I have an RCA proscan tv, CRT type. My sound has to be turned all the way up to hear it. There is also a low hum whether the sound is up or down and does not change volumn, no matter if the sound is
Chasis number: CTC169BJ5 Service Number: PS35653LW1 Model: PS35653 Serial Number: 323550072 Audio Video Equipment: QD337701
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
The ctc169 was the workhorse of the RCA line being used in over 300 models----sounds like a possible audio output circuit---a lot of parts are no longer available and I would be careful having a shop fix a set this old.
YOU "might" be able to get around this with a surround sound system used with a cable box.
Posted on Dec 04, 2012
chillmaster
  • 104 Answers
SOURCE: TV will not power on
Sorry, I had the same thing happen to me. The problem is a chip that has blown on the main control board in the unit. The board must be replaced, but I checked and as the service place told you, parts are not available. Looks like it is time for a new TV
Posted on Jun 20, 2008
SOURCE: Proscan will not turn on
i had the same issues.. i took the TV into a repair shop and they replaced a peice for $40.00 (Canadian)
Posted on Aug 06, 2008
  • 77 Answers
SOURCE: RCA TV, model number 32V550T. No picture but sound is fine.
hiya
this sometimes is quite simple to fix as it cud be a dry joint on the circuit board where the tube motor sits.
or it cud be the tube is on its way out, which wud be cheaper to buy a new tv rather than have it fixed
rik
Posted on Feb 24, 2009
ginko
  • 19396 Answers
SOURCE: Proscan TV powerup
When TV does not start, and sometimes you hear a clicking noise, that means that the TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Apr 17, 2009
SOURCE: 36" RCA TV Wont power up
I had dish network come to hook satellite up to my 36 in rca flat screen well they couldn't get signal to it and after 4 hours they called it quits and when they left I discovered that my Tv no longer had sound!This Tv was in perfect working condition before they came and tried to hook satellite up to it!Help??
Posted on Apr 05, 2012
Tv works but no sound
Hello Jjwpod hi, to find where the trouble is, you need to place ear near speakers, you should hear a humming sound, adjust the volume up or down, the humming sound also goes up or down, this means your amplifier is working, no hum means trouble in amplifier.
summary:
No hum: trouble in amplifier, speaker connection.
Humming, but no audio: problem before amplification, most likely the Sound IF stage.
Sep 16, 2010 | RCA F27615 27" TV
No audio/video
sounds like fly back failure. high voltage transformer
Aug 12, 2009 | RCA 27V514T 27" TV
Volume making humming noise when on
there is a bad ground.
the hum you are hearing is ac getting into the audio.check all the rca plugs on the set are plugged in all the way.do not run them close to a power bar either.
sometimes a second unit with it's own volume is hooked up to the tv and then the tv volume is up too high because the other box is turned down.if there is a unit hooked up,turn it's volume up ,and the volume on the tv down,otherwise the tv will amplify the residual noise.cheers,ed
Jul 04, 2009 | Proscan 32LB30H LCD TV
Proscan 40' 40LC45S has a high pitched hum when it is off. Sound goes away when TV is on.
Same problem here, there is a high-pitched sound in standby. As soon as the light turns blue and the TV is on it's gone. I actually exchanged this TV three times at Best Buy but all the models made the same buzz in standby. I was told that it's normal and in the store you can't hear it since there is too much humming from other TVs around. The power is transformed down to a minimum, just for the remote controls, internal clock etc. and this causes the buzz, like when you dim your lights at home. I hooked it up to a surge-protector for clean power and just switch it off over night. During the day it's hard to hear anyway. - Again, since this is my third (!) Proscan 40' exchange I can definitely say that this is normal for this model. I was just surprised that nobody mentioned the same problem so far on the Best Buy reviews.
Jun 10, 2009 | Proscan 42LA30H 42 in. LCD Television
Poor sound quality
Hi, I sent an email regarding the issue to OnCorpus (the company who makes ProScan)
This is what I got back:
Thomas,
Follow these steps to correct humming issue:
1. Turn tv on
2. Input mode should be tv
3. Turn volume to zero
4. With remote enter 9 8 7 6
5. A menu will appear on left side
6. Arrow down to backlight and with right arrow key move number from 81 to 83, press menu button twice,
7. Turn up volume and listen if hum is gone.
John
jd@oncorpus.com
I can't confirm if this works at this moment since I don't have access to my TV.
Thomas
Feb 11, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Why won't my T.V. turn on?
hello . it sounds like a high volatge problem . the tripler and the or the fly back transform. is bad. and thats what is huming. sound that you hear. time to get a new set. Good luck
Feb 08, 2009 | RCA 32F530T 32" TV
No Audio, picture fine
this is a very common problem just unplug tv for 5 minutes it
should fix it . simple fix most of the time with rca and proscan.
If that does not do it go into menu scroll down to audio and then press on .
thanks doctor video leading edge electronics
Apr 28, 2008 | Proscan PS36800HR 36" TV
Dec 01, 2007 | Proscan PS27600 27" TV
Agrabka@hotmail.com
Probable bad flyback transformer, common failure GE, RCA &
Proscan ( Thomsom Mfr.).......provide service number off back of set and I will get you Part #..............................
Nov 18, 2007 | RCA F32649 32" TV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
