How do I stop my S3520 computer from shuting down automaticaly when unattended
I have started to run a betting bot but the computer shuts down even when the bot is running
  • 27,725 Answers
Is it only shutting down when unattended ? Which operating sytem ?
if your laptop keeps shutting off
If your laptop suddenly shuts itself off for no apparent reason, there are several factors that can contribute to the problem.
When you troubleshoot the laptop, remember that it is also possible for a combination of causes to be at work.
Excessive Heat
Keep Cool
All newer laptops have built-in heat sensors that shut the computer off when it exceeds a pre-set temperature threshold. Install and run a temperature monitoring utility to determine whether the laptop is overheating.
might be getting hot
check you CPU make sure its securely seated and has thermal grease
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Hardware Issues
If you replaced or installed new hardware in your laptop, use the device management utility to review if there are any resource conflict or failure reports. You can also remove unnecessary hardware and run the laptop to see if the problem persists. If it doesn't, reinstall each hardware component and re-test until the laptop fails.
Operating System Issues
The operating system start-up controls can affect how the laptop performs.
Follow the operating system developer's instructions for entering the start-up program, and confirm that the settings are what your laptop requires.
Power Supply
If the laptop computer suddenly shuts down, it could be because of a break in the power supply.
If the laptop is plugged into an outlet for power, check to see if the plug was pulled from the socket and make sure the cord is properly connected to the computer.
If the laptop is running on battery power, then it is possible that the battery is drained and no longer has enough power to run the computer.
A simple recharge of the laptop battery should fix the problem.
Typically, a laptop has an indicator on the screen that tells how much battery life is left so that a shutdown is not a surprise.
Failing batteries can produce unexpected laptop shutdowns.
Use a battery monitoring utility to determine whether or not the battery is healthy and replace it if it isn't.
Malware
Unfortunately, rootkits and viruses can cause your laptop to shut down without warning.
You will probably have to take the hard drive out of the laptop to be able to scan it fully and remove any malware that is installed, or the laptop will shut down before the scan and repair can finish.
http://www.malwarebytes.org/mbam.php
Malwarebytes is as the name says, a Malware Remover!
Download the Free Version from the link above.
Download, install, update and scan once a fortnight.
http://www.spybot.info/en/index.html
Spybot Search & Destroy 1.6.2 is a very good, FREE Anti-Spyware Program.
Download, install and update it.
Then SCAN with it.
Update it, and scan your System once a fortnight.
Hope this helps
Posted on Dec 04, 2012
SOURCE: keep shuting down.
It may be overheating. Common problem with the dv1000. The fan may need to be cleaned or replaced.
Posted on Jan 29, 2009
  • 64 Answers
SOURCE: starting up the shuting right down
The only options is seems at this point would be to install a fresh copy of windows or you could reinstall windows over itself if you didn't want to loose your data. Is this windows XP?
Posted on Mar 07, 2009
  • 10 Answers
SOURCE: i have a Hp laptop bt it is now not shuting down
remove charger first and remove battery second to try which one causing problem.
if any power source cause the problem that is mean the mainboard or power board inside failed.
good luck.
Posted on Jan 06, 2010
vikasbharti8
  • 179 Answers
SOURCE: switched on samsung laptop s3520
its seems to be some problem with the LCD of the laptop..as its a new computer contact the manufacturer without any second thought..dont try to open it..or dont take it to local teck..call samsung they help you
Posted on Aug 18, 2011
  • 867 Answers
SOURCE: i have a lenovo z560 and when i start to playing games,sometimes later it works slowly and then it abruptly shuting down without any notification.this is occured near about 1 months.before that, it wo
You have an overheating issue, it may just be dirt in the CPU cooling fan or it could be a defective cooler or degraded heatsink compound on the cpu
Posted on Mar 12, 2012
Shut down automaticaly
Not much to go on, "shut down automaticaly" on battery or AC or both? A computer will shut down, or hibernate, if thats what you mean, that's a power setting? If a computer overheats it will shut down automaticaly to save the components from heat damage. If there is dust in the fan and vents it will shut down. If it is not getting sufficent air flow from vents on the bottom of the laptop through the vents on the side. One option is a Laptop Cooler.Is it shutting down when you are on it? When it's left unattended? Respod to this post for further assistance.
Nov 19, 2012 | Unknown Toshiba Satellite P755-s5385 15.6...
Motor shuts down when reaching normal operation temp
Sounds like the mass air flow sensor or the air intake temperature sensor. Sometimes just wiping out the throttle body/air intake can make all the difference
Good Luck and Happy Motoring
Jun 22, 2017 | 2000 Dodge Durango
Computer keeps shuting down
Shuts down when? Right after you boot it up? Or does it run a while then shut down?
If it shuts down after it has run for a while then the computer is probably running hot. Either the CPU Fan is not working or the Thermal Paste has dried up or is too thin to keep the CPU Cool. To prove it is running hot, let the computer sit for a while then boot it up. Once it boots up use it until it shuts down and immediately try to boot it up. If it does not boot up that means it's running hot. But if you let it cool off then try booting up you will be successful.
Mar 27, 2012 | Compaq Computers & Internet
When i switched on my laptop,it showd the warning as cooling fan is not workingproperly.and it got shut down automaticaly within 10 sec. but there is another option present showing start windows...
The computer monitors the speed of a fan inside your laptop.
If the fan stops spinning, or is spinning too slowly to cool your computer, your computer will stop.
Take your computer to a qualified technician, before your computer overheats and REALLY damages itself.
Apr 20, 2011 | Computers & Internet
Please guide the steps to install the norton antivirus 360 latest version one user
The easiest way, open your CD drive and with that open shut down your computer. Insert the Disk in the drive and close it then restart the computer. The installation program should start auto automatically as windows starts. The reason I said to shut down then reboot with the disk in the drive is to allow the program to scan your system before windows starts to speed up the install process. If you insert the Disk and close the drive while the computer is on it will auto start and scan the system anyway but it takes longer. Make sure you stop and uninstall any other anti virus programs or Anti Adware programs, such as Spy Bot, you may have running, the Adware programs only need to be closed.
Jul 22, 2010 | Symantec Norton 360 Version 3.0 Full...
HP 520 Notebook. Shuts down before installing new OS.
I agree a clean install is always the better, fresh start J
OK it sounds like missing drivers, what you have to do is create a new installation CD that will load the drivers for your laptop as it boots. I haven’t try this method with windows 7, but I know it works well with Windows XP. Try and create a new Windows XP CD with the drivers see: http://unattended.msfn.org/unattended.xp/view/web/35/
The start a new installation with this Windows XP CD and reformat you computer, after that you can do a new upgrade to windows 7
Nov 25, 2009 | Office Equipment & Supplies
UU undervoltage kohler 20kva
call koler but ui think is meant high heat as in the thermal circut is shuting you down or low oil
could be a couple of things best bet call kohler
Aug 06, 2009 | Kohler 12 kW Emergency Power System -...
How can i get my computer to turn off automaticaly
What OS are you running? Try hitting control/alt and delete at the sametime when the task manager open click on shut down computer and see if that works.
Dec 16, 2007 | Acer Aspire T310 PC Desktop
IBM T21 shuting down
start your lap in safe mode and watch the shutting down time and let me know
Oct 10, 2007 | IBM ThinkPad T21 Notebook
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
