Question about Dell A215 Computer Speakers
Possible blown speakers
My speakers work but they are really quiet even when the volume is up full blast
    Novelist:
  • 180 Answers
I have experience with that model of speakers. When they give up the ghost, the volume is VERY low. But just to be on the safe side, check the volume properties to make sure nothing is set too low. Start>Control Panel>Sounds and Audio Devices. Check the slider bars here, check in the Advanced area as well to make sure nothing is low and check the Speaker Volume as well. If all the bars are set to their maximum, it's time for some new speakers.
Thanks for using fixya.com. If you like my answer, please help me out and rate me accordingly.
Posted on Jan 11, 2009
Volume on my iHome is too quiet, fix please?
You an inline battery powered signal booster, they are cheap.
Sep 23, 2016 | iHome iBT60 Bluetooth Rechargeable Mini...
Packard bell easynote speakers are very quiet
In instances of speaker damage, there may not always exist a drop-in replacement. ... Driver damage doesn't just consist of poked-in speakers, there's also blown ... You'll know if the driver began smoldering, if there's smoke to be seen on the ... Hook it up to the speaker, let it play at modest volume
Dec 01, 2012 | Computers & Internet
Sound only works at high volume
What happens in a lot of these sets is the speakers are tiny--they get used long enough at fairly high volume and the paper in the speakers can tear or even come apart---if able a look inside at the speaker/s would show if this is the case.
Jun 16, 2012 | Philips 27PT9007D 27" TV
Describe your Magnavox Stereo Mini System FW36 Problem My speakers that came with the stereo dont really work. only when I turn the volume all the way up I can hear the music, but the sound is really...
Yes.
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Apr 16, 2011 | Philips Audio Players & Recorders
Speakers on full but really quiet
First, make sure speakers are plugged into speaker out, not line out, and all the cable are all the way in to the ports.
Second, check the sound control in the control panel to make sure master, and other settings are up.
Third, make sure the volume on the speakers are turned up.
Some of the programs also have their own volume control, make sure those are set correct.
Apr 12, 2011 | Acer Aspire 3690-2196 Notebook
My 2001 330ci has the Harmon Kardon sound system. However, when I run the system at high volume for about 5 minutes, the front speakers start cutting in and out. It doesn't seem like a speaker is blown,...
Thermal issue is shutting down amps till temps moderate. You must be driving your system too hard. And check out your tone control settings especially the bass. Every 3 db boost forces amp to double power at that frequency so if you are already blasting at 100 watts, a 3 db boost will compel amp to put out 200 watts, etc. Very easy to overdrive and overheat amp. You might want to try blowing air over output stages to improve cooling at high volume levels.
You are lucky that you have good protection circuits - otherwise by now you would have blown the output stages.
May 08, 2017 | 2001 BMW 330
One speaker stopped working and its really pissing me off...
Probably a short or a blown speaker. A speaker will still make noise if it is blown. Replace that speaker with a working one and see if that does the trick.
Aug 20, 2009 | Altec Lansing VS4121 Computer Speakers
Erratic volume
Either the potentiometer which sits behind the user knob has got a broken track or it is full of debris
You can buy a tin of Servisol switch cleaner (or similar, make sure it has a lubricant in it and that propellant does not harm plastics) take off the knob and give it a good squirt where the spindle of the potentiometer enters the cabinet
Give the spindle a few full rotations and another dose of cleaner , then give it a try
It is best if you take a cover off and apply the cleaner direct to the potentiometer
Jul 01, 2009 | Creative Labs I-Trigue L3500 Computer...
Volume up then pic gone
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Dell A215 Computer Speakers Logo
249 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
