Question about 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper 5701 shock sensor adjust not working
I have a viper 5701 in my 95 ford f150, i've been trying to set the shock sensor up more but i cannot, the remote gives me an error beep. i had all doors shut and valet mode off, i put the code the code in on the remote to enter the chock sensor but it doesn't work. i believe it's due to me not having a trunk button installed. Any suggestions on what on what i can do to engage it?
  • richie strejc Dec 04, 2012
    the remote isn't locked, the batterys are new (remotes) and i have read all the manual, the remote still wont adjust it. as soon as i hold the lock button (1.5 seconds) after i hold the function button for 15 seconds (till the light is solid) it beeps wrong and flashes red. is there a setting i may be on? also i cant access the sensor bypass
SOURCE: viper 5701 remote
read the owners guide look at page 11 remote control programing you have to follow the instructions after your in the programing mode go to page 12 look at the unlock symbol and finish the programing
Posted on Feb 28, 2009
Megaduty
SOURCE: VIPER 5701 remote how tofix?
you have the key pad lock turned on. It protects the keys from unwanted pressing when in your pocket. To unlock you hit the F key then the unlock key, you can now use any command untill you let it set for 60 seconds, then it locks again.
to stop this totally, u hold down the F key for 12 seconds it will beep and top light turns orange, then hold down the unlock key for 2 seconds, it beeps then u hit the lock key to turn off this feature (top green light goes out). then hold F down, and F down again, should b good to go!
REM
Posted on Jul 14, 2009
SOURCE: My Viper 791xv remote isn't receiving the page
My battery ran low and I jump started my car which some how caused the problem. My viper technician made me a buy new remote but the problem continued even with the new remote.
Try disconnecting the battery of your car for ten minutes and then reconnecting it. It worked for me. Now i have a extra remote which i don't need.
Posted on Jan 19, 2010
SOURCE: My viper 5701 2way remote works, but gives buzz for all functions
hi did you get this unit from ebay? i am going through the same experience right now and there is a problem with the early units that were manufactured. It will need to be replaced. I am currently trying to get a refund.
Posted on Feb 08, 2010
  • 132 Answers
SOURCE: how to program viper 5701 remote
Unlock doors
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in to IGN position
Push valet (black button) one time and release
Push and hold valet button
Push either lock or unlock on viper remote
Key out of IGN
Test unit
The horn or siren may sound afterwards to indicate SUCCESS!!!!!!
Posted on Apr 04, 2010
My viper 5701 alarm is having issues.
First thing is to trip the system to see if the siren works then. If it does, then perhaps you inadvertently set the chirp commands to silent. If the siren doesn't work when the system is tripped then that's your problem. You'll need to find the siren and troubleshoot possible causes. I'd start with the wiring but the siren could have simply gone bad. You should be able to test it easily with a test light or multi-meter.
Mar 19, 2017 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Car alarm goes off after starting car remotely
It's possible that that could be the shock sensor. Adjust it downward or, bypass the sesor prior to remote starting the vehicle.
Dec 12, 2012 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My viper alarm came with my truck and i had to put a heater core yesturday. so i disconnected the battery and obviously reset somthing or a wire is loose. well i got woken up last night to my truck auto...
If theres a pattern for the time then it has a timer run time set. If no pattern the unit has activated either the temp sensor and/or the low battery voltage sensor. Check your owners manual how to deactivate.
Oct 05, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper alarm keeps starting truck by itself
you have timer mode set. Check the time because there will be a pattern. Typically every 3 hours OR there is an automatic timer that will start based on the outside temp. sensor and theres one that monitors battery voltage and if the voltage drops to a low enough voltage the remote start will start.
Oct 03, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I have misplaced my remote control key after returning from work. How can I find it please?
If you know its at home or near there. Lock/arm the security system from the 1way remote and then set the alarm off either by opening door with the KEY or hitting the car to set off the shock sensor. The 2way remote will start making lots of noise AS THE ALARM IS GOING OFF.
Now if you lost the 1way remote, there is really no easy solution except your eyes.
cheers!!
Sep 04, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I have the viper 5701 on a bmw 540i and the alarm works so does the keyless but the remote start does not work, the park lights flash 7 times and gives an error code,what can cause this?
The flashing parking lights signal a shutdown diagnostic. There is a nuetral safety switch under the dash. It's a toggle switch that needs to be in the on position. Also, the hood pin needs to be making contact with the hood when the hood is closed.
Jun 28, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I have VIPER 5901 > how
The shock sensor can be adjusted by a Viper dealer.
The second part of your question does not make 100% sense, can you please reword and put in more detail.
Jan 31, 2011 | 5901 Security Remote Start System
The alarm is on a 1996 f150 the alarm will not chirp the led on truck is solid it isnt blinking and it is a 5701 viper
Your alarm got put into valet mode some how
.It's easy to reverse out of it back to normal. First look for a small black push button under the dash somewhere. It's called a valet button. Here are the steps.
1. open door
2.turn key on then off
3.then within 10 seconds hit that valet button once(your alarm light should be off. Tell you arm it again. Then it will blink)
Hope this helps
Aug 18, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper 5901, Ford 2008 6.4/ When I use the trucks door keypad
If you use the viper remote to arm the alarm, you MUST use the viper remote to disarm the alrm prior to opening the door. The only REAL solution is to add the keyless entry feature to the viper system, and quit using hte factory remote all together.
Aug 09, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
5701 VIPER 5701 2-WAY ALARM w/REMOTE START Logo
163 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
Tre Elkins
Shehu Pro
Shehu Pro
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
