usually you can get a drop-in replacement core/coil/former/spider. Call/e-mail the techsupport listed on their website, or contact your local dealer for replacement parts/service.
Jun 16, 2010 | Jl Audio 12W7 Car Subwoofer
One sub not working
Try this....the speaker that is not working, gently work the cone up and down with you fingers. Be careful not to go right thru the cone. One hand underneath(near webbing) and one hand on top over the dust cover. If you hear any kind of scratching, or noise, or it's not "breathing" freely, then the voice coil of that speaker may have overheated, or the speaker has extended above and beyond its range of movement (called excursion). And may as well be blown/dead/fried..however you want to say. I hope this is not the case for you.
Apr 26, 2010 | Jl Audio 10W6v2 Car Subwoofer
Dust cover came off of cone on a older JL W3.now it blows alot of air.
Oct 30, 2009 | Jl Audio 12W3 Car Subwoofer
Fixing the middle piece of the sub
Hello stoge52,
Many people do their own speaker repairs and it is many times perfectly satisfactory. The folks who do a lot of it are musicians who seem to bang their equipment around quite frequently.
The problem with your JL sounds like the dust cover and not the cone itself, so you are lucky in that respect. Repairing the cone is more involved and it's rather tricky to duplicate the thickness, rigidity, and original elasticity of the cone. It's usually best to simply replace the cone, a process called "reconing". But gluing the dust cover is perfectly acceptable and not much of a job at all. Don't try super glue. It won't work. I'm not sure about rubber cement, though, but I've never heard of anyone using it. Many pros use silicone sealant. Either black or clear looks best for speaker repair. A somewhat better product is a tennis shoe repair product called "Shoe Goo". It's a little lighter and remains more pliable than silicone sealant, making it a better choice for lighter speakers. You can usually find "Shoe Goo" at larger sporting goods stores. If you want to use something that is made especially for gluing speakers, here's a link to a product called "Prosound Loudspeaker Recone Adhesive" and is advertised as the same black adhesive as that used by many major speaker manufacturers. It's $19.99 for 8 fl oz, more expensive than silicone sealant. Is it better? I don't know. But if it were MY JL, I'd probably spring for it.
http://www.prosoundservice.com/m9_view_item.html?m9:item=PROSND-RECONEGLUE8OZ
You may want to gently remove the dust cover entirely from the speaker and make sure that there are not any tears in the cone itself. If there are, you should repair them first.
Also, when you reglue the dust cover, wait a MINIMUM of 24 hours for the glue/sealant to set up and cure properly. If you start the sub thumping before the glue has fully cured, you'll have the same problem again. One other thing, use just enough glue/sealant to do the job. Don't think that more is better. A consistent thin layer on the entire surfaces being joined is best. A gob here and there will not hold for very long.
The alternative is to send it out for repair. And since it is a JL, I would not send it anywhere but JL. Be advised that is not going to be cheap. And it's going to be time consuming. Probably at least 25-50% of the cost of a new sub and probably a minimum of 3-4 weeks, sometimes longer. And don't forget, you'll pay shipping both ways.
Hope this helps.
Apr 18, 2009 | Jl Audio 12W3 Car Subwoofer
I need to know how to remove super glue off of the speaker safely and what to use to adhere the cone (dust cap)to the speaker jl w0 10" thanks for your help!
fingernail polish remover with acetone works...or carefully with a razorblade. To glue it us something like rubber cement. You want something flexible
Jan 14, 2009 | Jl Audio 12W3 Car Subwoofer
Whats better
i would go with rockford cause they under rate alot of there stuff so it is actually better than what they say it is and audiobahn over rates there stuff so its wors than thay say w3v2 12's can be purchased at pro car sterio in roseburg oregon you can get them online @ jl audio.com for about $125.00 for the 12's and $110.00 for for 10's
Dec 02, 2008 | Jl Audio 12W3 Car Subwoofer
The surround on my JL Audio W7 is cracking. How can I fix it?
most replacement parts can be found on ebay such as the refoam kit for the w7 an the center dome cover.
Aug 07, 2008 | Jl Audio Car Audio & Video
Jl Audio 12W7 Car Subwoofer Logo
29 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
hoyzee1
Jamie Henning
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
