Question about Prenco 2001 - 2001 Infiniti QX4 Direct Ignition Coil W0133-1725976 I
Nox sensor i need to know where the 2 nox sensors r located on my 2001 infinity qx4
Where is the cooling temperature sensor located?
If you meant coolant temp sensor there should be two. One with one wire feeds dash display--one with two wires feeds ECU. Both should be located near the thermostat housing. If you meant temp sensor for cooling (Air Conditioning) I have no idea.
Jul 15, 2015 | 2001 Infiniti QX4
Qx4 infiniti wont go intoerdrive
I know its different but on my Isuzu Trooper it happened when the speedo drive (road speed)sender unit on the trans failed.
Sep 05, 2014 | 2001 Infiniti QX4
2001 infinitiy qx4 idles but does not accelerate.
You need to check: MAF mass air flow sensor, Fuel pressure and Catlic converter.
Aug 25, 2011 | 2004 Infiniti QX4
I need to know the knock sensor is on a 98 infinity qx4 v 6? thanks mike
Directly in the middle of the V of the V6. It is under the intake plennum and many parts have to be removed to access the sensor. I have attached a picture. Thanks, Please accept
Jan 29, 2010 | 1999 Infiniti.5 QX4
1999 Infinity QX4. Door Open warning light
usually on post where door closes, or in jamb by hinge area. Open door & try pushing any button/pin like object or may be a lever style too, with thumb or finger.When interior light goes out, you found it
May 03, 2009 | 1999 Infiniti.5 QX4
Tryen to find location of the crank sensor on 1998 infiniti QX4
looking for crankshaft sensor on 1998 infiniti qx4
Mar 01, 2009 | 2004 Infiniti QX4
How many catalitic converters are on the 2001 infiniti QX4
There are only to Catalysts monitored by the ECM. There is a wide pipe near the front of the exhaust system that looks like it houses a catalyst, but it doesn't. Look for the rear O2 sensor, that is where the catalyst is. If the bolts that hold it on are not badly rusted, and depending on your mechanical aptitude you could replace them, otherwise take it to a shop. Have you checked the warranty coverage with the dealership?
Oct 28, 2008 | 2004 Infiniti QX4
Prenco 2001 - 2001 Infiniti QX4 Direct Ignition Coil W0133-1725976 I Logo
Top Prenco GPS Experts
Are you a Prenco GPS Expert? Answer questions, earn points and help others
