- Why the compressor still on when I turn off the air conditioner?
The air conditioner freezes and if I turn off the ac the compressor still on and a have to unplug the ac
    Problem Solver:
  • 18 Answers
The points on the contactor switch are most likely stuck. will have to be replaced if you can find a local supply house they are usually no more than 10$
Posted on Dec 05, 2012
3 Suggested Answers
22yooper
  • 828 Answers
SOURCE: This is a duo derm roof top air conditioner, possible compressor freezing up
If the compressor is not even trying to start you have an electrical problem in the circuit for the compressor. The thermostat could be open and not supplying power to the compressor or the thermal overload device could be open.
Posted on Nov 06, 2008
SOURCE: Whirlpool portable AC, compressor works, but no exhaust fan
This is a single speed permanent split capacitor motor for the condenser. One of the capacitor wires shows infinite resistance to hot and netral. The motor needs to be replaced.
Posted on Mar 31, 2009
Why does my A/C condenser compressor turn on and off every 5 minutes?
You need good airflow across the indoor coil, the evaporator. Air warms the refrigerant. If there is no airflow, the refrigerant will come back out freezing cold (in liquid form) and can damage the compressor valves. Before charging any ac unit, good airflow must be checked for across both evaporator and condensor.
Too much, overcharging will cause freezing all the way back to the compressor in a capilary tube type of ac.
Where is it the refrigeration lines are freezing cold?
Apr 28, 2015 | Heating & Cooling
The compressor still on and freeze the evaporator
The compressor is probably on bc the contractor is stuck. Disconnect power to compressor and check for continuity across the contractor using your meter
Apr 08, 2014 | Heating & Cooling
Front freezes
What type of air conditioner is it there can be many reasons why it's freezing are you getting and air coming out? Is the compressor working? Is the filters dirty? Check these things out if its none of the above please provide more info on Ac
Jul 16, 2013 | Heating & Cooling
Compressor will not stop running
There has to be a stat or switch or controller of some kind on the rv. I would check that first. If you have a battery operated stat then try changing the batts, otherwise it could be the contactor on the unit or a bad stat.
Apr 26, 2012 | Dometic Rooftop RV Air Conditioner
My whirlpool window air conditioner' compressor
Sounds like a bit of refrigerant leaked out and it is freezing up or at least running too cold...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 14, 2011 | Whirlpool Heating & Cooling
Penguin 13500 ac short cycling
UNITS THEMOSTAT IS BAD REPLACE THERMOSTAT IF DONT SOLVE PROBLEM MAKE SURE UNIT IS NOT FREEZING UP AND BOUNCING OFF A "FREEZE STAT" CASING COMPRESSOR TO SHORT CYCLE
Jul 31, 2009 | Dometic Rooftop RV Air Conditioner
Brand new Dometic rooftop ac,freezes up at night,does fine during day...??
This is common for most air conditioners and is normal due to humidity levels being higher at night causing more condensation build up and then freezing. Solution: Turn down thermostat at night to allow compressor to turn on and off.
Jul 26, 2009 | Heating & Cooling
Duo Therm AC not working
If unit was freezing up the air flow would normally stop, until the unit is turned off and allowed to thaw. I suspect evaporator blower may have a worn out belt, or compressor is shutting off due to control or internal overheat. What is the age of the unit?
Aug 06, 2008 | Dometic Rooftop RV Air Conditioner
Compressor on AC does not go off.
If it is sized correctly I would assume that the problem is a stuck contactor relay. They some times weld themselves closed when they get old.
Jul 07, 2008 | Dometic Rooftop RV Air Conditioner
Ac unit freezing up
Either the coil is clogged, the fan is slow, or the freon is low... A solved rating is great motivation to continue giving priceless advise........
Oct 03, 2007 | Samsung AW0603B Air Conditioner
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
