Question about Goodman Heating & Cooling
Blower motor malfunction
I have a Goodman A24-10 stat in the off position, blower runs continously. switch the stat to cool or heat blower cuts off. Switch from auto to on fan shuts off.
    New Friend:
  • 18 Answers
Possible bad stat
Posted on Dec 05, 2012
  • Wayne Miller Dec 05, 2012
    I have already changed the stat. Same problem, heat and cool off, fan switch on auto. Fan runs as soon as I turn on the breaker. If I turn the fan switch to on the blower stops. Yes the stat is wired right.
2 Suggested Answers
  • 1833 Answers
SOURCE: I have a goodman a49-20 I cannot get the blower
The motor coil has gone bad. You have rewind the motor coil. Or you have to purchase a new motor.
But, check if you are under Warrantee. If so do not try to repair it yourself. Warrantee will void. Contact the service center or help line.
Posted on Mar 21, 2011
Goodman furnace a36-20 fan runs non stop
is green wire from thermostat or from outdoor. retrace and change as needed. If not Goodman has a tech support number you can call while looking at unit.
Jun 21, 2014 | Goodman Heating & Cooling
Indoor blower wont run on cool cycle
sounds like a wiring problem. the t-stat fan on position uses high speed on fan as does the call for cool. possibly a bad t-stat.
Apr 08, 2014 | Goodman Heating & Cooling
Blower on heat pump blowing with no demand
There is a contact in the blower control card that can stick on. There is also a possibility that the green wire which starts the blower motor could be shorting out with the red wire somewhere inside the thermostat wire. If that is the problem, either pull new thermostat wire, (the rest of the insulation is probably breaking down) or there is some new red link controllers from Honeywell that will completely eliminate wire because the controls are all wireless.
Feb 05, 2014 | Goodman Manufacturing Goodman GPH1348H41...
When I turn the system on for cooling, everything sounds likes its running properly, but no air comes out of the house vents. The capacitor is good, fan comes on, coils are getting cold. Could it be the...
Its possible but you might try a little diagnostics first. Put your thermostat in the off position and the fan switch in the auto position. Make sure the switch on the air handler inside is on. Now have someone stand by the blower while you switch the fan switch back and forth from auto to on. If the person at the blower hears a clicking sound from inside the blower cabinet you probably have a bad motor. But if you hear nothing it probably means you don't have power. Check the blower door to make sure its tight and the safety switch is depressed. The wall switch should be tested. Don't have any easy ways to check for power without a volt meter. Hope this helps good luck.
Aug 18, 2013 | Goodman Manufacturing Goodman GPH1530M41...
Blower runs constantly both warm and cool air
If talking about a hot air furnace check that you dont have t stat fan switch in auto position. As this will run blower continously regardless if calling for heat or cool is has ac also.
Nov 24, 2012 | Goodman Heating & Cooling
WEATHER KING GAS FURNACE . BLOWER MOTOR COMES ON INSTANTLY ON CALL FOR HEAT AND WONT SPARK IGNITE.
You have a high temp safety open. The control board sends a signal through all safeties first. And if there is a safety open, the board believes the unit is overheating, so it engages the blower to cool it down. The safeties are normally on the blower assembly, near the burners, and near the heat exchanger. Hope this helps!
Sep 24, 2017 | Heating & Cooling
Goodman furnace GMP075-3 The thermostat was in the off position over night and sometime during the night, the induced blower and blower motor came on. The trouble light on board blinks 5 times. I checked...
Need your model # to check the codes but, this coming back on after turning the t-stat off is rare. You may have been in a lockout and the furnace re-started. Some furnaces try to start three times , then lock out. Time out, then re-start. The codes should be on your furnace blower door. Write back with this info and i could help.
Oct 12, 2011 | Goodman GMS90703BXA Heater
GMPN 100-4 furnace. Blower motor runs when not calling for heat.
The board is bad. The unit thinks a flame is present, so it tells the blower to come on. Replace the board.
Oct 07, 2009 | Goodman Heating & Cooling
Goodman GMH950904CXAC with white rogers programmable stat. Turn the furnace on and the blower comes on whether there is a call for cool or not. Red led on control board is on, indicating OK. Disconnect...
make sure the blower is not set on rather than auto or the blower will run all the time. You might want to disconnect the thermostat and test the low voltage circuit to make sure the wires are not shorted
Aug 12, 2009 | Heating & Cooling
The fan in the airhandler wont shut off.
The fan is controlled by a blower timer board located inside the air handler, or on older units it has a relay called (of all things) a blower relay. If these items were at fault I doubt removing the thermostat would cause the blower to go off. if bad causing this problem the blower would continue to run even with thermostat removed.
But it is also controlled by the thermostat.
You mentioned that if you remove the thermostat it cuts off. There are 2 switches on most thermostats.
1 has Cool, Off, Heat, and Emergency Heat (on a heat pump stat)
2 The other switch has On and auto (it is for the fan motor only)
I believe because it stops when you remove the thermostat that the switch on the fan is set to on possibly. It should be on auto-matic. This way the fan motor only come on with cooling or heating. If in the on it stays on all the time. If this is the case just switch to AUTO.
Or the thermostat may be wired wrong. The G terminal is where the fan motor gets instructions from the thermostat. Make sure its on G at the stat and the correct wire at the blower coil is being used for the corresponding wire going from the stat to the blower for G. Don't confues G for green it could be any color. The terminals are not for color but it makes more sence to make them color - letter identified. On the other end soemtimes the wires are not colored the same so look carefully.
Also a whisker of a thermostat wire could be touching inside the thermostat and causeing the motor to run 100%. Look carefully at this and see if it has too long of thermostat wires stickinhg on out under the screws to where they may tough other things.
If neither things stop or show the problem and it deffinately stops when thermostat is removed the thermostat is most likely bad.
If this helps you 1 way to make the repairs your\self or helps you realize you need a technician please rate mne as high as you can.
May 14, 2009 | Heating & Cooling
Heating & Cooling Logo
52 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
