Question about Toshiba HDR5010KB Digital Recorder
Toshiba hdr5010 not responding to commands
Appears to be frozen boots up but when commanded via the remote the blue ring returns to red
  • 1694 Answers
SOURCE: Toshiba 57H82 does not except commands from remote
Toshiba part # 23000852 remote receiver LED located behind
screen frame assembly.....Remove speaker grill...then remove
screen assembly....locate small PC board near RGB CRT's...
Replace soldered in part on board....re-assemble...........T.
Posted on Jan 24, 2008
SOURCE: Toshiba SD-3980
http://www.tacp.toshiba.com/tacpassets-images/notices/sd-3980_sd-k750.asp
read that
Posted on Mar 23, 2008
  • 21 Answers
SOURCE: Toshiba 310CDT / Name the Command Interpreter !!
If you " \ " not work, type type ALT + 0 9 5 on keypad.
095 is ASCII code for " \ "
Posted on Nov 07, 2008
  • 225 Answers
SOURCE: Sony MW24FM1 either won't respond to DVD commands, or turn-off
Sounds like a bad power board. They have random meltdowns all too often. Usually the cause is an overheated transformer caused by power transistor short outs. Possibly sell it. Could get over $100 for it if sold online.
Posted on Nov 14, 2008
paul7of9
  • 1189 Answers
SOURCE: Toshiba system restore help please awhyaah?
  • Hi, these are instruction to perform the System Restore; follow them carefully! You will need Disks (CD or DVD); only if you needed to Backup System Files, before restoring the system; in which you may be (prompt) to do so. So have available beforehand, at least 7ea, of (DVD-R), or (DVD+R), or (DVD+RW) @ 4.7 GB ready! *Note: It is important to make, Recovery Disks for the Computer as well, in the event of system failure! *System Restore: 1. Go, to: Control Panel 2. Click, on: System and Maintenance 3. Click, on: Backup and Restore Center 4. In the (left) Tasks area, click on Repair Windows using System Restore 5. Windows may take up to 5Mins, to Setup a Restore Point; be patience! 6. The restore Wizard 7. Use (Recommended) Restore Point. Be patience! your Computer will Shutdown, and Restart. *Note: Once the computer returns to Windows Desktop, do not perform any tasks, for at least (45 min) the System Restore is still running! *Conclusion: "Message successfully restored, or failed to complete restore? Follow “prompt message,” for further recommendations." "Helpful Ratings Feedback is appreciated,thanks paul7of9”
Posted on May 31, 2010
My deepfreeze didn't show in my taskbar how i can disable it?
I understand that you would like to disable the deepfreeze software installed on the computer.
One or more methods can be employed to enable/disable (Freeze/Thaw) Deep Freeze depending on the version being used.
A) Locally at the workstation (Deep Freeze Standard and Enterprise):
The following steps can be used to disable (Thaw) Deep Freeze:
  1. Hold down the SHIFT key and double-click the Deep Freeze icon. Alternatively, you can press CTRL+ALT+SHIFT+F6. A Password dialog is displayed.
  2. Enter your password and click OK. If you have not yet entered a password you should be able to click OK without entering a password. The Boot Options dialog is displayed.
  3. Select "Boot Thawed" and click OK. This will disable Deep Freeze on the next reboot.
  4. The same steps can be used to enable (Freeze) Deep Freeze. The only change is to select "Boot Frozen" instead of "Boot Thawed".
B) Remotely via Deep Freeze Command Line Control (Deep Freeze Enterprise only):
Deep Freeze Command Line Control (DFC.EXE) can be used to Thaw/Freeze Deep Freeze through a script or batch file. More information about using this utility can be found in the Deep Freeze Enterprise user guide available at:
http://www.faronics.com/documents/DF6Ent_Manual.pdf
C) Remotely via the Enterprise Console (Deep Freeze Enterprise only):
The Deep Freeze Enterprise Console can be used to Thaw/Freeze a workstation using the following steps:
  1. Select the workstations to Thaw/Freeze.
  2. Click the "Reboot in Thawed state" button to Thaw the selected workstations. The workstations should reboot and appear in the Console in a Thawed state.
  3. Click the "Reboot in Frozen state" button to Freeze the selected workstations. The workstations should reboot and appear in the Console in a Frozen state.
Please try the steps and I am sure you would be able to disable the deepfreeze software.
Apr 20, 2011 | Faronics Anti-Executable Standard
How do I get my lg ally to respond to a voice dialer call command from my Jawbone bluetooth?
