Question about Dell Inspiron 1545 Notebook
1545 wont boot, seems loop
Dell has blue screen, but says updates loaded wrong, , been 2 days just looping
  • Dell Master
  • 27,725 Answers
Check to see if there are any keys stuck/depressed.
If so, use a paperclip and fit it underneath the key and gently pry the end that is stuck.
Make sure the laptop is off before attempting this.
Observe where the boot process ends and starts over.
In most cases, this will give an indication where the problem occurs.
If the laptop reboots early on in the process, for example when it is detecting the hard drive, chances are good it is a hardware issue.
If the reboot occurs further along in the process, like when it is loading operating system files, there may be an issue with operating system software.
Test all power and data leads that attach to your hard drive SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty
Make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty.
even something as small as faulty fan lead can cause you problems
computers need all of the data and power to travel through every working device and to have an end for a computer to be able work properly.
Motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all power and data leads make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
Check your computer ram modules for secure dust free seating you might even remove the ram modules to check for dirt on modules and in the module socket and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in
If your computer runs long enough scroll to bottom toolbar (bottom of screen) right click select task manager
applications you will see whats running
if you see anything you dont need running select end now and you might uninstall that specific
program if you or computer does not require it to run and
some unnecessary programs that could be running your computer over its limits causing memory dumps
also under processes see what is ticking over in the background you might have a virus again if you see something you
dont need to be and users you will see who is using your computer
You might need to add more computer ram
if you're not sure if a module is right for your system use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line
from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
You should always ask for a guarantee on the compatibility of the ram before making any purchase
Might be getting hot
check you CPU make sure its securely seated and has thermal grease
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Hope this helps.
Posted on Dec 04, 2012
knotbeerdan
  • 413 Answers
SOURCE: Update Dell Vostro 1000 BIOS now wont turn on, nothing on display
Hopefully you can find something helpful on this site. Basically you need to flash or reset your bios now. this site also has some links to remove upgrades. LIke i said i hope this helps.
http://www.user-guides.co.uk/Dell/DellManuals/Dell.asp?keywords=Dell+Vostro+Manual&recor=1
Posted on Dec 29, 2008
pontelemon
  • 531 Answers
SOURCE: Dell Inspiron 6400
Loks like the Video Card is defective.
Posted on Apr 18, 2009
  • 226 Answers
SOURCE: Boots to a grey screen
try to reinstall windows
Posted on Jul 20, 2009
  • 37 Answers
SOURCE: Need to update Network controller driver on Inspiron 1545
If you can't find it on the network card manufacturer's website, then try www.driverguide.com.
Posted on Nov 12, 2009
SOURCE: Dell Studio 1537 will not
Having same problem but less tech savvy than u. Any solution found?
Posted on May 04, 2011
Xp booting loop bios
Seems to be a bad driver or damaged boot.
If the computer shuts down and restarts check CPU fan and blow dust out from heat sink, CPU may be overheating.
Otherwise, use the recovery disk to repair, or the installation CD and do the system repair. Or from repair disk, if your computer worked fine before, Restore To a Previous setting.
Jul 16, 2013 | HP Pavilion a1410n (ER890AA) PC Desktop
Toshiba satelite a105 keeps looping in the boot menu
No blue screen or number, it use to work find, this problem start last week
Jul 05, 2017 | Toshiba Satellite A105-S1712 Notebook
Acer aspire 5734z will not boot
You need to restore your system. what os are you running? Windows7, xp, vista??
Dec 22, 2012 | Computers & Internet
When i start my laptop it shows the dell loading screen then goes to a black screen where you can start windows normaly or go into safe mode. when you click on start windows normaly it goes to the windows...
You may need to reload windows on the hard drive. However try this first: reboot the system. Tap F8 to get to the system menu. Go to Safe mode and see if windows will load from there. If it does- try System restore to a point before the looping issue started. If it still loops, tap F12 at the Dell screen, and select the image to restore the system (reload to factory default). If you do not have that option, you will need the install media that came with your Laptop to reinstall the operating system entirely. If you do not have the drivers disk for your system- you will need to go to Support.Dell.com, enter in the service tag of your system, and download the drivers for your system.
Good luck! Also, as a reminder: Use your burner or an external hard-drive to backup your college work. Nothing makes you hate life more than having to retype a 20page paper from your edited rough draft and outline due to a system crash or virus! (personal experience. History paper.)
Oct 08, 2010 | Computers & Internet
My pc will not load windows and I only get blue screen and dell home page. Computer will not repair as it keeps looping back to same page. I tried booting from install disk with same result.
When you say you tried booting from the install disk, what do you mean?
Do you ever see anything but the Dell image?
When you try to start up, press f12 for boot options and choose the diagnostics option and run it.
Apr 07, 2010 | Dell Computers & Internet
Starting up loop that never ends.
Try booting in safe mode (F8 just before the Windows screen) and do a virus check.
Stelios.
Feb 21, 2010 | Dell Inspiron E1505 Notebook
My dell pc wont reboot. keeps looping back to ''welcome'' screen.
reboot in safe mode hold f8 key while booting. then go back and restore your session before installation. then reboot
Dec 27, 2008 | Dell Dimension 3000 PC Desktop
Dell Inspiron 1545 Notebook Logo
32 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
