Question about Hoover U5450-900 Windtunnel Supreme Bagged Upright Vacuum
Sensor wont go to green
Even when vacuuim is lifted above the carpet and sucking in fresh air the sensor still shows red. Does flash green rarely when vacuuming however
  • 45 Answers
Try cleaning the dirt sensor. It's usually located where the bag connects to the vacuum. Take the bag off and clean the inside of the tube that goes into the bag with a damp cloth.
Posted on Jan 11, 2009
Red "DIRTY" light is on most of time, even after going over and over what should be clean carpets. Head is lifted, getting good suction. Got a solution?
The sensor that detects the dirt can get dirty causing the light to stay on. Hold the vacuum up in the air or position the vacuum in a way to observe the light when the vacuum is running but the nozzle assembly is not on the floor so it cannot be picking up any dirt. If the light will not go off it's likely the sensor needs cleaned.
Mar 09, 2017 | Vacuums
What is the best way to clean a fresh blood stain from a wool carpet?
Cold water on a clean cloth, blot with damp cloth, then with dry cloth, repeat, repeat, repeat until you do not see any red coming out. If you have a carpet cleaner flush it with lots of cold water sucking it up with your carper cleaner or extractor. A good professional carpet cleaner can prevent your spot from becoming a stain. Often you can use enzyme cleaners to remove blood but NOT on wool carpets.
Apr 07, 2016 | Vacuums
The cleaner is not sucking up the water from the carpet
There should be a filter. If it's clogged or old, water will not flow through it properly. Meaning... Your machine will not suck the water up, once you've made a big mess on your carpet.
Good luck and Merry Christmas, Bill
Dec 19, 2014 | Vacuums
Wont spray water on the carpet
Same Problem here- The hand piece works fine. Bissell 9500 ProHeat2X.
Both tanks full New Belt on the brushes I can not get cleaner/water to spary when trying to clean the floors.
I've taken my air-compressor and with low psi blown back to make sure teh lines are clear from the spary heads. Still not working...
Apr 17, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Wont **** up very much and know my room smells rotten
Even the professionals have problems getting pet stain smells out of carpeting. You need to use a good deodorizer and get the carpet as dry as possible.
Aug 22, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell 2x steam cleaner is not picking up the water from the carpet. What do I need to do?
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
vxbv
Jul 11, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
G5 intermittently or not at all pulling up dirt
Turns out that little light is a BELT indicator. Even though the belt wasn't broken it had stretched and needed to be replaced. So a $2 part and my baby is working as well as ever!!
Jan 17, 2009 | Kirby G5 Bagged Upright Vacuum
Kirby g 5 head bounces when vacuuming and tech drive is engaged, does not do this everytime
first change the belt, even if it is not broken. also make sure that the height adjustment is raised up high enough, the higher the better ( when adjusting a vacuum you want the tips of the brush roller touching the tips of the carpet fibers ) also the same problem could occur on an area rug or any place the carpet is not securely held down ( the carpet can lift up and get sucked up into the vacuum )
Sep 22, 2008 | Vacuums
Hoover U5450-900 Windtunnel Supreme Bagged Upright Vacuum Logo
125 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
