Question about Acer Aspire AM1640-U1401A Desktop PC
Want to upgrade my proccesor
I have a Acer Aspire M1640-U1401 with a intel pentuim duel core processor E2160 @1.8Ghz and i would like to upgrade it to a Intel Pentium Dual-Core Processor E5200 @2.5Ghz. will i have to repalce my motherboard or can i just switch out the processors? also if i do just switch out the processors will i have to reinstall windows Vista? Please help i need a faster proccessor badly.
  • Stephen Scheneman
    Stephen Scheneman May 11, 2010
    Since Acer is world renowned for poor support, Can you please give the make and model of your motherboard? I need it so I can tell you if upgrading to a 64 bit processor is possible.
OMG!! doogie812, quit giving people bad advice. From what you have suggested, you know nothing about computer hardware. You can upgrade the processor in this system and it will not effect the OS one bit, except make it process the data a little quicker. With this system, if you had done any research at all, it only comes with 1GB of memory, you should of suggested to this person to add more memory.
Posted on Apr 13, 2010
    Problem Solver:
  • 10 Answers
For the most part that is not doable. You cannot switch processors in mid stream. Given the fact that AMD and INTEL have boat loads invested in there chip sets, Windows detects this. Changing hardware on your software will result in a major slowdown in your operating system. You will have to reload. Many people think there slow computer is a result of the microprocessor, this is wrong!.
It is the lack of memory and poor design of the buss structure that results in slow computing.
Doogie
Posted on Jan 12, 2009
I have a acer aspire m1640, with the motherboard fails, if i can not fix it, what motherboard, acer apart, can i mount it? thank you
There are a few options you have on this, but if you want to maintain full compatibility with your current hardware, then you must purchase a motherboard that supports DDR2 533/667 MHz SDRAM since that is what comes standard in Acer Aspire M1640 Desktops.
A few options that would be similar to stock motherboard would be:
Foxconn G31MXP-K I7 or Biostar TForce TG31-A7
Those motherboards have similar specs to the stock motherboard and you can take a look at the specs of the Acer Aspire M1640 from this link below:
http://support.acer.com/acerpanam/desktop/0000/Acer/AspireM1640/AspireM1640sp2.shtml
Both those motherboards I have linked you too are microATX boards, which should fit fine in your case which may be a standard ATX case.
If you are willing to upgrade your ram, then your options open up to any motherboard that supports the Intel Pentium Dual Core processor. Since the stock motherboard also provides onboard video, chances are you don't have a video card plugged into your motherboard (unless you've upgraded that yourself) which means you should also look for a motherboard that provides onboard video so you don't have to purchase a video card.
Feb 26, 2011 | Acer Aspire M1640 Refurbished Intel...
My Acer Aspire M1640 desktop pc won't boot up
It is an problem with hard disk please change it
Feb 09, 2011 | Acer Aspire M1640 Refurbished Intel...
Aces Aspire M1640 desktop-pc starts but the monitor says NO SIGNAL. Tried various monitors and videocards without result. Can't find what mainbord is in it to have it changed. Regards, Toine
black out can be caused by series of things. Power supply is one. Second is the motherboard, memory and the processor aside from the video card. Motherboard and processor can be isolated,first is to remove the rest of the devices such as hard disk and cards and memory. Beep sound means your board is still doing fine. Re install all the devices and power on again. Good luck
Sep 12, 2010 | Acer Aspire M1640 Refurbished Intel...
J'ai un pc acer aspire m1640 et j'arrive pas instaler xp
Cet Acer a un disque dur SATA - XP ne peut le reconnaitre pendant l'installation sans le driver, Tu peut le trouver ici (avec tout les autres)
http://www.getpcmemory.com/drivers/download-acer-aspire-m1640-desktop-windows-xp-drivers/
Decompresse-le e brule-le sur un cd - quand (pendant la installation) tu sera questionne de lui met le dans le lecteur.
Feb 21, 2010 | Acer Aspire M1640 Refurbished Intel...
My Aspire M1640 wont start and it's readers won't blink
try hard bios reset and verify processor heat, if it doesn't heat a little this could mean that your motherboard is malfunctioning
Dec 31, 2009 | Acer Aspire M1640 Refurbished Intel...
I also have an Acer M1640 with a burned out Motherboard. Everything else tests out fine. QUESTION IS---Will a regular MSI PNGM-FD MB replace the MSI MB in the Aspire M1640 ACER?
yes but you will have to reinstall all the acer **** you got with the pc originally and also windows as it wont jst play due to hardware change
Sep 29, 2009 | Acer Aspire M1640 Refurbished Intel...
Cannot reinstall new os, seem my hard drive is not detected by os
I hope its not Vista os, because if the driver is not in its database, it does not accept any new driver. Install XP first and run the Vista Upgrade adviser from microsoft to check whether your PC hardware will run Vista....sodeep
May 16, 2009 | Acer Aspire M1640 Refurbished Intel...
Cpu upgrade
Your computer has one of these options:
spacer.gif level2_arrow.gif Intel® Celeron® Processor 560
(1MB L2 cache, 2.13GHz, 533MHz FSB)
or
Intel® Celeron® Processor 550
(1MB L2 cache, 2.0GHz, 533MHz FSB)
or
Intel® Celeron® Processor 540
(1MB L2 cache, 1.86GHz, 533MHz FS
or
Intel® Celeron® Dual-Core Processor E1400
(512KB shared L2 Cache, 2.0GHz, 800MHz FSB)
or
Intel® Celeron® Dual-Core Processor T1400
Check the features with Acer first and see if your motherboard model support that speed processor.
Contact tech support directly to the manufacturer right here:
http://acer.custhelp.com/cgi-bin/acer.cfg/php/enduser/ask.php?p_sid=8P57rbgj
Oct 13, 2008 | Acer Aspire 5315 Notebook
Compatibility
A8V-MXs are built for AMD processors. You will need a board made for Intel processors if you want to purchase the above processor. If you want to stick with Intel and Asus check out the P5 series of boards. If not, buy an AMD chip...I've had AMD in almost every one of my computers, laptops and desktops.
Good luck.
Dec 20, 2007 | ASUS A8V-MX Motherboard
Acer Aspire AM1640-U1401A Desktop PC Logo
379 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