Hi bredebar you need to go to settings. Next you need to hit the wirless &network go to the bluetooth settings and make sure that the blue tooth is connect to the phone and audio. If your having a problem with the voice command it is because your ally doesn't have froyo on the ally. You need that to get the voice commands to work. you can go to the open market and put in voice commands for droids. Hope this helps foryo is frozen yogurt great name. There is another new program coming out be on the lookout for it .
Jan 03, 2011 | LG Ally Cell Phone
Lg hdd will not always respond to remote commands
I returned it to LG. Thanks for your help.
Jan 18, 2010 | LG Televison & Video
I have a Toshiba TV model 36A43 that won't power on. The same thing happened yeaterday as this morning. The tv will not power on via remote, or the manual power button. Yesterday, the same thing occurred...
It sounds like you have a switch problem at the front panel of the set. If a switch gets stuck internally the micro is trying to process the command and won't respond to any other commands. The only way to find out is to go into the set and desolder all the manual switches and see if the remote will work the set. It has a seperate detector for the remote. Thanks for using fixya. Good luck
Nov 08, 2009 | Toshiba 36A43 36" TV
My powerbook G4 does not chime!!
I suggest you plug it into AC power, then boot with Command-P-R held down until you hear the unit chime twice, then release it. Hopefully, it will boot after this.
If not, boot with Command-O-F held down; when you reach the command line, type
reset-nvram [return-key]
reset-all [return-key]
If it doesn't boot after that, you have deeper issues if the machine is actually turning itself on and off.
Sep 18, 2009 | Apple PowerBook G4 Mac Notebook
Unable to delete a command in the spool que?
The problem has been resolved. I re-booted my pc and the command finally completed deletion. Thank you for your assistance.
Sharon
Dec 04, 2008 | HP Hewlett Packard LaserJet 3000dn Printer
I KEEP GETTING THE BLUE SCREEN
46CB,
Might be your windows currepted.
Reinstallation of windows will fix your problem.
Before re-installation:
You can try the following steps:
  1. Boot your computer in Command Prompt Only. (After switching power on keep pressing F8 untill boot screen appears, select command prompt olny by moving up and down by arrow keys.)
  2. At DOS prompt type SCANREG and press enter key.
  3. It will run a diagnostic for registry and will save the current values as backup.
  4. After backup restore dialog will be appear. Select an old date on which date your computer was running well.
  5. Then re-start your computer.
Please post your feed back.
Thanks
Iqbal
Jun 12, 2008 | Toshiba Computers & Internet
Trying to start from scratch
Hi Use the following steps to open a command prompt environment and also make sure tht the OS disk is in the drive:
  1. Turn on the PC and press the F8 key repeatedly when the first screen appears. The Windows advanced options menu appears.
  2. Use the Up and Down Arrow and Enter keys to select Return to OS choices .
  3. Select Microsoft Windows Recovery Console .
  4. When the login prompt appears, press the number next to the windows version (minint or Windows) and type the logon password. Try pressing Enter if you do not know the password.
  5. At the command prompt, type the following: diskpart
  6. Press Enter , do one the following:
    • If a table of volume names appears, remember the drive letter next to the main drive volume name and press the Esc key.
    • If a diskpart prompt appears, type list volume , press Enter , remember the drive letter next to the main drive volume name , type exit when done, and then press Enter
  7. Use the following steps to replace the boot.ini file with the backup boot.ini file:
    1. Type the following at the command prompt: X: (where X is the drive letter).
    2. At the prompt, type the following: ren boot.ini boot.in2
    3. Press Enter
    4. At the prompt, type the following: ren boot.bak boot.ini
    5. Press Enter
    6. At the prompt, type the following: exit
    7. Press Enter The system automatically restarts. If Windows XP does not open, continue to the next Step.
    If the above steps doesnt work then you will have to reinstall OS with the disks.
Feb 13, 2008 | Toshiba Satellite A105 Notebook
PCS-1
Reset password sony pcs-1
1. Access the Setup menu as follows:
Press and hold the MENU button on the remote commander.
2. Select Dial using the �� button on the remote commander.
3. Access the Service menu as follows:
Press 7 then 2 on the remote commander (without pressing the
PUSH ENTER button).
The Service menu appears. (See Figure 1.)
NOTE: To cancel Service mode and return to the Setup menu,
select Cancel using the arrow buttons, and press RETURN.
Jan 18, 2008 | Sony PCS-1 (PCS1) Video Conference
Always freeze
Firefox will use a lot of disk space over time for temporary use. You might try starting up and run the Disk Utilities program to repair disk permissions.
Dec 25, 2007 | Apple iBook Mac Notebook
Toshiba HDR5010KB Digital Recorder Logo
151 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
