Question about Kitchen Ranges
Oven doesnt come up to temperature. - Kitchen Ranges
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 04, 2012
Riello 40 gasG900 burner that will ignite but when oven reaches temperature it turns off completely. After temp drops by 4 degrees it turns back on and reheats back to temp then turns off.Why is this?
that would be normal. if it didnt shut off, it would go above the set temperature. the heat is either off or on. it cant me in the middle. it turns 'off' so that the temperature doesnt go too far above 250. when it senses the temperature falling too low below 250, it heats it up again.
Sep 03, 2017 | Ovens
After using self clean yesterday the oven doesnt work today
the oven thermal fuse in the back of the oven is blown. it will work properly once that fuse has been replaced. it happens a lot when using self clean because of the high temperatures the oven reaches
Feb 05, 2011 | KitchenAid KGRT607 Gas Kitchen Range
My oven doesnt work.
What exactly isn't working? The oven doesn't heat up?
If you test the resistance of the elements, they should read about 20 ohms, the temperature sensor should as well. Generally these are the cause for an oven not heating. The temperature sensor is a small pencil sized rod in the back of the oven. You can access all by removing the back panel of the oven. Let me know what is exactly wrong if you want better help on your problem.
Benjamin
Dec 08, 2010 | Frigidaire FEF336BC Electric Kitchen Range
My oven light blew now my control panel on my stove doesnt light up but the burners work?
I have seen the control panel light fail while the temperature controller still operates. In many floor-standing stoves the control light is operated by a switch inside the temperature controller, so it can fail independently of the temperature control. The 'fix' is to replace the controller. The oven light blowing is more likely coincidental timing rather than being directly connected to the other fault.
Feb 28, 2010 | Kenmore Kitchen Ranges
My hotpoint ew61 double oven doesnt come up to
If it is heating, but not getting hot enough, then it is possible the thermostat is cutting the element off too soon, in this event, you will need to replace the thermostat.
If it is not heating at all , then the element is probably faulty.
Please rate my solution.
Thanks.
Nov 14, 2009 | Ovens
Rival to606 temperature control doesnt work, unit doesnt heat up
The heating bar or element needs replacement.you can find it in electrical shop or electronic and electrical supplies in your area.
If you find this answer helpful, kindly vote it.
Nov 09, 2009 | Rival TO606 1500 Watts Toaster Oven with...
Built in oven gets too hot
sounds like your thermostat is bad not sensing temp
Apr 19, 2008 | Ovens
Kitchen Ranges Logo
41 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
