Question about Uhu SAUNDERS CERVICAL HOMETRAC DELUXE
Slow air leak on saunders cervical hometrac unit
2 Suggested Answers
SOURCE: hometrac is causing more & a different kind of pain..Normal?
No this is not normal, when a person experiences this type of pain something is wrong. Angle might not be what it should, force might be to strong, straps might not be on correctly or too tight. Some with disc injuries may experience more pain with this type of treatment.
Posted on Dec 29, 2009
Dpac 10071What is the likely cause for the control panel to glow, but the unit to not operate?
The refrigerant has leaked out over time is the most likely. That woudl mean a slow leak in the unit.
Jul 02, 2014 | Danby DPAC10061 Air Conditioner
Air is not coming out as cold as last year on my Gulfstream Mako
Hello, this could be due to a low refrigerant charge. Sometimes the schreader valve core can leak where the gauges attach to the system, usually they are slow leaks. Also, make sure there is enough return air coming into the unit and that all returns are open and not blocked.
Jun 02, 2012 | Coleman Heating & Cooling
TV on off light flickering and TV does not come on
maybe theres a trouble in your television,becuase i have been experience that kind of truoble when im repairing,most of that symstoms are happening in LCD or LED TV..In LCD, mybe the filter CAPACITOR of the INVERTER BOARD(located at the back of your TV) which is responsible for lighting the flourecent lamp inside the lcd panel have been leaked already os that why happening,i better recomended to put the unit in the nearest cervice center or a skilled personel to check out your unit,,
Feb 15, 2012 | Televison & Video
A/C unit in attic is leaking a substantial amount of water
It can be a low refrigerant(freon) issue,dirty coils,too slow fan motor.
Jul 16, 2010 | Heating & Cooling
How can I order a part for Saunders Cervical Hometrac Deluxe?
I called the manufacturer and spoke with their repair department. The O-ring is in the mail...gratis.
Dec 01, 2009 | Uhu SAUNDERS CERVICAL HOMETRAC DELUXE
Machine works fine just doesn't blow cold air any more. Can it be recharged?
Why assume it needs refrigerant? How did it stop cooling? Suddenly? Or slowly over time. Typically a sudden failure tends to be an electrical issue - bad switch, bad thermostat, compressor or related component failure.
Whereas a slow degrading in performance typically tends to be a leak in the refrigerant circuit.
If it needs recharging don't forget that it has a leak - and the new refrigerant will also leak out unless the leak is repaired.
The problem with fixing these small units is that the repair costs can easily exceed the value of the unit.
Sep 25, 2009 | Royal Sovereign ARP-1000EX Portable Air...
Unit not blowing cold air
you have a slow leak in your refrigerant and need to find the leak. you will have to get an AC repairman to come to your house and check it for leaks and fix the problem.
Jul 28, 2009 | Amana Comfort Zone 12M32PBEH Air...
Hometrac is causing more & a different kind of pain..Normal?
Jun 14, 2009 | Uhu SAUNDERS CERVICAL HOMETRAC DELUXE
Not cold enough
An air con unit of any make should never need to be regassed if initially installed correctly. If it needs regassing, there must be a leak. You would have to find the leak and repair it before regassing, or it would be the same as pumping a tyre with a slow puncture. Generally most simplex systems use around 750 to 800grams.
May 09, 2009 | Heating & Cooling
Uhu SAUNDERS CERVICAL HOMETRAC DELUXE Logo
282 people viewed this question
Top Uhu Luggage & Travel Experts
Dave braun
Dave braun
Tom Chichester
ray gallant
Are you an Uhu Luggage and Travel Expert? Answer questions, earn points and help others
