Question about Mitsubishi VS-60705 60" Rear Projection Television
No picture on Mitsubishi VS-60705, picture pops on then wil pop o
Picture fine playing dvds. acted like it needed to warm up then would come on after a while . has gotten worse. when picture off still getting distorted sound. problem at cable input?
  • 2,071 Answers
This a problem of input grounding,the cable input is already loose or crack solder that why you hear a distorted sound because not properly grounded it is a loose contact already thats why also is need to warm up and it wiill come.First change the cables with a new one with identical size and value then if problem still exist open the back cover ,when open look for the cable input connection parts joints reworks or resolder all soldered joints there .Then checks if it works then cover the unit.If you have no knowledge of electronics dont attempt to open to avoid electric shock.Find a TV repairman or bring this to a authorized TV repair shop maybe it cost you only $50.
Hope it may help you;
Regards;
VOTIT
Posted on Jan 11, 2009
    Genius:
  • 1,847 Answers
It seem s issue with the signal, as it plays fine with dvd player.
    Genius:
  • 2,920 Answers
You have a bad transformer
    Scholar:
  • 160 Answers
Minor repairings needed on main board.dry solder the main board and check for the faulty ic and replace it to solve
My tv mitsubishi vs-60705 looks great when i first turn it on after it warms up picture starts to shake and gets worse the longer its on. what is overheating to cause this ?
Sounds like you have a swollen cap in your horizontal hold circuit. Look at your board closely, and I am sure you will find one that is bulging on the top. Just replace with the same value.
May 16, 2011 | Mitsubishi VS-60705 60" Rear Projection...
It takes about 5-10 minutes to warm up, then the picture is fine. While warming up the picture wavy and jittery untill it warms up. Is this a picture tube issue?
You have bad capacitors in the power supply or around the 5v & 9v regulator circuits. If you have a meter just measure the outputs of the regulators. If you don't know what a voltage regulator is or does you should call a qualified repair shop. Estimate repair cost $250
Apr 04, 2010 | Mitsubishi VS-60705 60" Rear Projection...
Vs-60705
My Mitsubishi Model VS-60705 did the same thing a couple of years ago...A TV repair facility replaced the Video card. Any repair facility that works on rear-projection TV's should be able to repair your set. I bought the set on Jan 1, 2000. Coming up on 9 years and the set works like new.
Jul 30, 2008 | Mitsubishi VS-60705 60" Rear Projection...
Tv problemsMitsubishi VS-60705 60 in....
My Mitsubishi Model VS-60705 did the same thing a couple of years ago...A TV repair facility replaced the Video card. Any repair facility facility that works on rear-projection TV's should be able to repair your set.
Jul 10, 2008 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi VS-60705
I have a Mitsubishi VS-60705 and the picture flutters vertically and horizontally i need to be fixed
Dec 04, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi VS-60705 red lamp replacement
The part you are describing is actually the red picture tube, not a lamp. The tube will come dry and you will need to disassemble the lens assembly on the old tube, drain the coolant (antifreeze), reassemble the parts and seal on the new picture tube, fill with fresh coolant, install the new tube, reconnect all wires including the dangerous high voltage lead, then realign the yoke and entire convergence circuits. This is not something that should be attempted by anyone without experience. If you try it yourself and the seal is not working perfectly, the coolant will drip down on your main boards and the set will be ruined. If you slip while lowering the new tube in the chassis there is a good chance you will crack the tube's neck, and that tube will be useless too.
Jul 30, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi VS-60705 - picture flutters vertically and horizontally
This sounds like one of the 9 volt regulators on the small signal board is going bad, supplying less than 8 volts. I have seen this is several of those sets. The IC needs to be replaced and if you do not have experience in servicing projection TV's then I suggest letting a qualified tech handle it for you.
Jul 09, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi VS-60705 60" Rear Projection Television Logo
22 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
