Question about HP Pavilion F1703 17" LCD Monitor
I need to know the polarity of my Hp Pavilion F1703 monitor as I have just brought a new power adaptor and before I connect up to the mains it says make sure you insert the adaptor the correct way round i.e. positive or negative polarity as incorrect connection could damage the monitor
  • 30 Answers
Hi!
I found the spec for the adaptor:
Output: 12V DC
Current: up to 5A / 60W max
Connector: Barrel, Center +
It means positive is the inner side of the connector.
Here is some useful links.
http://en.wikipedia.org/wiki/Coaxial_power_connector
It is not a very special adapor i think.
Posted on Jan 12, 2009
  • HP Master
  • 5,568 Answers
If the monitor does not have a symbol (similar to the letter 'C' with a dot in the middle), the cheapest digital multimeter can be used on the 'diode' or 'continuity' setting to check the input.
If the meter reads between 600 and 900, you are measuring the forward voltage drop of a protective diode.  Any other reading will mean that the positive probe of the meter is on the positive part of the connector.     i.e. If you are placing the positive meter lead on the center pin and the negative on the shell and it reads 600-900, then the power supply needs to have the negative applied to the center pin and the positive on the shell. If the negative lead is held on the center pin and the positive on the shell and the reading is 600-900 then the center pin is the positive input and the shell the negative.
The readings shown above mean that you are measuring the forward voltage drop of a diode meant to protect the unit against improper polarization and it will probably either die or ruin the adaptor if misapplying the polarity.
You can buy such a meter at electronics or auto parts stores for under $20 US.
Posted on Jan 11, 2009
A450N needs new monitor - what monitor specs are required?
Any monitor will do unless you are trying to get one with the built in speakers that you have. Just make sure the monitor has the same type of connection that you currently have (VGA, DVI, HDMI, etc).
Apr 23, 2012 | HP Pavilion a450n PC Desktop
I need to know the polarity of the barrell plug on hp pavilion f1703 that was given to me with out the powersupply. **** w. Pierce dickwpierce@juno.com
It's center pin positive, sleeve negative. Replacement supplies are commonly available online. 12 volts DC, 4 or 5 amps is what the replacements are rated.
Feb 18, 2011 | HP Pavilion F1703 17" LCD Monitor
My hp f1703 monitor just turns off on it's own.
Common failure in this monitor is the poor soldering works on the doughnut (4) shape inductors in the inverter board, http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/
Feb 18, 2010 | HP Pavilion F1703 17" LCD Monitor
Plug in loose on back of hp pavilion f1703 monitor it makes the monitor shut down. I also have a problem with the connection to the motherboard where it screws in one of the screws stays loose but it...
if you have soldering equipment you can fix it in 5 minutes otherwise if you don't move it it can work a long time without problems
the best you can do is to fix the connection.
Feb 13, 2010 | HP Pavilion F1703 17" LCD Monitor
Can a 12V 3.5A lcd monitor be replaced with a 12V 4.15A power supply?
Yes that will not create any problems as long as the voltage and plug polarity is correct. Look for the polarity diagram on the power supply, or in the manual and make sure!
Apr 11, 2009 | HP Pavilion F1703 17" LCD Monitor
Hp pavilion f1703 blue monitor power button flashesw/ dark screen
Have you tried connecting this monitor to another computer, even a laptop. This would tell you whether the display is bad or the video card is the culprit. I suspect the monitor's power supply is dying. Taking it to a pro for repair should cost @55.00. Buying a new monitor @ $100 - $125.
Mar 26, 2009 | HP Pavilion F1703 17" LCD Monitor
HP Pavilion F1703 17" LCD Monitor Logo
126 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
