Question about Vacuums
I have a philips FC9222 vacuum cleaner. When i switched it on today all the lights came on but the motor did not start. all the lights are on and you cant adjust the power up or dow n using the button on the top. the whole thing just looks like it has frozen on. i would be grateful if anyone can help. thank you.
5 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: FROZEN On NON SUPPORTED FORMAT DETECTED SCREEN
Reset the player by inserting a paerlcip into the reset hole. If that fails, go to Philips' website and upgrade the firmware on your player to solve the freezing issue permanently. Actually, don't go to Philips website - run the Philips Device Manager and select Update. If the device manager won't recognize the player, unplug the GoGear, hold in either the shuffle button or volume + and reconnect it to the computer until a Found New Hardware Wizard window pops up. Once all this is done, use the Philips Media converter to convert all your video files from now on.
-Tha Mp3 Doctor
Posted on Dec 31, 2008
SOURCE: Kenmore Elegance Vacuum cleaner - power bar not working
The problem almost certainly is that the axle of the brush in your power bar has dirt/fluff in it that is preventing the belt from turning it so that the fuse in the power bar clicks off after 2 or 3 seconds. It is fairly easy to fix. All you will need is a Phillips screwdriver and about 15 minutes. Follow the following steps
1. With the power bar disconnected from the vacuum, turn it upside down and you will see two inset screws at the rear side of the base of the power bar. Unscrew these two screws using your Phillips screwdriver.
2. With the power bar in the same position unlatch the two plastic tabs at the rear of the power par. [It may be useful to flip up the metal bar that you see on the base to use as a handle] On each side of the base you will see an arrow saying insert screwdriver here to release. Insert a screwdriver and lever the plastic of the base slightly apart from the plastic of the side. When you have done this for both sides the base should lift off.
3. Now lift the brush including the two end pieces straight up. It should just slide up. You will need to unhook the drive belt from the brush as you lift it out.
4.Pull of each end piece and clean the dust, lint, hair off the end piece and from inside the end of the brush.
5.Once clean, reinstall the end pieces on the brush. Hook the belt back over the brush to its original position and slide the brush back into the power bar.
6. Reinstall the base by hooking the tabs from the front of the base into the small openings on the power bar.then push the base down until it clicks back into place and the tabs are back in their original position. Reinstall the two screws you removed earlier.
7. The power bar should now work. Good luck.
Posted on Apr 18, 2009
tooltech75
  • 80 Answers
SOURCE: Miele 5000 vacuum cleaner stopped during use. no lights on
could be your retractable cord assembly's contacts..
push the power on while pulling out the cord. see if it tries to start.
Posted on Oct 07, 2009
SOURCE: PHILIPS MOBILO PLUS (vacuum)- How to remove motor cover?
I found a solution. At least on my Mobilo HR8572. There are two tabs on the top plastic parts that hold on to the bottom plastic part. These tabs are located above the wheels, if you look closely you will see thicker grey plastic. You have to put a big screwdriver under the top plastic part and move it outward. The tabs are 6mm thick so you have to bend it out considerably. It then pops open. Works a treat and all the motor and electrical components are easily accessible using a simple star driver
Posted on Apr 01, 2010
The on off swtich cannot work in philips vacuum cleanner FC8386/01
Have the switch replaced in a local small appliance repair shop.
Jun 15, 2014 | Vacuums
Dyson cylinder i was sucking a vacuum space saver bag and my vacuum just stopped
Hi Philip,
Your DC11 is equipped with a safety device which shuts the cleaner down if it starts to overheat. It's likely that this is what occurred, as there may not have been enough airflow through the cleaner to keep the motor cool. If you unplug the cleaner and leave it to cool down for at least an hour, you should find it will work again.
If the cleaner still won't run after this time, get in touch with us directly so we can provide further assistance - you can call us free on 0800 298 0298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
Oct 31, 2011 | Dyson DC11 All Floors Bagless Canister...
My vacum Cleaner has ceased to operate
Check from the power cord line to the switch and further the continuity from the switch to the motor. There is no difficulty to check this out but for the trouble to open the unit. So check by logic if the cord is damaged then check into the switch and motor. If power comes to the motor check for the brush contacts, the commutator wearing or the capacitor,
Aug 31, 2010 | Philips Vacuums
Pro hEat will not **** up water from carpet
check the vac motor hose could be clogged? does the vacuum motor turn on? check the vac motor on switch for power using an ohms meter.could have a bad vacuum motor or micro switch.
Jan 26, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Dyson dc14 vacuum cleaner ,the power, off-on switch does not work
Take it back - the power on switch button sounds like its being tempramental and it shouldn't do that. It would have to be repaired.
Mar 31, 2009 | Dyson DC14 All floors Bagless Upright...
Dyson vacuum cleaner doesn't start
check if something is stuck to keep the motor from turning
Mar 18, 2009 | Dyson DC05 Bagless Canister Cyclonic...
I am trying to take my philips vision 8731 vacuum cleaner apart because a heap of c*** got sucked into the motor when the bag was not put in correctly. I have removed all visible screws but cannot for the...
Generic problem for all Vacuums
I am trying to take
I am trying to take my Philips vision 8731 vacuum cleaner apart because a heap of c*** got sucked into the motor when the bag was not put in correctly. I have removed all visible screws but cannot for the life of me find how the wheel end comes apart. Any tips?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
I believe the part you are taking about is the fan and the fans generally are installed by a reverse thread and screws off counter clock wise. Once you removed the fan or the wheel you can use a blower and blow the motor clean, remove the carbon brushes and use a pipe cleaner to clean out the carbon brush holders and then re-install. Also free to contact your local vacuum cleaner dealer in your area or in the yellow pages under vacuums.
Apr 22, 2008 | Vacuums
Vacuums Logo
228 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
