Question about Crock Pots & Slow Cookers
Fix broken feet on crockpot - Crock Pots & Slow Cookers
Need replacement rubber feet for my 2 qt Rival Crock Pot
Check your local thrift stores, i.e., Goodwill for a crockpot that is the same or similar and get the feet. It will be very cheap. Also, Home Depot and Lowe's carry very similar products for less than $4. Hope this is helpful.
Feb 08, 2016 | Rival Crock Pots & Slow Cookers
G.E. Slower Cooker/Crockpot
Hi Krista, your model number should be located somewhere on the appliance, then try googling G.E. Slow cooker/crockpot model number XXXXXX parts manual pdf. You will need to install Adobe reader for free if you don't have it to read the pdf format. Good luck and have a nice day.
Sep 25, 2015 | Crock Pots & Slow Cookers
I bent the bottom of my crockpot pushing the rubber feet back in place. How do I take it apart to push out the dent?
There should be a few screws on the bottom that if removed will allow the dis-assembly of the unit. The screws may be inside the rubber feet.
Jul 07, 2014 | Crock Pots & Slow Cookers
Side handle broke on crockpot
you can't cause once you take it apart it don't work right again.
Jan 07, 2013 | Rival 38651-C 6-Quart
E01 code on west bend slow cooker - how can I fix
Your crockpot is giving you an error code EO1. Now you need to know how to get the code off of your crockpot so that you can use it.
Here is a tip that will tell you how to fix the EO1 error code.
West Bend Crockpot EO1 Error Codeheatman101
Jan 14, 2011 | West Bend 84496 6-Quart Slow Cooker
Broken power plug too!
You could go to a hardware store and purchase a new male plug and put it one yourself. 3 bucks maybe. Check it out!
Aug 23, 2009 | Crock Pots & Slow Cookers
Replacement parts
Try one of the following sellers:
To contact the manufacturer, try calling 800 #. 1-800-323-9519 (US number) for replacement parts or try www.crockpot.com
Rival Crock Pot Replacement Parts from MarBeck.com
Crock Pot Replacement Parts | Slow Cooker ...
Nov 09, 2008 | Rival 3060 6-Quart
Broken handle on crockpot
The handle on my rival 20 quart programmable roaster oven is broken. Where can I get a new handle?
Aug 09, 2008 | Rival 37601 6-Quart
Broken knob
Try website www.crockpot.com for replacements
Dec 16, 2007 | Rival 3745 4.5-Quart
Crock Pots & Slow Cookers Logo
44 people viewed this question
Top Crock Pots & Slow Cookers Experts
charles
Irene Tulloch
Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
