Question about Microwave Ovens
The display on my Sharp Grill 2 Convection Model R 82ojs-f is too dim to read.
Display lights, but is way too dim to see it.
    Top Expert:
  • Microwave Ovens Master
  • 14,553 Answers
Either the display is bad or the unit may have a setting in the menu for adjusting the brightness level
Posted on Dec 04, 2012
  • 338 Answers
SOURCE: Dim Display Panel on Sharp Convection/Microwave R-1851
its a common problem with the sharp microwaves. the control pcb needs to be replaced. it should come with the clock attached to it.
Posted on Mar 13, 2009
SOURCE: manual for sharp grill 2 convection oven
where is the fuse at on the sharp grill 2 convection
Posted on Feb 01, 2010
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp Convection double grill LCD
We repair those for US and Canadian customers, but in the UK you can contact Quality Electronic Repairs.
Posted on Sep 16, 2008
fathitkf
  • 1871 Answers
SOURCE: sharp carousel convection/grill/microwave maybe R990
Hello :
This happens because of a bad door switch . The plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door .
Check also the turntable . It could be out of it's right place .
WARNING :
1:Don't slam your microwave door because this may cause the fuse to blow and this is the reason of bad door switch problem .
2: A microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Posted on Jun 03, 2010
SOURCE: I have 2 Sharp R898M Convection /Microwaves , the
Open up the display and push on the end of the ribbon cable where it connects to the edge of the display driver PC board, if it lights up then your ribbon cable's connection pads are failing. REplace the ribbon cable. If it DOES NOT light up then you will need to replace the entire display assembly (driver board and LCD)
Click on the link below to view the Sharp R-898M operation manual (If you have lost your manual):
http://www.sharp.eu/cps/rde/xbcr/documents/documents/om/20_mwo/R898MA_OM_GB.pdf
Posted on Oct 20, 2010
The control panel of my sharp grill 2 convection microwave oven is very dim
Dimmed light might be caused by a slight contact between the panel's connector and the mainboard. Or, there is a dimmer option (feature) in the menu. Depends on model. Some of Panasonic microwave ovens are equipped with such a feature.
Regards,
Dan
Oct 12, 2016 | Sharp R-820JS 900 W 0.9 cu ft Countertop...
Sharp jet convection double grill
Looking at other answers below your question on the page that i am viewing anyways. It appears that Sharp convection microwaves or Sharp microwaves in general seem to have an ongoing problem of that sort. The solution is to replace the main circuit board.
Nov 09, 2013 | Microwave Ovens
I need instructions on how to use Sharp Convection microwave Grill 2?
Best way short of Sharp is Google the model number of the unit with "manual" to try to locate free one online.
Nov 04, 2012 | Sharp R-930AK Convection/Microwave Oven
Sharp carousel convection/grill/microwave maybe R990
Hello :
WARNING :
good luck .
Jun 03, 2010 | Panasonic NN-S254BF Microwave Oven
Manual for sharp grill 2 convection oven
Jun 13, 2009 | Sharp R-820B Convection/Microwave Oven
The display no longer works on my Model R303CW Sharp Microwave. Is there a part that will fix the display?? Everything else works fine.
Nope , could be dry joints or corroded pcb or defective display driver or supply ? Only can be told once opened and inspected.
May 13, 2009 | Sharp R-303CW Convection / Microwave Oven
Mar 13, 2009 | Sharp Microwave Ovens
The Display is Dim. Hard to read the numbers.
I have the same model and problem. The time display is totally unreadable. Looking for a solution as well. I suspect given the cost (I believe around $60), it's time for a new one. Anyone have any suggestions or easy repair ideas?
Mar 12, 2009 | Sharp R-314FS Microwave Oven
Sharp Convection double grill LCD display not working
Sep 11, 2008 | Microwave Ovens
Siemens HF87950GB /03
If the display is dim and another problem is denoted on the dim display, the problem may be the power supply which may be in common with both items. The power may have surged to a high level before going out which could have damaged the power supply. The only way to know is to probe the power supply with a voltmeter. If the board doesn't show the power levels, usually +5V or +/- 12 V DC, read the values on the electrolytic capacitors on the board. Usually 16 V caps are used on 12 or 5 volt supplies, 32 V caps on 24 V supplies, etc. Be very careful or leave this to a profesional
Nov 24, 2007 | Siemens HF87950GB Convection Microwave...
Microwave Ovens Logo
353 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
