Error code E16 on hoover washing machine
I have fitted a new pump for the waste
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
E16 = Open circuit on the heating element.
Posted on Dec 04, 2012
BIKER T
  • 909 Answers
SOURCE: Hoover oph714d - error code e16. What does it mean
Where in the program is this happening?
Posted on Sep 20, 2009
FitzOriginal
  • 842 Answers
SOURCE: hoover washing machine Mod OPH 714D Error E16 in
After far more research than I usually have to do, It seems that E16 means "O/C Heater"
Which means that the heating element is open curcuit. Which menas......
Either the heater element has a wire off at the back, or more likely the heater element is burned out.
They are easy to replace. Pull the machine out and remove the rear inspection plate at the bottom of the body (I think this machine has one!, sorry if it doesn't).
At the bottom of the drum, you will see a atainless steel cover, about 4 inches limg and a third of an inch wide, with rounded ends. There will be 2 spade connectors with wires in them (1 either end of the plate) and a 10mm nut in the centre. The nut tightens up a squeeze plate inside that crushes up a rubber seal to hold it in place. Undo the nut fully (you may have to push the little stud bolt that is now exposed in a little to free it off) The element should now withdraw if you grab hold of the spade connectors and tug a little to break the seal before you withdraw it.
Replacement should be the reverse of removal.
Google "Hoover washing machine heating element" to find yourself one on line, or ho to your local Hoover parts stockist
Posted on Jun 30, 2011
Testimonial: "thanks for your help great, having more problems now so it has to go!"
SOURCE: error code e04 on hoover washing machine
called hoover and they replaced the washing machine
Posted on Jul 28, 2008
SOURCE: Hoover Vision 1600 AAA Washing Machine error code 5
High summerzaman,
the error mean an problem by the temperatur sensor of the water. It is possible an defect of the sensor or cable between the sensor and the microcontroller or the controller self.
with regard Andreas
Posted on May 07, 2008
  • 193 Answers
SOURCE: error code E03 on washing machine
eo3 water not draining,check for kinked drain hose,check that drain filter is clean
Posted on Sep 28, 2009
Hoover washing machine error code16 has come on
Hi!
Baically, Hoover washing machine error code E16 means that there are problems with the insulation of the heater. this may lead to the shutdown of the circuit breaker and other random errors, but this is difficult to prove without replacing the heating element.
Apr 27, 2017 | Hoover Washing Machines
Washing machine stuck on e16 error need to get washing out please help can't it won't unlock
The only way is to disconnect from power if the door does not open within the specified time then you need to open the top of washing machine and get access to the electronic switch then tak it off do this without power this will open the door and if can test the swich if faulty you can get replacement from washing machine spares on internet google it hope this helps
Mar 05, 2016 | Hoover Washing Machines
I have a hoover silver pulse inverter e03 came up on the display then changed to e16, what do I need to do?
Hoover dyn8144 and related machines
Error code 03 followed sometimes by Error code 16
Check the usual drain pump and resistance of heating element
On my machine I've discovered that on the motor if the brushes are not bedded onto the commutator it will cause the above codes to display and stop the machine.
The problem is not related to the drain pump or heating element so the codes displayed are not correct. If the brushes are not bedded to the commutator the motor cannot get to spin speed but will happily wash away. Watch the machine during a quick wash to ensure it does actually spin
Jul 10, 2015 | Hoover Washing Machines
What does e16 mean please?
An E16 error code means there is a heater insulation problem which could cause the tripping of your fuse box and other random cycle errors, but it's hard to prove without the replacement of your heater.
For more information on other error codes , watch this video .
http://www.espares.co.uk/advice/0/2531/how-to-understand-hoover-and-candy-washing-machine-error-codes
May 15, 2015 | Hoover Washing Machines
Wot is e16 mean
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3450-hoover-optima-fault-codes-carbon-brush-motor.html
looking here i see that error 16
tells us that the heating element has gone bad and needs replaced
or the wiring is bad
could just be a loose plug on the htc/ temp regulator
you can check it but its pretty clear by the error
so look to hoover spares ebay etc espares etc for the cheepest if you feel like replacing it yourself
Dec 09, 2014 | Hoover DYN8163D8X White 600 mm Washer...
Eo3 error message hoover washing machine
Unplug machine for 2 hours to reset the board electronics and re-plugin to load fresh computer code onto board.
Oct 15, 2013 | Hoover Washing Machines
What is error code 16
If it is an Optima with a brushless motor (I only have those fault codes for Hoover), 'E16' means 'water heater element insulation fault'. Sorry ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 31, 2011 | Hoover Washing Machines
Washing Machines Logo
1,537 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
