Question about Bosch SHU5315UC Dishwasher
Bosch dishwasher stuck on CL
The control board on my dishwasher went (puff of smoke and lights out) so I replaced it. Once the new one was installed the power came on. I ran it on regular wash and the indicator counted down from 90 to 80 without any activity. It was stuck on 80 so I hit cancel and the indicator changed to CL. I haven't been able to get it off of CL. Tried to cancel again, turned machine off, circuit breaker off, re-installed the board but nothing has worked. Any thoughts?
BIKER T
  • 909 Answers
SOURCE: Bosch SHE44C02UC digital display shows longer time for regular wash than power wash
sadly enough, same problem. looks as though micro processor is defective.
Posted on Oct 08, 2007
aborcass
  • 2651 Answers
SOURCE: Bosch Dishwasher Not Draining
Im really not all that familiar with the bosch unit, but a few things i would ck. when you cancel a cycle (it should drain the water) is it humming??? does it sound as if it even trickling into the sink discharge?? do you have a disposer under your sink that this unit drains into, if so remove the clamp and look for possible obstructions right there.Honestly passed this ill have to defer to someone else sorry and good luck
Posted on Mar 10, 2008
SOURCE: Bosch Dishwasher will not power on
I have a bosch dishwasher model 2046. When you try start the cycle you hear the timer inside start to activate but the cycle doesn't start. The light in the start switch does not come on as well but I think it may be burned out. We have checked the breaker and I seems to have power.
Gerald
Posted on Oct 31, 2009
SOURCE: Bosch Dishwasher (SHE44C05UC) won't turn on
Just had the same problem, same model. Found the wiring below the front cover fried. So now I'm checking to see if anyone else had this happen.
Posted on Mar 06, 2010
SOURCE: Bosch sms 4012 dishwasher
hiya,
Can't solve this problem unfortunately but I however have been given a Bosch sms 4012 without the manual and was wondering if you could tell me how to make it go.
Posted on Oct 21, 2010
Is there a Reset button for Bosch shu53 dishwasher?
Press and hold Scrub Wash and Delicate/Econo buttons at the same time for three seconds. This will advance the unit to "CL" (clean), meaning the washing cycle is finished, and will drain the water. Do this if your unit gets stuck on 1 minute left, which is common with this model. (I am told that the control panel melts over time, and that the unit is not designed to last more than 10 years.)
Jun 22, 2014 | Bosch 24 in. SHU53 Built-in Dishwasher
Error code C1 PO......
Hello. Your model dishwasher has a recall on it. There is a potential problem with the control board. Call Bosch at (800)856-9226 to find out if your unit needs to have a new control board installed and re-programmed. This only covers the replacement of the control board--any other problem will be covered by the customer. You will need the model and serial number. Next, regarding your model's problem...this was gotten from another tech site(I'm a member of quite a few, lol)
"Sounds like the unit is stuck in the control coding mode. C1 is the proper coding for your model so you just need to lock it in.
To enter coding mode, press and hold the second, third, fourth and fifth buttons to the right of the display simultaneously, then turn the dishwasher on using the On/Off switch. The associated leds will be blinking to confirm coding mode.
Release all buttons to view control coding. To change coding, press the second button to scroll through codes C0 - C9. C1 is the correct code for your unit.
Turn the dishwasher off to save control coding and exit coding mode." I hope this helps you! Let me know if you need further assistance!---Thanks!
Jan 09, 2011 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
I little puff of smoke came from my Kitchen Aid Dishwasher Model 8531654 and now is not working. The lights are on but it never cycles through.
Sounds like the motor when ka-fooeey! Have a technician check the motor with a volt-ohm-meter to make sure that that's the problem.
Feb 23, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwasher signals "clean" inside five minutes
I would check tosee if your water meaning hot water temp is hook up correctly. i have seen cold water going to machine and causing the machine to do funny things. 1 the unit drains.2. it fills.3.it washes if the water is cold there is your problem .make sure b4 you start machine the water going in is hot. let me know how you made out maybe we can further check. p.s im a old bosch tech:)
Jan 26, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
My countdount down light stays stuck at 1 and the sanitary cycle doese not engage
Hi.This is a common problem with the Bosch.The heater relay on the control board is burnt out and need to be replaced.This is the electronic control behind the push buttons.cost about $130 for the part.Hope this helps.Please rate my response :)
Dec 11, 2009 | Bosch Dishwashers
Even after ensuring that really hot water is coming from the faucet and placing the unit on the Delicate/Econo setting we consistently get a 2 HR reading. We have also had it where the unit gets stuck on...
this is common, a lot of bosch dishwashers had circuit board recalls. call bosch to see if yours is one. also if you get the cicuit board replaced, ensure that it is programed correctly when it is installed. main reason dishwasher extent time is to heat to a certain temp. bosch will then average out previous cycles and adjust its times. sounds like your not heating.
Nov 24, 2009 | Bosch SHU5316UC Dishwasher
Bosch dishwasher SHU5315uc control board issue
Check the main smoothing capacitor on the control board. Could be low value.
Jul 24, 2017 | Bosch SHU5315UC Dishwasher
The digital display does not come on
you have a burnt board thats going to need replacing.that was the pop you heard and the puff of smoke.
Dec 28, 2008 | Kitchen Ranges
Philips 28PW6506 28" TV - no picture - just went pop
Hi
Please check TV's control board main capacitor for worn out.
Thank you.
Dec 28, 2007 | Philips 28PW6506 28" TV
Stuck on last minute
I have seen a lot of these dishwashers burn out the control board, and usually the symptom is the timer not working or inability to complete a cycle. Most of the ones I have seen, you can remove the control board assembly and its pretty obvious where its burnt. If you can do the repair yourself, the board is about $150. Hope this helps!
Oct 26, 2006 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch SHU5315UC Dishwasher Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
