Question about Camping, Backpacking & Hiking
Can not get battery out
It unscrews at bottom. but one battery is stuck at the top
  • 19 Answers
If this is an alkaline battery, it may be stuck due to corrosion. I would carefully slide a solution of liquid soap and water going a little heavier on the soap. Dial soap is perfect, and let it sit for 24 hours. The batteries should slide right out. Try it
Posted on Aug 28, 2009
You may have to drill a hole in the batt and pull it out. Probably has acid leak on top of it, and the batt. expanded. Seen this once with a Tape recorder and used a wirehook to get it out. It aint easy, but it can be done and not hurt the light.
Posted on Jan 12, 2009
How do I get the mill open to fill it and put in batteries?
d65b8aa2-bda9-4fd2-810b-bf61e63e797e.jpg pepper mill
e206c9bf-aafd-400c-9672-b16614dd71b0.jpg Unscrew top where clear part attaches to metal. 55cea22b-5cf2-484e-9228-41c8146cea32.jpg
To load batteries, unscrew bottom. Once open, load fresh batteries. If mill fails to operate, unscrew bottom again and flip wire bale in opposite direction.
Jul 05, 2014 | Wolfgang Puck Salt & Pepper Mill Set
Have all in one electronic Wolfgang puck salt and pepper mill. I can't figure out hot to open the top to replace the batteries. It does not work like the electronic sets (is a bit different).
batteries are in the bottom. unscrew bottom cap and pull metal ring to release battery pack. put in fresh batteries and return to casing. screw cap in place. if it does not work immediately, unscrew cap again and move metal wire to opposite side of battery pack and replace the cap again.
Oct 13, 2013 | Wolfgang Puck Salt & Pepper Mill Set
1999 chrysler 300M pcm replacement
1. Disconnect the Negative battery cable
2. Unscrew windshield wiper bolt (1 screw - 10mm). Remove hose from bottom. Place to side
op5nix5zyx17maaaaasuvork5cyii=
Jan 08, 2012 | Chrysler 300M Cars & Trucks
How to battties in a mag light.
The bottom unscrews.When you get the bottom open,screw the top(where the lightbulb is) down further.Hold the flaslight almost sideways and slide the batteries in,then turn the flashlight back up so as not to let the batteries slam.The little positive nipple goes in first for both batteries.After you screw in the bottom,then you can adjust the top end for proper usage/operation.Greg
Dec 18, 2010 | MagLite Mag Lite® 2x 'd' Battery ...
F 21 error code on whirlpool front loading washer. What is it?
Check your filter screen under the bottom panel. Things like socks get stuck in there. Unscrew bottom cover remove screw top cover located right in the center of the bottom. Might want to grab a towel! Screw it back on. Restart. Good luck.
Aug 22, 2010 | Whirlpool WFW8300SW
Need to fix loose wire inside 421 sennheiser how do you open it up?
Well, it looks like an SKM 100/g2 casing so if that is true, then unscrew the bottom part till you have access to the batteries and there are three star screws you'll need to take out right between the battery compartment and the bottom with the LCD screen. The bottom cover slides down and off. If you need the cartridge out then you unscrew the top of the mic where the actual pickup is and pull the core out through the top. That should be close, but might vary a little bit.
Oct 27, 2009 | Sennheiser Flashmic Digital Recording Mic...
How do i change the bulb
Unscrew the bottom portion, where the batteries go. Then unsrew the top where you can adjust the beam width until it comes off. Very carefully pull the bulb out and replace the old bulb with the new. The Reassemble is the reverse of the procedure.
Jun 23, 2009 | MagLite RX3019 Rechargeable Flashlight...
How *** I access the battery in the Omnitech GPS handheld?
there are four screws on the back of the gps top left and right bottom left and right unscrew and open from the top disconnect the speaker wire and battery wire from the main board and the battery is the black or blue rectangular thing on the bottom right of the back cover.
Jun 17, 2009 | GPS
Need to replace the cmos battery on a gateway 450sx4 laptop.
Some are way deep inside, and you have to remove the top part of the case from the bottom.
Some others, you can remove the top power strip, (unscrew screws in the battery compartment, and sometimes on the bottom) and then unscrew the keyboard, and when you remove that, sometimes you can get right to it.
The only problem is, some of the laptop batteries are odd ducks, and not just the standard, they have wires or a metal tag on them. You can always order a new one onces you get to it.
Apr 12, 2009 | Gateway 450SX4 Notebook
How to get a battery out of a maglite.
both ends of your maglite unscrew.  Tap the stuck battery out with a piece of wood and spray in a bit of WD 40
Apr 05, 2009 | MagLite Mag-Lite& Largehead Flashlight
Camping, Backpacking & Hiking Logo
467 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
