Question about Foxconn G31MV-K Motherboard
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER"
4 Suggested Answers
lolita
  • 385 Answers
SOURCE: Foxconn 6100K8MA-RS Motherboard
Hi You need to make sure that your boot sequence sets to boot from hard drive first. Also, make sure that the hard drive sequence has the hard drive enabled. If this does not work, then let me know so I can give another suggestion.
Posted on May 31, 2007
byteguy
  • 2229 Answers
SOURCE: Hi. Well there are not
You are seeing a failure to read your hard drive.
Now you need to troubleshoot that. Your hard drive could have gone bad or you can boot from a system disk (that would be a Windows system disk) and run chkdsk.
If you need help doing that, just ask. I'd be glad to help you further.
Posted on May 23, 2009
  • 272 Answers
That is probably an harddisk failure. First check the cable , both data and power to the harddisk. make sure your bios is getting the harddisk on its boot menu / first page on bios. if or when HDD is ok and still not booting up the pc, you should consider an operating system reinstall.
and please comment here to let me know the progress.
Posted on May 24, 2009
Disk boot problems
Insert your OS disc to repair the damaged boot sector and then replace the hdd as that could be the cause.
Sep 11, 2014 | Computers & Internet
Getting message "Disk Boot Failure Insert system disk and press enter" using window xp platform and have MCA fee antivirus software
this happens either the boot sequence have changed or your hard drive is not recognised by the BIOS
Jan 26, 2013 | Computers & Internet
When i turn on my PC toys CPU and emachines monitor it says disk boot failure enter system disk
hi,
you have two option as follows:
1.when you start PC press F2 enter in BIOS set it to boot from HDD then restart,if this step does not help then number 2
2.reinstal the OS
Sep 26, 2012 | E-Machines eMachines Desktop PC
When I switch on my pc,it tells me disk boot failure insert system disk and press enter. I have XP proffessional sp3 but only have a xp home disk.
If your computer has just been formatted, your computer might require you to insert the boot CD
to be able to run it. You might hence get the error message Disk Boot Failure- Insert disk and
press enter displayed on the screen every time you will try to run it. This might be linked
to:
* 1. The boot options not correctly set in BIOS
* 2. A non bootable CD is found in your CD drive
* 3. You do not possess any bootable device
* 4. You have installed a new hard disk
* 5. The hard disk is not properly plugged
* 6. Your system files have been infected
Get more help and information for Disk Boot Failure. Hope this helps you....
Jan 29, 2011 | Microsoft Computers & Internet
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER... i have a mother board K7S741MG-6L, bios version 426wp225, i have this problem BIOS CHECKSUM ERROR , KEYBOARD ERROR or NO KEYBOARD PRESENT (which is...
your hard disk is disconnecetedor loose . pls check the hard disk power cable & IDE or SATA cable. Then check BIOS hard disk detected or not if hard disk is not detected your hard disk is faulty.
Dec 11, 2009 | Foxconn WinFast K7S741MG Motherboard for...
Disk Boot Failure
Any system can be recovered, although it depends on what is wrong.. this error can mean no info on the hard disk, or damaged hd...more than likely whoever had the computer erased it for data's sake...I would've...get an os and load it.
Aug 08, 2009 | Computers & Internet
Disk boot faliure please insert disk and press enter
Sounds like your hard drive has failed and became corrupted or the boot sequence is causing this on the motherboard. I reccommend entering CMOS setup if you can and changing the boot sequence to putting the hard drive first and if that doesn't work insert a recovery disk in during the disk boot failure...please insert disk and press enter screen. Jus make sure to press enter after inserting the disk if that is done...and if that fails I suggest replacing your hard drive with a similar one of equal value and qualities.
Jun 05, 2009 | Intel Motherboard
Hi. Well there are not any reason for this problem to appear. Done nothing regarding disk problem. Anyway when I boot the process stops with the black screen with "Verifying DMI Data...... Boot from...
Make sure you dont have a floppy in the floppy drive inserted.
Also if you have a jump drive installed, plz unplug it.
But if you little computer savy. Go to your bios and make the boot sequence to first boot the Hard Drive
May 24, 2009 | Foxconn G31MX-K socket LGA775 motherboard
Disk boot failure
After making 100% sure you have no diskette or CD in any drives the conclusion may well be that the disk is ruined. You ay try to boot from a diskette or CD and see if you can access the disk then. (see www.ultimatebootcd.com for instructions to make a boot CD) "The ultimate boot CD" has a few tools that might help you out. Since you can't boot you must make it on a different computer, though. You may also try to insert the disk in a diffe rent computer to see if it can be booted there. Also make sure all cables are properly connected.
Apr 03, 2007 | Acer (91.AB033.041) 73 GB Hard Drive
Foxconn G31MV-K Motherboard Logo
27 people viewed this question
Top Foxconn Computers & Internet Experts
Rommel Balcita
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
