Question about Cameras
Sony DSC-WX100 I have a flash error E:91:01 on my WX100. I have tried to initilize the camera but the fault remains. I have found a replacement flash board from a working camera but the service manual says I should clear the flash error before installing the new board?
3 Suggested Answers
SOURCE: Flash not working on Sony CyberShot DSC-P93A digital camera
The flash on my Moultrie gameSpy 4.0 (D40) quit working. I can trigger the camera and see the flash is very week. Batteries are 100%. Can the flash be ordered and replaced?
Posted on Nov 30, 2008
pauman
  • 248 Answers
SOURCE: error message E 91 01
flash error for sony cybershot dscw55 ERROR CODE E:91:01 1st go to SETUP MENU then select the toolbox icon 1 then select "INITIALIZE" press ok, master reset then it goes back to normal
(DOWNLOAD & SAVE PICTURES BEFORE MASTER RESET AND KNOW THAT YOU WILL HAVE TO SET UP TIME&DATE)
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
Posted on Jul 06, 2009
How do I change language from Japanese to English?
sir,
It is very easy to change the language in such models, put the camera in setting menu and it will show the language option, if it has option for English, if it is a dedicated Japanese version you will not get language options in that type.
Oct 09, 2015 | Sony Cyber-shot Dsc-wx100 18.2-megapixel...
I am looking for a download manual for Cybershot DSC-WX100
there is nothing called a manual bt u can find useful content in net.just search in google./
Dec 12, 2012 | Sony CyberShot DSC-WX100 Digital Camera -...
I have a Sony DSC-T1 and it is displaying a flashing error message E61:10. . The screen is blurry and I can't do anything! It had the CCD chip replaced by Sony free of charge previously - is this the same...
In DSCT1 Camera, the E:61:10 error message indicates a Self diagnostic message. This message can be clearly identified by the help of a Sony Authorized service technician. Each of these codes indicates the symptoms and resolutions of the Camera. The E error code indicates the internal hardware malfunction with the Camera. This issue is not related to the CCD Image Sensor replacement.
Try the steps given below to check if the issue can be resolved.
· Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
Also, try resetting the Camera back to factory default by pressing the RESET button using a sharp-pointed object. The RESET button is located at the lower right side of the control buttons.
Please make sure that the Camera is turned ON before you reset it.
Good Luck!!
Nov 09, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
I have a Sony Cybershot DSC-W55 and when I go to take a picture with the flash on, it doesn't work and I get this error that says E:91:01. It also makes this quiet ticking noise when it's on. I reset...
The immediate solution is that your flash unit within or the triggger or control circuit to the flsh is fault.
now since thisis within and just opening wont solve issues, it is advice able that you have the camera checked for errors, to estimate for the fault .
This might save time and energy.
Sep 29, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Camera is flashing "E:91:01" ON THE SCREEN. WHY?
The flash fuse on the main board or flash board is bad. Contact your local Sony service center for repair as this is possibly a short circuit problem but first try this......
I found a forum that talks about your error. Here is a quote from the forum:
TO SOLVE FLASH ERROR sony cybershot ERROR CODE E:91:01 , JUST GO TO SETUP MENU, SELECT THE TOOLBOX ICON 1 AND SELECT """"INITIALIZE"""" CLICK OK, MASTER RESET AND IT GOES BACK TO NORMAL.
please rate my help++++Thanks for using FIXYA
Nov 20, 2009 | Sony Cyber-shot DSC-W200 Digital Camera
DSC W55 Error code E:91:01
Hi,  Its an error of flash unit(E:91:01 denots flash unit problem) which get started malfunctioning. Therefore you have to replace the FLASH UNIT ASSY.
  For changing of flash unit assy. You can contact any sony service centre nearby to you. For your convenience please visit:
www.sony.net
or
www.sonyworld.com
Here you can find contact info of nearest service centres.
Thanks for using FIXYA.
Jan 28, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
SONY DSC-S600
If you are able to access the MENU option, then try to initilize the camera by following the steps mentioned below:
Please press MENU to display the menu items.
Please go to the SETUP menu and select the SETUP 1 option of the Camera.
You would see the intialize option.
Thanks
Aug 24, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Sony DSC P52 won't flash Error Code is E:91:01 tried reset already
When you pressed the reset, if it cleared the time and date that button is working. If that did not clear the error it is a hardware fault, meaning that a circuit has failed and parts will have to be replaced.
A local camera store might be able to find the problem but you will have to carefully weigh whether these older camera is worth the cost of repair.
Sorry! I hate giving bad news.
Oct 24, 2007 | Sony Cyber-Shot DSC-P52 Digital Camera
Cameras Logo
220 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
