Question about Dell 2335dn Multifunction Printer
HOW DO I FIX A DELL 2335DN PRINTER LSU MOTOR ERROR
4 Suggested Answers
The Machine
  • 788 Answers
SOURCE: LSU ERROR shows in display panel
The LSU is the Laser Scanning Unit or "printhead". There is a mirror in there that spins really fast, if the mirror spins too slowly (bad motor, low voltage) it gives an error. Sounds like you would need a replacement LSU. Have the printer serviced.
Posted on Jan 14, 2008
StevenC82
  • 160 Answers
SOURCE: I have a Dell 2335dn,
Make sure the fuser is seated correctly and cycle the power (turn the machine off and back on). If the error continues try replacing the fuser (part# KW449). Iteminc has this in stock and ships same day. Here is a video that shows you how to replace it. Good luck, and thanks for using FixYa!
Posted on Aug 22, 2011
pradeep_loke
  • 69 Answers
SOURCE: I want dell 2335dn lsu unit to buy .im from Ghana west Africa
Hi Emmanuel,
My name is Pradeep and I work for Dell's Social Media Team.
Thank you for your interest in our printers. Please contact our authorised partners using the link: http://lt.dell.com/lt/lt.aspx?CID=285905&LID=5550776&DGC=SM&DGSeg=DHS&RED=301&DURL=http://www.dell.com/learn/ed/en/eddhs1/campaigns/index-ed-en for assistance.
Pradeep Lokesh
Social Media and Community Professional
Order Status: http://del.ly/61822hij
Download Drivers: http://del.ly/61832hid
Posted on Jul 06, 2015
Hi Emmanuel,
Pradeep Lokesh
Jul 05, 2015 | Dell Office Equipment & Supplies
Call service Code 4600 KYOCERA FS 8520 MFP
LSU cleaning motor error
When the LSU cleaning motor
is driven, an error signal is
detected continuously for 1 s.
Defective connector
cable or poor
contact in the connector.
Reinsert the connector. Also check for continuity
of the connector cable. If none, replace
the cable.
May 17, 2014 | Kyocera FS-C5030N Led Printer
How do I replace cassete pickup roller for Dell 2335dn?
David Wangaard,
You can click the link below to download the online manual. The manual provides information on replacing parts in your printer.
Dell 2335dn Printer Manual
http://dell.to/1nIznNt
Thank You,
Dell-Jesse L
Apr 28, 2014 | Dell 2335dn Multifunction Printer
My printer is samsung scx4300 so error massege lsu error
This is Laser Scanner Unit error and this is probably cause if the polygon motor in the LSU does not rotate.The LSU's laser beam is functioning properly.You can try unplugging the machine for 3 minutes and plugging back in before you do anything else.If this does not fix it you will need to have it serviced by samsung.
Apr 26, 2011 | Samsung SCX-4300 Monochrome Laser...
The printer shows LSU error, When i Turn it of after 2 or more hour I can print max 3 copies and then the same error appier (LSU error).
Hello my friend this is Laser Scanner Unit error and this is probably cause if the polygon motor in the LSU does not rotate.The LSU’s laser beam is
functioning properly.You can try unplugging the machine for 3 minutes and plugging back in before you do anything else.If this does not fix it you will need to have it serviced.
Feb 03, 2010 | Samsung Office Equipment & Supplies
MY samsung scx-4521F LSU ERROR. HOW TO RESET THE PROBLEM
No reset will work, it is detecting the Laser Scanner Unit is not operating correctly and it is a replacement unit (LSU).. the lsu is a high speed motor with a many sided mirror attached spinning at very high speed (you can hear the whine in lasers of the spin), the motors wear out and cant spin fast enough yo spread the light and need to be replaced... then your error will clear
Nov 07, 2009 | Office Equipment & Supplies
Have lsu error also.
Hi ...
LSU stands for Laser Scanner Unit ... you normally get 2 different kind of errors with LSU ...
LSU Hsync or LSU Motor Error ...
If you get this error, it means that the Laser Scanner Unit has gone bad and the only way to get it fixed is to get the printer repaired ...
Cheers ....
Jul 28, 2009 | Samsung SCX-4100 All-In-One Laser Printer
Fuser error
Hey, if your Dell 2335DN has a fuser error or low heat error first try cycling the power (powering off and back on the machine). If this doesn't fix it, you should replace the fuser (part# KW449). Here is a video showing how to replace it and where you can purchase one. Good luck!">
Apr 07, 2009 | Dell 1600n All-In-One Laser Printer
Jan 02, 2008 | Dell 1600n All-In-One Laser Printer
Dell 2335dn Multifunction Printer Logo
308 people viewed this question
Top Dell Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Dell Radio Communication Expert? Answer questions, earn points and help others
