Denon AVR 1609 Receiver circuit breaker trips repeatedly
Hi, folks: My AVR 1609 receiver has developed a nagging problem. Whenever volume is set above -15db, the circuit breaker trips at peak volumes (say, explosions in movies or moments of dynamic crescendo in music). This behavior is consistent, whether it's set for Cinema audio, all flavors of Dolby or just plain-vanilla stereo while listening to CDs, the radio or my iPod. I haven't changed any wiring since installing the unit, nor added any power tools or other drains to that 120v circuit that it's plugged into. Can you suggest what might be causing this, and how to cure it other than having it serviced? It's out of warranty, and I can't afford time or cost of sending it to the bench. Any ideas? Mack Los Angeles
    Top Expert:
  • Audio Player... Master
  • 45,115 Answers
Probably the output stage(s) short circuit at peak volume levels, causing the breaker to trip.
Posted on Mar 21, 2017
2 Suggested Answers
hattonhall
  • 349 Answers
SOURCE: I have a Denon Receiver, that recently started
Hmmm!..give me the hard wired simple sound systems we had for years without even dreaming about the complexities of SMD components and super complex IC's and multilayer printed circuit boards !
Retro my thinking maybe.....but bacj then many Technicians had jobs with a future that they can no longer get due to the changes in equipment complexity and the reluctance of consumers to engage repair services.
Posted on Oct 30, 2011
Denon mod avr-1609. Porque no se escucha que esta pasando?
no sound out of your dennon receiver ? 1st ck your source , if its a dvd or cd player , try switching inputs dvd to cd, second make sure your front panel controls are set to the source your trying to hear(cd or dvd) and make sure you have volume up a bit (30 %) then make sure al your speakers are connected properly and too the correct set of terminals on both the receiver and the speaker end , if any of these things fails to produce a sound out of receiver , then your receiver will require service
Mar 17, 2016 | Audio Players & Recorders
How do I set up my denon 1609 receiver to be remotely run by my Ipad
That unit is not setup for iPad control. You can plug the audio out from the iPad to either the front audio in or CD/Tape IN using a 3.5 M to RCA M cable/adapter
Jan 03, 2015 | Denon AVR-1601 Receiver
Denon AVR 1609 volume Zone 2
Logitech recommends that zone 2 is controlled using device mode on your Harmony remote. Controlling zone 1 and zone 2 simultaneously within activities may lead to the AV Receiver turning on and off unexpectedly as you switch between activities. For example, if you try to turn on zone 2 within an activity, it may turn on or off zone 1 and vice versa. Controlling zone 2 in device mode will prevent this from happening.
Aug 07, 2009 | Denon AVR588 Receiver
Can't Get 360 to Work
Your receiver is not capable of upconverting analog to HDMI (digital). You will need to add component video cables either from the Denon to the TV or simply straight to the TV from the XBox. Audio should be handled solely by the Denon receiver.
Feb 26, 2009 | Denon AVR588 Receiver
No dish network sound through denon 1609 receiver
check the setting for the HDMI connection at the Denon you may have to assign the HDMI audio setting also on the front of the Denon while in the DVR mode press the input mode button on the front of the Denon to select auto and if that doesn;t give you sound you will have to connect a cable from the DVR optical.coaxial or analog audio output to the Denon and setup for that type of audio connection
Jan 19, 2009 | Denon AVR588 Receiver
No sound when ps3 is hooked up to a denon avr 1609
The 1609 only has video on the HDMI. No audio comes through the HDMI cables. Hook up an optical cable between your ps3 and the receiver and you should be good to go.
Dec 29, 2008 | Denon AVR588 Receiver
Denon AVR 1609 Receiver Zone 2 has no sound
you have to change the power amp assignment to zone 2, you must also have Analog audio connections to the Denon from your devices.
Try this put your remote in the zone 2 mode, select tuner in zone 2 and turn zone 2 volume up to -10
Dec 18, 2008 | Denon AVR588 Receiver
Loss of sound on the Denon AVR 2807 a/v surround receiver when I turn on and off lights in my house
Finally the problem was with the HDMI cable. When I pushed it in on the TV set the problem disappeared. It seems the connections must be quite firm on the HDMI cables otherwise anything may interfere to the sound.
Jan 06, 2008 | Denon AVR-2807 Receiver
50 people viewed this question
 Grubhead
Grubhead
