Question about Electrical Supplies
Wire a pir sensor
Wiring diagram required
3 Suggested Answers
swolfinor
  • 504 Answers
SOURCE: sensor and control wiring to unit what is the
1. RED - Red trace wire from wall control.
2. WHITE - Wires without trace from wal control and eyes.
3. GRAY - Wires with black trace from eyes.
Hope this helps
Posted on Jul 04, 2010
SOURCE: i have a stairs with a switch and a bulb on each
I answer questions for free.
I know electrical wiring.
I am unsure about a few things in your question.
Are you wanting to know how to wire a product you purchased?
Are looking for a wiring diagram to see if you can do what your want?
1) Is your circuit a 3-way circuit with 2 switches controlling both lights?
2) Or are there 2 different circuits where each switch controls one light?
Here is a Leviton manual with wiring for occupancy sensors:
http://waterheatertimer.org/pdf/Leviton-IPP0R-1LW.pdf
If you want sensors to replace 3-way switches, you need a control sensor and a remote sensor.
Click link below to see this image clearly
http://waterheatertimer.org/images/3-way-sensor-600.jpg
Add a comment and I will get back to you with specific details about wiring.
Posted on Nov 01, 2010
Replacing a one way light switch with a infrared motion sensor. Sensor has N,L,A connection points. brown to L. blue to N and green to old earth on socket base. What is the A for ? Not working Joh
It is best not to speculate about this - you need to refer to the data sheet for the switch. The passive infrared sensor will require a low voltage for operation which it will derive from the mains (probably) but that would usually require a neutral to be present in some form.
A neutral of sorts could be derived from the circuit through the load, but only while it is switched off) or from the earth connection, which is a practice that is frowned upon.
Apr 22, 2017 | Electrical Supplies
PIR switches and house wiring is incompatable?
Several possibilities. First use standard light bulbs until it is working. Some of the PIR have triac outputs which need a minimum amount of current to work. CFL and LED lights can be a problem with electronic switches/dimmers.
The PIR needs electricity to operate. The black and white wire are probably power and return, there is no neutral to connect to the PIR. Unless you can get a different PIR that does not need line power to operate you are out of luck. There may be some that can cycle steal power and would work but I am not familiar with them.
I assume the three way is a three way PIR and the lights that are flickering are electronic such as LED or CFL.
If you talk to one of the people where you bought the switch they may help you free of charge.
Good Luck
Feb 23, 2014 | Electrical Supplies
Pir connected to 3 bulkhead lights the lights work but the pir doesn't appear to operate the lights just stay on I have attached a picture of the wiring can anybody tell me if it is correct
It appears you do not have it wired correctly. If you want help a better description is needed. I would think the brown wire needs to be connected to something.
Feb 18, 2014 | Electrical Supplies
I want to replance a standard wall switch (2 wires: white & black) with a PIR Occupancy Sensor switch
Copy following link for simple walk-thru how to wire occupancy switch
http://waterheatertimer.org/How-to-wire-occupancy-switch.html
This device is made to replace single-pole switch.
Power to fan: note the horsepower range for device: for example if occupancy switch is rated 1/4 Hp, then it will work for ordinary bath fan. If device is rated for 1/3-1/2 Hp then it is rated for whole-house fan.
Each fan motor will have rating plate showing Hp. Check rating labels for each device.
http://waterheatertimer.org/Color-codewire.html
Apr 08, 2013 | Hardware & Accessories
User manual for fl09sbk light
It appears this device is rate 10 amps at 230 volts = 2300 watts.
Use at least #14 wire and 15 amp breaker.
Connect wire at connection point on light.
Unit appears to have a transformer, and might make humming sound.
There is override located somewhere on unit. Possibly as a button on the motion sensor
If infrared motion detector requires separate wiring connection, then use following wiring illustration:
http://waterheatertimer.org/images/How-to-wire-motion-sensor-230V.jpg
Motion sensor will probably have 2 settings.
1st setting for sensitivity, so it will not activate when cat walks up driveway.
2nd setting for time duration, selectable from 30 seconds to 7 minutes
ML FL09SBK IP44 36W Fluorescent PIR Floodlight c/w Lamp
IP44 Low Energy Floodlight c/w PIR & Override.
Black finish.
T4 twist and lock lampholder.
36 Watt 6500k T4 spiral compact fluorescent lamp included.
(replacement lamp - product code FL09L).
Electrical termination via 10 Amp connector block within secure enclosure c/w cord grip.
PIR detection range of 12 meters at 2 meter height from ground.
Detection arch of 160 degrees.
Time range 30 seconds to 7 minutes.
Manual override.
Nov 12, 2012 | Woods Outdoor Lighting Timer
Wiring diagram for a p i r to a light
They all wire the same. The black wire on the PIR connects to the incoming (usually black) hot or switched wire. The red wire on the PIR connects to the light(s), usually a black wire. The white (neutral) wire from the PIR connects to BOTH the incoming white wire and the white wire that goes to the light(s).
Jan 17, 2012 | Home
Wiring Diagram for Outside Security Light with PIR
what kind of lights?
most have black, white and green wiring, black to house power, white to neutral, and green to ground
Sep 15, 2011 | Home
How to wire
This should replace any existing single pole (one location) switch. You have two wires on the pir, black and blue and then the ground. The black hooks to the hot or common wire. It may be black, but it will be the hot wire. The blue wire hooks to the wire going to the light. The ground hooks to the green or bare.
Mar 05, 2011 | Leviton Decora Wall Switch With Pir...
I have a stairs with a switch and a bulb on each floor and i need to replace them with a wall pir sensor on each floor i need the wiring diagram
Oct 31, 2010 | Cooper Wiring Devices Motion Sensing...
Wiring diagram 3 way motion detector switch I want the motion detector to be in the hot line box, and I want a regular 3 way to turn the light on from the load box. So far I can only get the motion...
Sorry, but you need one extra wire between the switches to wire "the opposite configuration" that you want :-(
That means going into the attic and pulling another cable :-( I can walk you through it if you are willing to do all that work.
The only other solution would be to purchase the commercial version of that motion switch, which would also require a sensor at _each_ switch location :-(
Jan 02, 2010 | Leviton R01-PR180-1LI Decora 180 Degree...
Electrical Supplies Logo
194 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
