Question about Kitchen Ranges
The knobs on my electric range will not turn and a screw even fell out of one. I only have 2 functioning burners now
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the complete model number of the unit?
Posted on Dec 04, 2012
the dr
  • 447 Answers
SOURCE: problem with electric range
Most likely the switch has welded closed
Posted on Sep 28, 2007
fridgetech
  • 473 Answers
SOURCE: burner will not turn off
I will need the complete model #. There should be a sticker near the bottom front behind the drawer. Can't use the # that is on the owners manual.
Posted on Oct 09, 2007
fridgetech
  • 473 Answers
SOURCE: General Electric electric range
Give me the complete model # from the sticker on the oven so I can look into this for you.
Posted on Nov 11, 2007
freetek
  • 5568 Answers
SOURCE: Electric spark for gas range burner is non stop
Turning any knob starts the spark via a switch behind each which should disengage when the (any) knob is turn further.
One of your switches is stuck.
I think you should be able to remove the range-top for access and find the offending switch.
It is probably gummy from a spill and is no longer in solid contact with the cam that operates it.
A solvent/lubricant such as WD-40 sprayed on the plunger of the switch once you can see it and operating the knob back and forth should free it up.
It might be wise to turn off the gas supply while tinkering with the range - blow your house away and the range won't matter. :-(
Posted on Jun 19, 2008
SOURCE: Range burner will not turn off, the knob is tight and stuck
Not knowing age - very often older (standing pilot) ranges will have burner valves that become hard to operate. These are usually a tapered core valve that can be greased with a high temperature valve grease.
Posted on Jan 28, 2009
When the power is turned on at the wall, the automatic spark that lights the gas top comes on on the two right burners, and wont stop even after the light is lit. What can I do about it?
Behind the knobs for the right burners are 2 electrical switches that start the spark when you turn the knobs on. One of those switches is bad and stuck in the on position. You have to pull the knobs off and remove the trim behind the knobs to get to the switches.
Mar 22, 2015 | Lofra Kitchen Ranges
Have a wolf range and the spark generator which lights the burners will not stop clicking even when i turn the stove off. if I turn on the middle back burner it will stop clicking. how do i stop this?
Remove the knobs and skirts and a few screws. Remove the panel and locate the spark switch that is bad by removing one wire at a time till the ticking stops. dfc80e7.jpg
Jul 16, 2010 | Wolf Range CHR-2-1829-FT45 Gas Kitchen...
I have a gas range and I think the burners are turned too high, I can boil my food when I have the knobs turned to low. I would like to know how I can lower the flame. I pulled out the knobs and thought...
ther should be 2 sets of brass nozzles for the burners, make sure that the correct ones are installed, ie natural gas or propane. they have a different injector size for each.
Dec 01, 2009 | Maytag MGR5875QDS Stainless Steel Dual...
Front large burner on the right overheats. Have cleaned connectors. Socket seems to be OK as well. Control for this burner may have problem, but don't know what to look for beyond the outer nob itself. My...
you need to replace youburner switch, it is failing. There is a mechanism inside this kind of switch which turns power on and off to the element, thus regulating its output. The mechanism is stuck closed, so your switch does not regulate the output, When you turn the burner on, it's on "High" no matter the knob position.
You can order the original switch here: 3148954 (use coupon code "New10" for 10% off).
To replace the switch: Unplug the range. Remove back cover of the control panel (usually an unpainted piece of sheet metal). Remove the knob in the front. Remove 2 screws holding the switch. Now disconnet wires one by one from the old switch and connect to the new one. Even if the switch looks exactly the same, make sure to match LETTERS on the switch (usually P,L1,L2,H1,H2,), not the connector position!
Good luck! ;)
Oct 15, 2009 | Whirlpool RF365 Electric Kitchen Range
How to replace spark igniter - Jenn-Air SEG196 gas-electric range
took off the knob to the ignition system to clean and spray got onto the ignition under the dial and now the two front burners won't ignite unless I turn on one of the functional back burners then turn on the front burner. How do I repair this?
Jan 22, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Burner on range will not turn off
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
Apr 07, 2008 | LG LRE30755 Electric Kitchen Range
Jenn air pro range 36" prg3610np
hi after the burner ignites turn knob until it stops trying to ignite thanks
Jan 07, 2008 | Jenn-Air PRG3010 (NP) Gas Kitchen Range
All the Burners click when I just turn on 1 knob
The manual tells you this will happen. Just adjust the flame for your intended use and start cooking
Dec 01, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Burner will not turn off
Oct 08, 2007 | GE Spectra JBP78 Electric Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
