Question about Fisher and Paykel (IWL12)
Very slow to fill up with cold water-
20year old machine, checked filters-ok
The mechanical internals of both the hot and cold water inlet valves include a rubber (or similar material) diaphram. After a period of time the diaphram deteriorates and punctures or tears. When this happens the water inlet valve ceases to function correctly and the water just dribbles in and may take hours to fill the machine.
The cure is to replace the water valve that is displaying this problem. The presumtion is that you are already sure there is no filter blockage at filters that may be in the hose ends at the supply tap end and / or at the machine end.and that the plastic pull out filters that are in the water inlet valve (accessible after disconnecting the hoses) are also clean.
Posted on Mar 28, 2009
Wm2032hw water filling slowly
The solenoids in the valve were sticking either because of sedement in them or them being faulty all together, which is likely the case since you said the screens were clear of debris, my advice is to order a new valve because the problem will happen again, its a matter of when
May 07, 2012 | Washing Machines
Water when filling has slowed down cold water is very slow hot is ok
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Jun 26, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Whirlpool washer: Very slow fill cycle on the
I had a similar problem - unscrew the water hose feed lines from the back of the machine and clear out any sedimentation build up from the filters. You can use a turkey baster to siphon off. If filters are clear you may have to replace watervalve. Look at vitual repairman,com as to how to remove the back. Replacement cost about $26.
Mar 27, 2009 | Washing Machines
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
Washer fills only with hot water
Disconnect cold water hose from machine. Inspect the filter screen on the cold water connection. DO NOT REMOVE SCREEN. If full of debris, use a spray bottle with a hard spray to remove debris. If unable to remove or cold is still slow, replace valve.
Regards,
reg501
Jun 28, 2008 | Washing Machines
Fisher & Paykel 608 washing machine
nope..the pressure needs to be maintained..I'm assuming you've checked for blockage in the line and cleaned the intake filters, right?
Mar 11, 2008 | Washing Machines
Kenmore washing machine 80 series
check for kinks in the pipe or restrictions to the flow in the pipes before it gets to the washer, if all is ok then check the filter on the outside of the water connector on the machine for dirt
if you confirm all is clear and the flow of water is not the problem before the machine, replace the cold water solenoid
Oct 14, 2007 | Washing Machines
Washing Machines Logo
184 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
