Question about Vizio P50HDTV20A 50 in. Plasma HDTV
I have a 50" Vizio plasma tv that is about 5 years old. Recently when I turn it on it cuts off or blinks. I have to turn it off and back on several times in order to get the picture to come on. I am s
    Problem Solver:
  • 5 Answers
Yes it's. Just bring it 2the nearst electronic shop for repair. T power my be spoile or some insect get inside n make it burn. It's ever happen 2 my tv also.
Posted on Dec 04, 2012
SOURCE: VIZIO 50" PLASMA
Wow. This is more comon than I thought. My 50" Vizio plasma just went out as will after a loud pop noise. Power button is still lit. Sound continue to come through but no picture. I will dig into it and see if I can find a appropriate solution.
Posted on Aug 11, 2008
SOURCE: VIZIO 42" Plasma HDTV
i have a vizio p42 and i have sound but no picture i have tryed to reset it but nothing works
Posted on Aug 29, 2008
Slapnuts1975
  • 51 Answers
SOURCE: Vizio L32 HDTV 10A - Won't Turn On
Bad capacitors in the power supply. Open it up and look for swollen electrolytics.
Posted on Sep 22, 2008
DRACO A5OG
  • 22 Answers
SOURCE: vertical red line on my Vizio plasma
Spent 3 hours removing all what seemed like 100 freaken screws.
Took out the OEM 038A, caution the factory placed some type of heat transfer silicon clear grease on the back of the board so it will feel like it is glued on. Just be very carefull and gentle when prying it apart.
Be warned, you will need a magnifying glas to check those little resistors. They all checked out, no broken solders.
What I did observe is the grease melted down the back of the board and puddled at the bottom of the board and where the resistors sit.
I used rubbing alcohol to clean it all up but left the reside on the square pads. Cleaned the resistors and used a dry paint brush to dust of any lint.
Placed the component back and after 10 minutes the Vertical Red Line Disappeared.
Turned on the set next morning it was still gone. 10 minutes later it re-appeared for a couple of minutes then went away.
I spoke to a kind gentlemen at Electronica-USA.com, he stated that the 060Q is an upgrade to the defective proned 038A ( 038C is also an upgrade ). A tech in Cali stated the 060Q worked perfectly. He has had zero complaints about the 060Q in the Vizio plus he offers a 90 day return policy. Funny thing is the 060Q was designed for LG and Goldstar Plasmas but for some reason they do not work for them but do work for Vizio's. He even states that on his site.
As I type the red line is still gone and stayed off several hours last night.
I think I am going to pull the trigger and replace the 038A to the 060Q and be done with it.
Oh yeah, I asked him if the 060Q needs to be "flashed" with the Vizio program. He never heard of it requiring it.
He has 038C on order they are couple of bucks cheaper. the 060Q is $224 plus S&H.
I found on ebay for $184 free shipping but waiting for the guy to verify no "flash" requirement.
Hope this helps someone.
Merry Christmas and a Happy New Year!
P.S. use a power screwdriver, your wrist will thank you. I put mine on low torque as not to strip the heads.
Posted on Dec 23, 2008
  • 4 Answers
SOURCE: plasma tv has no picture but green led is on
Try unplugging the TV for a few minutes (discharges the ballast/ps) then plug in and attempt to power on. I have the 42P Vizio over two years old and ran into the same problem a few times. First thought was a power supply issue, but the unplugging trick worked. Good luck.
Posted on Apr 17, 2009
Turns on then turns off
check for a bulging capacitors first at the power supply board.
Oct 07, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
My tv turned off and won't turn back on. There is an orange light still on
It sounds like the power supply board has failed. On TVs that are this age this is a very common problem. Contact the extended warranty company and have them send a tech out.
Jul 16, 2012 | Vizio P50HDTV20A 50 in. Plasma HDTV
I HAVE A 50' PHILIPS MODEL 50PFP5332D/37 FLAT SCREEN TV. I BLEW A BREAKER ON THE TV PLUG IN WITH A PORTABLE HEATER. TURNED BREAKER ON TV CAME ON WORKED FINE. TURNED OFF. 1HR. LATER A RED BLINKING LIGHT WAS...
HI:
This is a plasma unit and philips plasma's are nortorious for bad power supplys, your problem may very well be the power suppy in the television, it is possible you blew a low B+ fuse on the power supply. There is also a issue with the Y-sustain board failing in this model, If you open the back and looking at the unit from the rear the y board is on the left side of the unit and the PS is in the center. disconnect the Y-sustain power plug from the power supply and turn on the unit if the unit stays on with no red light then the y board is bad. it does the same then replace the Power Supply.
Mar 10, 2011 | Philips 50PFP5332D 50 in. Plasma...
I have a 2 year old Vizio P50HDTV20A 50 in. HDTV Plasma TV Occasionally, when I turn it off, it goes into standby mode as normal but then will not turn back on with the remote or the power button on...
i think you unconciously program the tv on its timer mode and it is still not yet remove. check it out on menu, find the time set it off. if you already done it then the system i.c. has the problem
Jan 28, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
50" lg plasma tv will not power up
The problem with the set is bulged electrolytic capacitors in the power supply.
May 16, 2010 | LG 42PX5D 42 in. Plasma HDTV
Similar issue with Vizio 32" plasma - turning on and off repeats
Possibly startup circuitry or microproc that handles turn on
Jun 17, 2009 | RCA 20F512T 20" TV
Vizio P50HDTV10A 50 in. HDTV Plasma HDTV Tuner out
The HDTV tuner is out. Analog tuner, and video inputs work fine.
TV Model P50HDTV10A
Screen Size 50 in.
TV Manufactured Date Jan 1, 2007
Part Type MAIN UNIT
Alternate Part Type SIGNAL BOARD
Part Number 3850-0042-0150(3A)
Alternate Part Number 0171-2272-2163
Jan 08, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
No picture but has sound
The problem can be caused by a bad sustain board (Ysus Zsus) , the popping sound is often caused by a capacitor blowing up.
The TV must be taken apart and tested before eventually replacing sustain boards.
Apr 27, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
No picture
Hav 50 inch lg no pic but got sound wtf how do i fix it an there r 5 flashes b4 green light stayes on at the start
Apr 10, 2008 | LG 42LC2D 42 in. LCD HDTV
Vizio P50HDTV20A 50 in. Plasma HDTV Logo
210 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
