Question about Jenn-Air Ovens
How to fixed my 1992 jen air oven door locked handle,can not find model nos
    Top Expert:
  • Jenn-Air Master
  • 9,472 Answers
Try unplugging it if it's wired directly find the circuit breaker and kick it off for a minute.
Posted on Dec 04, 2012
SOURCE: oven door locked - jenn air
My Jenn-Air double oven locked after a clean cycle. My model (JJW8630) has a series of slots cut in the top of the door. Take a piece of stiff wire, coat hanger, and bend a right angle about 1/2 inch at the end, feed the wire into the 3rd or 4th slot from the center on the right hand side. Turn the wire so that the bent piece is on the top and push the wire so it engages the lever which latches the door shut, it is spring loaded and moves easily.
Once the door was opened, I removed the temperature sensor, held by 2 screws, from the top of the oven and eased the wire out to get to the connector. The faulty sensor was reading 4.2 k, at room temperature it should be just over 1k, while waiting for a new sensor to arrive I stuck in a 1k resistor, ex Radio Shack, so the fan stops running and the door latch can be retracted by closing the oven door, or press the switch on the top right of the door opening.
My replacement part was ordered on line for less than 1/2 the official quoted price.
Hope this helps.
Posted on Dec 05, 2008
mastatech
  • 478 Answers
SOURCE: Neff Oven handle loose
The door can be seperated by screw on the side of the door, Put lock washers to insure futer tightness.
Posted on Mar 12, 2009
richardsimpl
  • 230 Answers
SOURCE: how to fix F1 error code
HI There
I have this code for you to read and this is helpful. Let me know how it goes.
F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information.Thank you for writing to fix ya.
Best Regards Richard
Posted on Jan 07, 2010
  • 523 Answers
SOURCE: Jen Aire oven / micro combo unit. Display code F7.
change the probe
Posted on Apr 24, 2010
  • 4 Answers
SOURCE: oven door handle is loose on Model RF366BXD self
Extend your door hinges and remove entirely over to a table or other flat surface where you can do a step-by-step dis-assembly. Unfortunately, to get at the interior of the handle unit, it's the final stage of the taking apart. Begin by removing the bolts at the bottom of the door, then the main panel and side flanges can be removed. (You can give your glass a good cleaning at this point also.) There are 2 bolts to remove to free up the handle unit, and now you can easily tighten (or replace as needed) the 2 pairs of handle bolts. Reverse your order to re-assemble, and put your door back on the oven. It's not as bad an exercise as it would appear. Just take your time and watch what you're doing. I used the hinges as a shim, and had it laid out on a pool table for easy, elevated examination.
Posted on Jan 02, 2011
How can I fix the loose handle of the oven door ?
Open the door and lock it down, or remove it from the oven. Remove the screws holding the inner panel to the door. Remove inner panel, then remove the screws holding in the handle. Reverse to re-install.
Feb 15, 2015 | Ovens
I need the Start Amprege for a Jenn Aire #WW30430P
phone jen air tech support daytime Eastern Standard time:
1-800-JENN-AIR (536-6247)
Dec 20, 2013 | Jenn-Air WW30430P Stainless Steel Electric...
Jen-air electric oven jjw8530. Door will not shut all the way. Light stays on. Hindges have been replaced twice. Not hindges! Help!
Bubbcrk,
Is your door lock in the way? I think that your model has one correct? Have you checked the door light switch? If it is the switch that is keeping the door from shutting and turning the light out, you can get one fairly cheap.
Please Clarify.
Door Light Switch for your model
http://www.pricedrightparts.com/products/Door-Light-Switch-PRP71002904.html
Thanks Joe
Jun 11, 2011 | Ovens
Both oven doors do not close properly. lights stay on & can't heat properly with doors not closing tight. is there an adjustment for these doors?
We have similar Jen Air double oven and with the same problem but only on the lower oven. The doors are interchangeable and the top door fits fine but the lower door will not close completely at the top. It does turn out the light but has never cooked properly. I checked with several appliance repair shops and the hinges are not adjustable, but since one door closes and our other doesn't it is not a hinge problem, just a defective design.
We let this go too long and are out of warranty so I doubt Jennair is going to do anything. I hope someone post a solution but it is clearly not problem with the henges but with the receptacle they go into.
Jan 04, 2011 | Jenn-Air WW27430P Stainless Steel Electric...
The door handle of my oven whirlpool gold model no GGP84803 is loose I try to get it off by prying it from the top with no luck seem to be jam or locked I am not sure how to proceed.
I had same problem, fixed by removing screws under door and removing side panels . Then remove front glass ( 4 screws under glass ) and remove other screws behind glass to remove handle and then tighten 4 screws on handle. Works great.
Dec 29, 2009 | GE Ovens
Mar 12, 2009 | Ovens
Oven Door Jen-Aire Single Oven won't shut all the way.
you have bad receviers probably. did you set anything heavy on it latley? sometimes you can realign the door by sticking a peicee of 2x4 between the door and the frame and closeing the door to pop the hinge out a little thatt sometimes solves the problem with out haveing to replace the hinges and the receivers
Jan 04, 2009 | Jenn-Air JJW8530C Expressions Collection...
My electric oven will not lock the door to have it self clean
The most likely problem is that the motor that drives the locking mechanism is defective.
Mar 30, 2017 | Ovens
Ovens Logo
46 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
