Question about Refrigerators
How to replace overflow grille - Refrigerators
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 04, 2012
  • John Sessions Dec 04, 2012
    I figured it out. It just slides straight out. Thanks though.
Why is my drain pain overflowing?
on most fridges, you should be able to empty drain pan. Remove grill on bottom at the floor, and see if pan will slide out. Good-Day!
Jul 26, 2014 | Roper Refrigerators
Low gas to burner
turn off gas source, check gas line for possible blockage to that 3rd burner, sometimes when we cook food with liquid , such as sauces or soups , then tend to overflow and get into the burners and the gas lines causing a blocked gas line, where the lower half of gas line is filled with liquid,,,
Dec 28, 2013 | Barbeques Galore Turbo Classic 3-Burner...
MY Traeger is less than a year old. I started smoking some salmon alot of smoke was bellowing out the stack. It was so much smoke I could not see the grill with the salmon when the lid was open. I close...
Sounds like you've got grease in the bottom that's catching on fire. Take the grill apart and clean out the bottom of the barrel. You'll probably need a shop vac to clean out the ash, too.
May 25, 2017 | Traeger Industries BBQ070 All-in-One Grill...
I have a 1999 oldsmobile intrigue with a 3.5 engine and it is overheating what might be the problem?
It's usually the thermostat, I woud pressure test the cap. It may need to be flushed. Are the fans working? Is there a 50/50 mix of anti-freeze
Sep 11, 2011 | 1999 Oldsmobile Intrigue
Just bought a new Jenn-Air grill and cant get the temp past 250. Any ideas what i am doing wrong?
First, check that all the gas lines and flame bars are clear of any 'things' or bugs. I had a similar problem with a Webber grill and found out my problem was with the gas bottle. The new Overflow Protection Valve required on LP bottles can closed off or severly slow the flow of gas when the bottle is full and the valve is opened quickly. It will let enough gas flow to light the grill but won't let the fire get high enough to heat the grill up. Turn all the valves off on the grill and gas bottle. Open the gas bottle valve slowly then turn on the grill burner and try lighting it. If the flame is still very low try again or you have to let it burn at the low level until the OPV float drops down and the valve doesn't impede the gas flow. The best way to avoid this in the future is to not fill the gas bottle to the top when you have it refilled. Just ask the LP attendent to not fill it all the way.
Jun 06, 2011 | Garden
I have a Weber E-420. When the lid is closed and it rains, I find the dripping collection pan full of water and overflowing, resulting in a real mess of water and drippings all over the inside of the...
That's not unusual at all. Nor, is it a design flaw. The are are air vents all along the back of the grill head that allows rain to get in. Especially, blowing rain. The best solution is to either bring the grill into the garage when it's not in use OR if you don't have a garage, invest a few $$ in a good quality grill cover. Not some cheap $9.99 special. Either one, will solve the water problem, as well as keep the tree drippings and bird droppings off the grill.
Apr 19, 2011 | Weber Summit E-420 Gas Grill
I have a Kitchen Aid side by side refrigerator. Under the refrigerator there is a plastic water overflow tray. It collects water and the water becomes foul smelling. I have tried removing the tray to...
You should be able to remove the base grill by opening both doors to 90 degrees and pushing down while pulling outwards on the base grill to unlock the top clips, once the top is away roll the base grill toward you and up. From there you should be able to see the pan underneath which should slide out.
Clean it thoroughly and use a mixture of baking soda and water for final cleaning rinse and replace, I also mix some baking soda and water and pour in the bottom of the fridge to allow the mixture to cleanse the drip tube leading to the pan.
Installation is in reverse of removal
Mar 12, 2011 | KitchenAid KSCS25FKSS Side by Side...
Traeger junior 2 weeks old dosen't seem to make loud fan noise when starting up , seems like during grilling last night made funny noise like bad bearing or something cleaned grill empted fire pot and...
Take and unplug your electrical cord and then take the bottom grate that covers your motors and components off. The are 4 small screws and then it should drop down. Look to see that there are not any wires hitting your fan motors. You can just reach up there and move them around if they are. Some Treagers seem to have some noise until you use them a little. They have a 3 year warrenty, so if the wires are not hitting the fan blades, I would use it and see what happens.
Apr 15, 2010 | Grilling
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
