Question about Health & Beauty
Back right wheel sticks when going forward BUT runs free backwards
All 4 wheels run freely when reversing BUT back right does NOT Turn when moving forward CAN U suggest what problem is & possible solution THANKS
  • 1,271 Answers
First of all look behind the wheel and axle, is there any been caught around it, I have seen this problem before and the fault was the transaxle problem, is the transaxle noisy ?
Regards
GeWiz.,
Posted on Dec 06, 2012
  • 39 Answers
SOURCE: Have Zoom 220 HMV 3 wheel scooter. Charged battery
It is possible the the battery could be damaged after being stored for that length of time. If it was wasn't completely charged before storage, or if it was exposed to extreme temperatures (even for a short amount of time) you may need to find a replacement battery. http://www.batteryinternational.com/electric-scooter-batteries.html should have the battery you need.
Posted on Jun 23, 2009
  • 32 Answers
SOURCE: moving problem
More than likely its the speed pod or engager (paddle assy. This would need to be replaced.
Posted on Jul 12, 2009
gewiz
  • 1271 Answers
SOURCE: batteries are fully charged but won't go forward
it should show 24v not 13,5volts, sounds like you only measuring one battery,
Check the fuse under the seat and check the reset button,
Could be a bad connection to the batteries or to motor check the B+, B- voltages, should show around 24v.
Regards
GeWiz.
Posted on Oct 07, 2009
  • 31 Answers
SOURCE: Pride Victory 3 electric motor will not engage the wheels.
no its definatly the kerosine mix in the fuel tank
Posted on Apr 19, 2010
  • 177 Answers
SOURCE: Wheels- knocking noise in the right wheel
Hi. If the knocking noise happens with each revolution of the wheel, it is probably the square key in the axle that drives the wheel. Remoce the wheel and wipe a light smear of grease on the axle and key where it fits inside the wheel. As the wheel normally rotates, the weight comes on to the key and off again, causing the noise. The grease allows it to move without making the noise. Sometimes also caused by a stone in the tread, but most likely to be a dry key.Good luck. Neil.
Posted on May 27, 2010
The right rear wheel intermittently locks up on my lawnmower when going forward stopping forward movement temporarily, until I move it backwards to "unlock" it. Any ideas?
There is an excellent 3 part video that may help you to fix this problem. Please see the 2nd and 3rd videos:
https://youtu.be/Vk_tpjKlbjM
https://youtu.be/DdiewLxTQDc
Things you can try:
(1) Remove casing over rear wheel drive assembly and perform a test run to assure all parts are moving as expected
(2) Lubricate the shafts with lightweight motor oil where the shaft penetrates into the gear box of each wheel
(3) Remove each rear wheel, inspect gears for damage and free movement. Grease up each drive gear and the shaft.
(4) Inspect gears on each wheel for damage.
(5) If none of the above fixes the problem, try swapping out the front wheels to the rear wheels provided the front wheels can accommodate the gearing on the rear wheels
(6) If this doesn't work try replacing the small gear assembly on the right rear wheel
These steps are illustrated in the videos.
Good luck and hope this helps.
Oct 11, 2016 | John Deere JA65 Self Propelled Mower
TGA Breeze S4. Why doesn't it freewheel?
hi George, if you took the brake apart , you reassembled that incorrectly as there should be a slight gap when moving the lever into free-wheel to allow the motor to move freely...Normal you put a plate the wrong way during reassembly ...a common mistake...
Now with the free wheel working correctly both wheels will move in the same direction when the brake is released either by powering forward or backwards or using the freewheel lever has released...what you described is a normal action ...because they can move independently...that's by design.. so strip the brake again and make sure plates and springs if fitted are the right way round...
Regards
Mar 01, 2016 | Health & Beauty
Lights run back and forth from red to green, no power
sounds like it might be in lock mode or the free-wheel is on. if i remember correctly to unlock push the joy stick forward and hold, turn on the power hold in forwared for about 10 seconds then release turn of and on and should be unlocked. if you are in free wheel push the scooter forward or backward if it is easy to move then the free wheel is on put it to off. and power on and you should be sorted.
Aug 15, 2013 | Health & Beauty
RIGHT BACK WHEEL DOES NOT TURN WHEN GOING FWD
what car???
Sometime the Emergency Brake Pads ( different then Disc brake pads) brealk off their mounts and will bind when moving forward
Dec 04, 2012 | Cars & Trucks
Swatch diaphane second hand stuck
Hello, a week ago the small second hand (not long chrono second hand) got stucked and my irony swatch just stop moving. Although the chronometer could be running if started... The small hand just didn't move.
I tried different tricks, like removing battery, pull out main wheel and use chrono buttons to reset arms. Etc.
Today I noticed that when turning the wheel backwards a couple of times (one or two hours back) the little hand moved one second back... Pushing wheel back to On possition made the small hand move forward one second and get stucked again.
Then I did this procedure a couple of times, at some point I turned the wheel back for a while (may be 5 full turns) and noticed the small hand moved more than one second (5, 10, 15 seconds backward)... when I noticed it was moving freely I pushed wheel to on position and noticed the small second hand was running normal.. I hope it works for some of you. Greettings from Canada
Nov 06, 2012 | Swatch Diaphane Chronograph Blooded Silver...
The back wheel was removed for repair and now tractor won't go into gear.
when you installed the rear wheel did you install the square key back on the axle?
May 15, 2012 | Garden
Cadet LT 2042 worked fine changed hydro filter by lifting front with hoist to vertical. Lowered and topped off fluid. Now wont go forward or reverse. Makes no noise when pedal is engaged to move either...
You will have air in the system and will need purged. To do that you jack up the wheels to where they will turn freely then disengage the hydro and at an idle alternate forward and reverse for a for about 4 or 5 minutes. Recheck the fluid level and top off. Now engage the hydro and do the same forward and reverse for 3 or 4 minutes. You should have axle movement at this point. Hope this will help.
May 20, 2017 | Cub Cadet Street Sign- tractor lawn riding...
Son's can pedal 12" bike
Yes, something isn't turning freely. It's either the front wheel, the back wheel, or the pedals and chain. Lift the bike off the ground and turn the front wheel by hand. If it doesn't turn very freely, it could be the hand-brake is dragging or the hub bearing is too tight. Try the back wheel in both directions. It should move freely in the forward direction. When rolling it backwards it is normal for the pedals to move too if this bike has a coaster brake (that is the kind of brake that is applied by pushing the pedals backwards.) It the back wheel moves forward freely, but backwards is a problem, then try the pedals by hand with the rear wheel off the ground. If this doesn't turn freely, the pedal crank bearing (a.k.a. bottom bracket) is too tight. Once you have identified the problem take it back to where you got it. It should be easy to fix, or they should replace it.
Jul 28, 2010 | Huffy Cars Lightning McQueen 16 Boys'...
1993 camry le 6cly will not roll backwards. can jack up all wheels and all free. car will move forward bur locks up as in park when reversing.bye the way the service brakes and the hand brake are free.it...
It sounds like a problem with the reverse gear and you're probably going to have to have a transmission shop look at it,I'm assuming it locks when it's running and you shift into reverse.
Jun 22, 2009 | 1993 Toyota Camry V6
Hydrostatic mower goes in reverse but not forward. Only 73 hrs on it!
On my hydrostatic there is an adjustment on the forward/back lever which can be made to run all reverse or all forward. Normal setting gives both of course. Look at that adjustment. Maybe something let go.
Oct 14, 2008 | Garden
Health & Beauty Logo
56 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
